IBM PS/2 Model 80 Capacitor Replacement Guide
This guide covers capacitor diagnosis and replacement on the IBM PS/2 Model 80 (machine type 8580, all submodels). It covers the planar, the tower power supply, the diskette drive and the fixed-disk subsystem. The Model 80 shares its chassis and its power-supply form factor with the Model 60 and the Model 65 SX, so most of what follows applies to those too.
Read this first. IBM published no capacitor values for any part of the 8580: the technical reference, the hardware maintenance manual and the parts catalogues all work at FRU level, and the planar schematics are net-level without a valued parts list.[1][2][3] Every value below comes either from a reverse-engineered schematic of a physical supply or from a documented community teardown, and is labelled as such.
Safety Warning
The tower supply is mains-rectified. Its two primary reservoir capacitors are connected in series across the rectified mains so the unit can accept 220 V input, with a chain of balancing resistors across them; between them they store a great deal of energy and they do not self-discharge quickly.[4] Before any work inside the supply:
- Power off and unplug the mains lead.
- Discharge each reservoir capacitor individually through a 1 kΩ / 5 W resistor across its own terminals — discharging across the pair is not enough if one has drifted.
- Confirm with a meter that both read near zero before you touch the board.
- Do not probe a powered primary side without an isolation transformer.
There is no CRT in the system unit; the matching IBM displays are serviced separately. See CRT Discharge Procedure if you are working on one.
The Planar Does Not Need Recapping
The 8580 planar does not carry surface-mount aluminium electrolytic capacitors. Photographs of the Type 1 and Type 2 planars show through-hole dipped tantalum beads — the orange and yellow teardrops scattered between the logic — together with surface-mount ceramic chips for high-frequency decoupling. There are no electrolytic cans on the board to leak.[5][6]
This matters, because the standing advice for PS/2 machines is often "recap the planar on sight". On this board there is nothing to recap, and lifting dozens of healthy tantalums off a thirty-five-year-old multilayer board is a reliable way to turn a working machine into a donor.
Two claims in particular should not be applied here:
- There is no published designator-to-value map for this planar, and the values are not on the silkscreen. The "10 µF / 16 V marked 106 16V" tantalum quoted for IBM PC, XT and AT motherboards is documented for those through-hole boards only and has never been shown to apply to a PS/2 planar.
- IBM factory rework wire is present on many 8580 planars. The yellow wires visible on photographs of the 20 MHz board are how it left the factory, not damage.[6]
What to do instead
The commonest planar-level fault on this machine is not electrical at all. The supply's fan draws household dust directly onto a sensitive area of the board, and that dust is often conductive; current leaking between IC pins produces lost configuration, a clock showing nonsense after a long power-off, and disk read/write errors. The affected area holds the 8042 keyboard controller, the MC146818A real-time clock, the diskette controller, the NS16550 UART, the RTC crystal and sometimes an 8259A. Strip the machine, blow the supply out somewhere you do not mind making filthy, then brush and vacuum the board and check between the IC pins.[7]
If you suspect a shorted tantalum
Tantalums fail short far more often than open, and a shorted decoupling part drags its rail down and can make the supply latch off.
- Unplug and discharge the supply.
- Set a multimeter to its lowest resistance range or to diode test and probe from ground to the rail side of each part. A good one settles high after a brief charging pulse; a shorted one sits near 0 Ω.
- Everything on a rail is in parallel, so a low reading indicts the rail, not the part. Lift one end and measure again before replacing anything.
- Replace with an equivalent tantalum or a low-ESR ceramic of the same value and equal or higher working voltage, read from the part you removed.
