Grandstand Tron General Maintenance
Tomytronic TRON (1981) VFD LSI Game
Tomy's own Tomytronic Tron. Grandstand's version has "GRANDSTAND" in place of "TOMYTRONIC" on the bezel; the smoked case, the controls and the "TOMY" moulding on the front of the base are the same (Jeff Keyzer; CC BY-SA 2.0).
Care and cleaning of the Grandstand Tron, Tomy's Tomytronic Tron tabletop game with a vacuum fluorescent display (VFD), which Grandstand distributed in the UK under code no. 11266.[1][2] No service manual has been published, and no teardown, board photograph or repair account of a Tron of any brand has been found. What follows rests on Tomy's instruction leaflet, the MAME driver notes, the Handheld Museum's records, and two owners' videos: one cleaning a Tomytronic Tron, the other describing one whose battery terminals had corroded. Fault-finding is on Grandstand Tron Troubleshooting Guide. No capacitor values have been published, so there is no capacitor guide for this game.
What is known about the hardware
Tron construction, as far as it has been recorded
Part Detail Source
Case Smoked clear plastic throughout, so the inside can be seen; large imitation circuitry at the back is part of the styling Handheld Museum, video[2][3]
Main board Marked THN-02 2E114E07 MAME[4]
Microcontroller Hitachi HD38800A88 (HMCS40 family); the program is inside it MAME[4]
Display NEC FIP10AM24T no. 2-8 1, cyan, red and green; ten grids MAME[4][5]
Controls CONTROL disc (right, up, left, down), ON/OFF slide switch, SPEED/SHOOT button Tomy leaflet[6]
Power Four C alkaline cells under a lift-up cover in the base, or an adaptor through a socket in the case Tomy leaflet, videos[6][3][7]
Tron is the only one of the three Tomy tabletops Grandstand sold that uses a Hitachi microcontroller; Grandstand Munchman and Grandstand Caveman use NEC chips.[4][5] Nothing published shows whether its display supply resembles theirs, so do not carry their part numbers over to Tron.
Batteries and contacts
Tomy Tron Instructions battery compartment drawing
"Illustration 1" from Tomy's Tron leaflet: lift the cover under the base and fit four C cells in two rows.
  • Switch off, turn the game over and lift the battery cover. Fit four C alkaline cells as the moulding shows.[6] On the unit cleaned by GenXGrownUp the cover carries a printed instruction label.[3]
  • Leaking cells are the one Tron-specific fault on record. Keeper1st left cells in a Tomytronic Tron for over twenty years; they swelled and leaked, and corroded the battery terminals so badly that the game could no longer run from batteries, only from an adaptor.[7]
  • Clean corroded terminals back to bright metal, and replace any that have lost their plating or broken. Neutralise residue as described on Battery Explosion, Capacitor or Corrosion Damage.
  • Tomy's care notes: turn the game off after use, take the cells out before storing it, and never leave dead cells in it.[6]
The DC socket and adaptors
  • Tomy's leaflet recommends the Archer 270-1551 A or Recoton AD-10UL adaptor and gives the requirement as 7.5 V DC, 200 mA, 2.1 mm coaxial plug, tip (centre) negative.[6] Measure any adaptor before use: centre negative is the reverse of most modern adaptors.
  • Four C cells give 6 V, so Tomy's adaptor rating is higher than the battery voltage.[6]
  • No Grandstand leaflet for Tron has been found to give a setting for the Grandstand Universal Mains Adaptor.[1]
  • The wrong adaptor is the commonest cause of damage to VFD tabletop games in general, usually a blown transistor.[8]
Opening the case
No account of opening a Tron has been published, so screw positions, clips and cable runs are not recorded here. Tomy's leaflet says not to take the game apart.[6] If it must be opened:
  • Because the case is smoked clear plastic, look through it first for the screw posts, the board, the display and the wires before undoing anything.[2]
  • Take the cells out and photograph each stage.
  • The display is a glass vacuum tube; handle it by its ends and do not lever against it. A cracked tube cannot be repaired.[9]
  • No photograph of the THN-02 board has been found; photographs of an opened Tron are the largest gap in what is known about this game.
Controls
  • The CONTROL disc covers four direction contacts and SPEED/SHOOT is a single large button.[6][4] No account of cleaning their contacts has been published; if a direction fails, the contacts under the disc are the first place to look once the case is open.
  • GenXGrownUp cleaned the control panel and the case seams with a cleaning putty, without opening the game.[3]
Case and window
  • The smoked plastic shows every scratch and smear. GenXGrownUp removed old sticker residue from the rear of the case with Goo Gone (the "Surface Safe" formula) and a microfibre cloth.[3] Try any cleaner on a hidden area first; solvents can craze clear plastic.
