IBM PCjr Capacitor Replacement Guide
This guide documents the procedure for diagnosing and replacing capacitors on the IBM PCjr (4860) motherboard, sidecars, and the external AC power brick.
The PCjr uses the same family of 10 µF / 16 V tantalum filter capacitors as the rest of the IBM 51xx range. Tantalums on the PCjr motherboard are less numerous than on the 5170 (the PCjr has fewer rails) but they fail in the same modes: short circuit (most common, pulls the external brick into fold-back) and open circuit (less common, no immediate symptom).
This guide does not enumerate each tantalum's reference designator on the PCjr motherboard, because IBM did not publish a unified silkscreen reference and surviving PCjr boards show different revisions of the silkscreen. Treat every orange/yellow bead tantalum as a candidate for inspection if the PCjr will not start.
Failure Mode
Tantalum capacitors on the PCjr are commonly marked "106 16V" or "10µF 16V" (10 µF, 16 V working voltage). They are polarised. They fail in two modes:
  • Open circuit — filtering is lost; the rail is still nominally correct, but decoupling is degraded. The system may still boot but may be sensitive to noise from sidecars.
  • Short circuit — the cap pulls its rail down. With the PCjr's external brick, this causes the brick to enter fold-back protection (the brick clicks off, the LED on the system unit goes out, the brick rests, then tries again in a cycle). Severe shorts can damage the brick.
The PCjr also uses aluminium electrolytic capacitors in the AC power brick. These dry out over decades; symptoms include reduced or unstable DC output, ripple on the system unit's rails, and the brick failing to start when warm.
Diagnostic Procedure (motherboard)
If the PCjr will not start (no audio at power-on, no fan because there is no fan, no system unit LED on the front of the case):
  1. Disconnect the external AC brick.
  2. Open the system unit and remove all sidecars and both cartridges.
  3. Visually inspect each tantalum on the motherboard for damage (cracked body, black spot, ruptured top). Most failed tantalums show no visible damage.
  4. With a multimeter on the diode test or 200 Ω range, probe across each tantalum in-circuit (negative probe to GND, positive probe to the +5 V or +12 V side). A good tantalum reads open or high resistance after a brief charge. A failed (shorted) tantalum reads close to 0 Ω.
  5. Where a short is found, remove the capacitor to confirm. Other components on the same rail can give a false-short reading.
If no tantalum on the motherboard is shorted, inspect each fitted sidecar individually: each sidecar has its own filter caps on its connector. A shorted cap on a sidecar will pull the system rails down even with the motherboard healthy.
Removal and Replacement (motherboard or sidecar)
  1. Mark the polarity of the failed cap on the board with a paint pen or photograph.
  2. Apply fresh solder + flux to both pads to wet them.
  3. Heat one pad, gently lever the cap up on that side. Heat the other pad and lift the cap clear.
  4. Clean the holes with solder wick.
  5. Insert the new cap with correct polarity (the + marking on the cap matches the + on the silkscreen).
  6. Solder both legs from the underside. Inspect for a clean fillet.
  7. Trim the legs flush.
Modern 10 µF / 16 V tantalum replacements are the like-for-like fit. Two-legged radial parts work in every PCjr footprint. As an alternative, 10 µF / 25 V low-ESR ceramics (X5R or X7R) work as drop-ins for filtering duty.
Polarity reference for IBM 51xx motherboard tantalum capacitors. The same convention applies to the PCjr motherboard. (Image: minuszerodegrees.net)
A failed tantalum often shows no visible damage. Do not rely on visual inspection.
A failed tantalum capacitor on an IBM 51xx motherboard. The small black hole on the body is the only visual indication of failure — in most cases there is no visual sign at all. (Image: minuszerodegrees.net)
AC Power Brick Recap
The PCjr's external AC brick contains a mains rectifier, a switching regulator, and a small number of secondary-side aluminium electrolytic capacitors. After thirty years many bricks supply marginal DC under load.
Warning: The brick's primary side carries mains voltage and the bulk capacitor can hold a lethal charge after the brick is unplugged. Always discharge the bulk capacitor through a current-limited resistor (1 kΩ / 5 W to ground) before working on the primary side.
Procedure:
  1. Unplug the brick from the wall and from the system unit.
  2. Wait at least 30 seconds for the bulk capacitor to bleed through the internal resistor; verify with a multimeter on the bulk capacitor terminals.
  3. Open the brick. Many IBM bricks are ultrasonically welded; cut the seam carefully and plan to glue or screw it back together.
  4. Identify the secondary-side electrolytics (the larger caps closer to the DC output connector). Replace each with a new low-ESR aluminium electrolytic of equal capacitance, equal or higher voltage, and equal or higher temperature rating (105 °C preferred over 85 °C).
  5. If the primary-side line suppression cap (X2 class) shows any cracking, bulging or fluid leakage, replace it with a new X2 cap of equal capacitance and voltage class.
  6. Reassemble the brick. Verify DC output with a multimeter under no load and then under a 1 A resistive dummy load.
  7. Re-test with the system unit.
Sidecar Capacitors
Each PCjr sidecar contains its own filter capacitors on the inlet from the system unit's sidecar bus. These are the same 10 µF / 16 V tantalums as on the motherboard. A shorted cap on a sidecar produces the same symptom as a shorted cap on the motherboard: the brick goes into fold-back and the system will not start.
To diagnose, remove all sidecars and re-add them one at a time. The faulty sidecar is the one that reintroduces the power-up failure.
Post-Recap Verification
  • With the system unit closed and the AC brick fitted, the system should power up to the IBM logo / BIOS POST and emit a single short beep.
  • If the system POSTs but a fitted sidecar still drops it, re-inspect that sidecar's caps.
  • If the system POSTs and runs but the IBM 4863 display shows ripple or noise, the brick electrolytics may still need replacement.
  • Commonly Failing Electronic Components, minuszerodegrees.net. Reference for tantalum and electrolytic failure modes on IBM 51xx hardware.
  • IBM, IBM PCjr Technical Reference. Reference for motherboard chip layout, sidecar pinout and power requirements.
  • IBM PCjr Hardware, Mike Brutman. Reference for sidecar power behaviour.