Power Supply
Three ratings were fitted across the tower family, and IBM's own technical reference lists heat outputs for all three. Only one of them has been documented at component level.[1][8]
| Rating | Identification | Component-level data |
| 225 W | IBM P/N 72X6665, REV A58491, PEC 3978; also seen as FRU 15F6548, and as P/N 90X9109 / FRU 15F6551 on Schrack-built units. Red switch | Reverse-engineered schematic available for the 72X6665 unit |
| 242 W | Later 8580s, including the 25 MHz models | None published |
| 250 W | FRU 57F1600 — the part the October 1994 maintenance manual lists as the replacement across 60/65/80 | None published |
More than one manufacturer built these. Al Savage's teardown of a failed 225 W unit found a Schrack EP071063-A with screwed case halves, while another supply carrying the same IBM part numbers was an Italian Plessey with riveted halves. The internals differ. Read values off your own board.[9]
How the 225 W supply works
Knowing the topology tells you which capacitors matter. Eric Schlaepfer's reverse-engineering of the 72X6665 establishes it as a resonant converter with a separate auxiliary bias supply — effectively two supplies in one box:[4]
- Inrush into the two series reservoir capacitors is limited by thermistors RT1 and RT2 with resistors R117 and R118, and the pair is balanced by the resistor chain R100–R114.
- The bias supply uses a triac preregulator that chops part of each mains cycle, so the controller's supply rail sits at roughly the same voltage on 120 V or 220 V input.
- All three outputs are monitored for over- and under-voltage. An over-voltage latches the supply off; an under-voltage simply de-asserts Power Good.
- The front-panel power LED is driven by Power Good. The hard-disk LED is driven by the planar, not by the supply.
The practical reading: a tower that clicks and dies is usually something shorting a rail, not a dead supply; a machine whose power light never comes on has a supply that is running but not meeting its own under-voltage thresholds; and a supply that latches off and stays off until the switch is cycled is doing what it was designed to do.
225 W supply — electrolytic capacitors
These values are read from the reverse-engineered schematic of the 72X6665 / PEC 3978 unit, hosted here: File:IBM PS2 225W Power Supply 72X6665 Reverse-Engineered Schematic (Tube Time 2024).pdf. They are not an IBM specification, and they apply to that unit only — not to the 242 W or 250 W supplies, and not necessarily to a Schrack- or Plessey-built 225 W. Check each part against your own board before ordering.[4]
| Designator | Value | Position |
| C5, C6 | 1000 µF / 200 V | Primary reservoir pair, in series across the rectified mains, balanced by the 220 kΩ chain. These are the lethal ones. |
| C16, C40 | 4700 µF / 10 V | +5 V output reservoir, ahead of the output chokes |
| C41 | 470 µF / 35 V | +5 V output, after the chokes |
| C18 | 4700 µF / 16 V | +12 V output reservoir |
| C17 | 470 µF / 35 V | −12 V, ahead of the LM7912 regulator |
| C19 | 47 µF / 25 V | −12 V, after the regulator |
| C20 | 2200 µF / 16 V | Preregulator / auxiliary bias supply |
| C13, C14 | 22 µF / 25 V | Bias and control |
| C34, C56, C57 | 10 µF / 50 V | Control and reference |
Note what this table does not say. The +5 V reservoirs are 4700 µF rated at 10 V, not the 2200 µF / 16 V often quoted, and the primary reservoir is a series pair of 1000 µF / 200 V, not a single can. Anyone who tells you the primary bulk in this supply is a single 220 µF / 200 V part has not looked at one.
The mains-side non-electrolytics on the same sheet include 1 µF / 250 V parts and C26 at 0.1 µF / 500 V, with 560 pF line-to-earth parts at C3, C4, C52 and C53. These are safety-critical positions — replace them only with correctly rated X- or Y-class safety capacitors, never with ordinary film parts. Any RIFA-branded part with crazing in its epoxy should be replaced on sight. Several designators on the sheet are marked "?" because the author could not read the original part; those are yours to read off the board.
A documented failure
Al Savage's 8580 died with a chirping supply. Disconnecting the outputs did not change the symptom. The cause was a shorted 3300 µF / 16 V output filter capacitor — one of an identical pair, the upper one — on a Schrack EP071063-A board with no silkscreened component locations. He also found a cold solder joint on the solder side.[9]
That value does not appear on the Tube Time schematic of the 72X6665, which is exactly the point: these are different physical designs sharing IBM part numbers. A chirping or ticking supply with a symptom that does not change when the outputs are disconnected is an internal fault, and the output filter capacitors are the first place to look.
Recapping the supply
- Remove the rear drive carrier from the drive support structure, unplug any 4-pin drive power leads and the planar power plug, take out the three screws holding the supply, and draw it out of the top of the chassis.[8]
- Discharge each reservoir capacitor individually and confirm with a meter.
- The case screws are security Torx (a pin in the centre of the drive). On a Schrack unit, disconnect the short ground lead routed through the top cover before lifting it; the PCB is notched so the cover comes straight up after sliding it about an inch.[9]
- Photograph the board from both sides before touching anything, and write down every value, working voltage, diameter and polarity.
- Replace like for like: same capacitance, equal or higher working voltage, 105 °C rating, low-ESR where the original was low-ESR.
- Replace mains-side X and Y capacitors only with correctly rated safety parts.
- Bench-test the outputs under a modest resistive load before refitting, against IBM's service limits on the maintenance page.
Before you open it at all: about half of failed Model 80 supplies failed on a broken power switch, not on the electronics — the red switches more often than the white. The same switch was used in IBM 327x and 525x terminals and was a stocked spare.[8]
A crackling noise from a machine that is switched off is not automatically a capacitor. It has been traced to the switch itself (the front switch cover acts as an echo chamber and throws the sound to the rear), to an insulation fault in the AC line filter, and to a loose mains lead.[8]
Diskette Drive Logic Board
This is the one assembly on the machine with a documented capacitor fault and documented values.
The 8580 used two interfaces. The 25 MHz -Axx machines use the 34-pin style drive; every earlier model uses the card-edge style, P/N 90X6766 with FRU 72X8523. Both were built by Mitsubishi, ALPS and others to a common IBM specification, and all take power through the interface with no separate power connector. 2.88 MB drives were released for later PS/2 systems and should not be used here.[10]
Al Savage found that all three of his 8580 diskette drives would not read, and that the cause was surface-mount electrolytics that were open-circuit or very high-ESR. On the Mitsubishi MF355W-99M3 (P/N 90X6766, FRU 72X8523, EC A58560, dated August 1989) he identified and marked five parts:[10]
| Value | Quantity | Position |
| 22 µF / 16 V | 2 | Beside the card-edge connector, at the left of the logic board |
| 1 µF / 50 V | 1 | Centre of the logic board |
| 0.22 µF / 50 V | 2 | Centre of the logic board, to the right of the 1 µF |
Revisions differ. Another account of the same family replaced two parts with 10 µF; the 2.88 MB drives are different again. Read the values off your own board.[10][11]
Alan Douglas, who did this work on 8580 drives, used surface-mount electrolytics of the same type for the 22 µF and 1 µF positions; 0.22 µF electrolytics are hard to obtain, so ceramics went in there, and tantalum chips are a reasonable substitute elsewhere. Through-hole parts soldered to the surface-mount pads work if nothing else is to hand, at the cost of appearance and of standing proud enough to be sheared off later.[7][11]
Removal is the awkward part: the pads are small, and leaking parts contaminate their own joints so they refuse to reflow and the leg pulls free before the solder melts. Cutting the can in two with flush cutters, removing the rubber seal and then working on the exposed stubs from above is far less likely to tear a pad than pulling on an intact part.[7][12]
Mitsubishi drives in these machines are specifically noted for capacitors that produce 6xx electronic errors at POST.[7]
Faults that look like capacitor faults and are not
- 162 at POST with the drive otherwise dead. During POST the heads are driven off track 0 and back within a fixed window. A sticking head carriage, a dirty track-0 photo-sensor or a detached head damper misses it and the drive is dropped from the configuration. ALPS drives lose the damper pad glued to the head assembly and have a much higher error rate than the Mitsubishi drives; the Mitsubishi 355 collects dirt around the read/write head actuator spindle.[10][7]
- Speed or timing complaints blamed on a belt. There is no belt. Mitsubishi's own specification for the MF355C states a DC brushless direct-drive motor coupled straight to the spindle at 300 rpm.[13]
- Dirt on the planar's diskette controller. The controller sits directly under the power-supply fan, collects dirt and leaks current between pins, producing 6xx errors that look exactly like a dead drive. Clean that area before condemning a drive.[10]
Fixed Disk Subsystem
The Model 80's fixed disks are conventional ST-506, ESDI or SCSI units on a separate adapter card, not the integrated drive-plus-controller assemblies used in the desktops. No capacitor list has been published for the drives or for the adapters.[14][3]
Check the obvious before suspecting electronics:
- 1780 on an 8580-041 — IBM's own retain tip, record H064300, says to verify that the fixed disk cables are installed properly. Cable orientation is the documented first cause of this code on this machine.[7]
- A 314 MB drive on a -311 that will not come ready is covered by IBM ECA 040, which attributes it to a fault in the drive logic board.[15]
- A drive that will not spin up after long storage — stiction. Unplug the unit, shake it vertically, then rotate it sharply a few times and try again. Whatever frees it, back up immediately.[16]
- 104xx codes. 010455 and 010456 are controller errors, 010462 a controller seek error, 010464 a drive read error and 010454 a sector-buffer test error.[17]
The code often quoted alongside 10455 as an "ESDI controller error" — 10463 — does not exist in IBM's code tables. The range runs 010462, then 010464.[17]
Memory Cards
The 8580's planar memory sits on IBM's own memory cards in two connectors on the board, and no capacitor data has been published for them.[18] Memory errors here are far more often a card, a seating or an ECA problem than a capacitor problem:
- 00011000 is a system-board parity check: remove the card in J15 or J8; if the problem goes, replace that card, otherwise try the one in J16 or J9.[15]
- 00021500 indicts the card in J15 or J8; 00021600 and 00022100 the card in J16 or J9.[15]
- Intermittent 110 during POST, diagnostics or applications — IBM retain tip H006554 notes that Advanced Diagnostics loads into the first 256 KB and therefore cannot stress-test it. Swap the two cards and re-run the memory test.[15]
- OS/2 Trap 0002 or NMI on a 25 MHz machine with 8 MB fitted — ECA 051. Examine the modules at U24 and U34 near J8 and J9; if they are marked FCT841 the board qualifies for replacement. Any other marking is good, and anything printed on the board near the module should be ignored.[19]
After Working on the Machine
- Bench-test the supply on its own, under load, against IBM's service limits.
- Refit and start from the Reference Diskette, with the diskette in the drive at power-on.[17]
- Run Automatic Configuration if any adapter changed, then Advanced Diagnostics (Ctrl-A).
- Check that the power light comes on — it is driven by Power Good.[4]
- Run a surface scan if you worked on the fixed-disk subsystem, and format and verify a diskette if you worked on the drive.
- Leave a long memory test running.
If a fault appears immediately after a recap, check the polarity of every part you fitted before suspecting anything else.
When Not to Recap
A Model 80 that starts reliably, POSTs clean, holds its configuration and reads and writes diskettes does not need its planar touched — there is nothing on it to recap.
Do act if you see:
- Fluid, crust or crystalline residue near a capacitor on a drive or supply board, or discoloured, grey or rough solder at its pads.[12]
- A rail outside IBM's service limits under load.
- The power light staying off, or the supply latching off and needing the switch cycled.
- Diskette read/write failures or 6xx errors on a mechanically sound drive.
- A supply that whines, chirps, smells, or will not start when warm.
- A decoupling capacitor confirmed shorted out of circuit.
Related Pages
- IBM PS/2 Model 80
- IBM PS/2 Model 80 Maintenance Guide
- IBM PS/2 Model 80 Troubleshooting Guide
- IBM PS/2 Model 60 Capacitor Replacement Guide — same chassis and same supply family
- IBM PS/2 Model 70 Capacitor Replacement Guide — the desktop sibling, with a different and undocumented supply
- Capacitor Failure Symptoms
- Floppy Drive Repair
- Recommended Tools
- ↑ 1.0 1.1 IBM, IBM Personal System/2 Model 80 386 Technical Reference, October 1990 — hosted on this wiki as File:IBM PS2 Model 80 Technical Reference Oct90.pdf. Section 1: "Physical Specifications", "Power Supply", "Outputs", "Output Protection", "Voltage Sequencing", "Component Maximum Current" and "Channel Load Current".
- ↑ IBM, IBM Personal System/2 Model 80 Schematics — hosted on this wiki as File:IBM PS2 Model 80 Schematics.pdf. Planar-level schematics for the 8580; net-level, without capacitor values in a parts list.
- ↑ 3.0 3.1 IBM, IBM Personal System/2 Hardware Maintenance Manual, S52G-9971-02, October 1994 — hosted on this wiki as File:IBM PS2 HMM S52G-9971 Oct 1994.pdf. Sections "Power Supply Voltage Check", "System-Unit Power Supplies", "Numeric Error Codes" and the Model 50/70 and Model 60/65/80 parts catalogues. Note that the printed Models 50/70 voltage table on page 141 repeats each rail's maximum in the minimum column; the facing 60/65/80 table and ardent-tool's transcription of the same IBM table give the correct minima, which are the figures used here.
- ↑ 4.0 4.1 4.2 4.3 Eric Schlaepfer ("Tube Time"), IBM PS/2 225 W Power Supply 72X6665 — reverse-engineered schematic, 2024, CC BY-SA 4.0 — hosted on this wiki as File:IBM PS2 225W Power Supply 72X6665 Reverse-Engineered Schematic (Tube Time 2024).pdf. Drawn from a physical 72X6665 / PEC 3978 unit; the only component-level reference published for this supply. IBM did not publish capacitor values for any PS/2 power supply.
- ↑ 8580 Type 1 Planar, Ardent Tool of Capitalism. Component-designator map for the 16 MHz planar (FRU 33F8416): J1/J2/J4 32-bit Micro Channel slots with Matched Memory Extension, J3/J5/J7/J8 16-bit slots, J6 16-bit slot with auxiliary video extension, J15 and J16 memory-expansion connectors, J18 battery/speaker connector, U72 72X8287ESD VGA controller with eight OKI M41464-12 64 K × 4 video DRAMs, U187 Motorola MC146818A RTC and U186 2 K × 8 configuration SRAM.
- ↑ 6.0 6.1 8580 Type 2 Planar, Ardent Tool of Capitalism. Component-designator map for the 20 MHz planar (FRU 33F8506 / 92F0756 / 92F0767, P/N 90X7390): the same slot arrangement as the Type 1, J15 and J16 memory-expansion connectors, J18 battery/speaker connector, U87 72X8287 VGA with eight TI TMS4464FML-12 video DRAMs, U131 Intel 386DX-20, U186 MC146818A RTC and U146 configuration SRAM. Also links IBM's Model 80 planar schematics.
- ↑ 7.0 7.1 7.2 7.3 7.4 7.5 60, 65 SX, and 80 — Common Devices, Ardent Tool of Capitalism. Source for the side-cover and front-bezel removal procedures, the locked-case workaround, IBM retain tip H064300 (1780 on the -041 machines), the dust-under-the-fan cause of lost configuration and disk errors with the list of affected ICs, IBM retain tip H024809 on checking the battery for a minimum of 5.5 V DC, the Mitsubishi/ALPS diskette-drive comparison and "killer caps", Alan Douglas's capacitor-replacement notes, and the on-board VGA capabilities and the multiple-VGA-driver warning.
- ↑ 8.0 8.1 8.2 8.3 60, 65 SX, and 80 — Power Supply, Ardent Tool of Capitalism. Secondary source reproducing IBM's 15-pin planar power-connector pinout and service test-voltage table for the 8560/8565/8580, the observed supply variants with their FRU numbers and output ratings, the removal procedure, Peter Wendt's note on the high failure rate of the power switch, and Fred Spencer's fixed-disk power-consumption figures.
- ↑ 9.0 9.1 9.2 Repair of PS/2 8580 Power Supply, Ardent Tool of Capitalism, created by Al Savage. Documents a Schrack EP071063-A 225 W unit (P/N 90X9109, FRU P/N 15F6551, EC A79369) failing with a chirp, traced to a shorted 3300 µF / 16 V output filter capacitor — one of an identical pair — plus a cold solder joint. Notes that the same IBM part numbers also appear on an Italian Plessey unit whose case halves are riveted rather than screwed, and that the case screws are security Torx.
- ↑ 10.0 10.1 10.2 10.3 10.4 8580 Diskette Drives, Ardent Tool of Capitalism, content by Fred Spencer and Al Savage. Source for the PS/2 diskette-drive part numbers (P/N 90X6766, FRU 72X8523 card-edge; FRU 64F0162 pin-interface), for Al Savage's teardown of a Mitsubishi MF355W-99M3 identifying five failed surface-mount electrolytics — two 22 µF/16 V, one 1 µF/50 V and two 0.22 µF/50 V — for the diskette-controller dirt problem under the power-supply fan, and for Peter Wendt's list of mechanical causes of a 162 at POST.
- ↑ 11.0 11.1 PS/2 Surface Mount Capacitors, ibmfiles.com. Community teardown source; documents surface-mount electrolytic failure and pad corrosion on PS/2 Mitsubishi diskette drives and on the DBA hard-drive logic boards, and the technique of fitting through-hole parts to the surface-mount pads.
- ↑ 12.0 12.1 8573 P75 Failing Capacitors, Ardent Tool of Capitalism. Jim Shorney and Peter Wendt on the behaviour of leaking PS/2 surface-mount electrolytics: discoloured, grey or rough solder joints beside the can, joints that will not reflow because electrolyte has contaminated them, and legs that pull free before the solder melts.
- ↑ Mitsubishi Electric, 3.5-inch Diskette Drive MF355C Specifications, UGD-0527A, February 1987 — hosted on this wiki as File:Mitsubishi MF355C 3.5 inch Diskette Drive Specifications (UGD-0527A, Feb 1987).pdf. The drive uses a DC brushless, direct-drive motor coupled straight to the spindle at 300 rpm. There is no belt in this drive.
- ↑ IBM product information document GJAN-43WKBR, "IBM PS/2 (Model 80) — Technical specifications", mirrored at ardent-tool.com. IBM's own summary: announce date 2 April 1987; 16 MHz (041, 071), 20 MHz (1xx), 25 MHz (Axx); 3 32-bit slots on the 0xx/1xx and 4 on the Axx; 1–4 MB on the system board in two sockets, expandable to 16 MB with memory options; cache 0 KB except 64 KB on the Axx; 225 W (242 W on the Axx); drive bays 4 × 3.5-inch half-height plus 1 × 5.25-inch full height; and the interface and access time of every fixed disk offered.
- ↑ 15.0 15.1 15.2 15.3 8580 Common Devices, Ardent Tool of Capitalism. Source for Fred Spencer's submodel table (processor speed, disk interface and capacity, and the 32-bit/16-bit/AVE slot split for every 8580), IBM retain tip H104756 on draining CMOS by grounding the configuration modules, the memory-error codes and memory activation/deactivation behaviour, Peter Wendt's summary of Model 80 ECAs 008, 011, 031, 035, 040, 048, 051 and 069, retain tip H006554 on intermittent 110 parity errors, the 64 MB configuration limit, and retain tip H021673 on the two non-interchangeable base frame assemblies.
- ↑ Known Problems — Experience, RETAIN Tips, ECAs, Ardent Tool of Capitalism. Source for Peter Wendt's account of hard-disk stiction and the recovery options.
- ↑ 17.0 17.1 17.2 PS/2 Error Codes and the linked code tables 160–199, 300–999 and 10000–11999, Ardent Tool of Capitalism. Secondary source; the tables reproduce IBM's own symptom-to-FRU lists.
- ↑ 8580 Planar Memory, Ardent Tool of Capitalism. Catalogue of the IBM planar memory cards used in the 8580's two on-board memory-expansion connectors, with part numbers, DRAM complements and the connector pinout. These cards are specific to the Model 80 and are not 72-pin SIMMs.
- ↑ 8580 Type 3 Planar, Ardent Tool of Capitalism. Component-designator map for the 25 MHz planar (FRU 34F0022 / 85F0046): J10–J13 32-bit slots with Matched Memory Extension, J6/J7 16-bit slots with auxiliary video extension, J14/J15 16-bit slots, J8 and J9 memory-expansion connectors, J19 battery/speaker connector, F2/F3/F4 1 A, 1.5 A and 2.0 A fuses, U54 Intel 82385-25 cache controller with eight Mitsubishi M5M5178P-33 8 K × 8 SRAMs, U96 80386DX-25 and U132 MC146818AFN RTC. Also carries the full text of IBM ECA 051.