  • The imitation circuitry visible at the back is decoration, not a board.[2]
Display
  • The FIP10AM24T shows cyan, red and green.[4] MAME's notes on these tubes record that the colours fade after decades.[5]
Tomy's care list: no excessive heat or cold (the leaflet's examples are a car glove compartment on a hot day and a heater vent), keep it dry and clean, do not shake or drop it, switch it off when not in use and take the batteries out before storing it.[6]
Maintenance checklist
  1. Cells out; inspect the battery box for leakage.
  2. Clean the battery terminals; test on fresh alkaline C cells.
  3. Test on a measured 6-7.5 V, centre-negative supply.
  4. Clean around the controls without letting liquid in.
  5. Clean the smoked case gently; test cleaners first.
  6. Store with the cells out.
  1. ↑ 1.0 1.1 Handheld Museum, "Grandstand Tron" (retrieved 2026-10-18): 1981, VFD, four C batteries, model 11266; "Grandstand was the distributer for Tomy's Tron in the U.K."; photographs of the Grandstand-branded game, with "GRANDSTAND TRON" on the bezel and "TOMY" on the front of the base, and of its box ("Code No. 11266", Tomy, "Three electronic games in one").
  2. ↑ 2.0 2.1 2.2 2.3 Handheld Museum, "Tomy Tron" (retrieved 2026-10-18): 1981, VFD, four C batteries, model 7601; "the entire case is made of a smoked clear plastic so you can see the inside of the game (and it has some large, simulated circuitry in the back...)"; released by Grandstand in the UK.
  3. ↑ 3.0 3.1 3.2 3.3 3.4 GenXGrownUp, "1981 Tron Handheld from Tomytronic in LIKE-NEW CONDITION!", YouTube, 29 June 2023, 8:58 (watched 2026-10-18; no transcript available; chapters "Hardware Tour" 1:31, "Original Manual" 3:06, "Clean-Up" 3:58, "Power On!" 5:33). Shown: the smoked case, with imitation circuit patterns visible through the rear of the hood; the battery cover on the underside carrying a printed instruction label, and the empty battery box with contacts for four C cells in two rows; the panel and case seams cleaned with a cleaning putty; sticker residue on the smoked rear removed with Goo Gone and a microfibre cloth; the game powered on with fresh C cells.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 MAME source, hh_hmcs40.cpp (retrieved 2026-10-18). Driver notes for Tomy Tron: made in Japan; PCB label THN-02 2E114E07; Hitachi HD38800A88 microcontroller, 1-bit sound; cyan/red/green VFD NEC FIP10AM24T no. 2-8 1. The chip list dates the HD38800A88 to 1982 and lists it for Tomy Tron (THN-02) only. Inputs: four directions read through a multiplexed interrupt, and one button; the machine configuration clocks the chip at 400 kHz, marked in the source as an approximation.
  5. ↑ 5.0 5.1 5.2 MAME source, hh_ucom4.cpp (retrieved 2026-10-18), file header on VFD games: NEC FIP part numbers give the number of grids after "FIP"; "after decades passed, all the colors fade". Also the driver notes for Tomy Pac-Man (NEC uCOM-43, D553C 160) and Tomy Caveman (NEC uCOM-43, D553C 209, PCB TN-12 2E114E03).
  6. ↑ 6.0 6.1 6.2 6.3 6.4 6.5 6.6 6.7 6.8 Tomy Corporation, Tomytronic Tron instructions, no. 7601, copyright 1982 Tomy Corp., Carson, California, and MCMLXXXI (1981) Walt Disney Productions; printed in Japan. Hosted here as File:Tomy Tron Instructions.pdf. Page 2: "Illustration 1", the battery cover lifted on the underside with four C cells in two rows; "Set the On/Off switch to the Off position. Turn the game over and lift the battery cover ... Insert four 'C' size Alkaline batteries"; recommended AC adapters Archer cat. no. 270-1551 A and Recoton AD-10UL; adapter requirements 7.5 V DC 200 mA, 2.1 mm ID coaxial plug, tip (centre) polarity negative; "Illustration 2", the CONTROL button (right, up, left, down), the ON/OFF switch and the SPEED/SHOOT button; at switch-on "a pattern will move across the screen and a fanfare will sound", then the first screen shows four Tron figures, four Sark figures, three red and green enemy light cycles, the MCP and a score of 0. Pages 3-5: the Light Cycle, Ring and MCP games; the skill level rises after all three are completed, up to six times. Page 6: scores above 1,995 shown as green bars, maximum 15,995 then back to 0; an extra Tron at 2,000 points, at most five; care: no excessive heat or cold, avoid wet or dirt, "Don't take it apart", don't shake or drop, turn off and remove the batteries for storage, no dead batteries left in; "If the batteries become weak the display screen will become dark and show incorrect action".
  7. ↑ 7.0 7.1 Keeper1st, "TRON hand-held electronic game (Tomytronic, 1982)", YouTube, 19 December 2010 (video description, retrieved 2026-10-18): "I had left the batteries in it. The batteries since had expanded and leaked, making a big mess and corroding the battery terminals to the point where batteries cannot power the game anymore. But thankfully it has a jack for an external power supply!"
  8. ↑ Handheld Museum forum, "Astro wars / galaxy ii repair", December 2018 - February 2019 (retrieved 2026-10-18). The site administrator (Rik), writing about VFD tabletop games in general: the wrong AC adapter "will usually fry" a transistor, "the most frequent damage I've seen to VFD games"; keep rubber buttons, springs and speakers from scrapped games as spares.
  9. ↑ Handheld Museum forum, "EPOCH Astro Command - dead or dying", January-February 2016 (retrieved 2026-10-18). The site administrator (Rik), writing about VFD tabletop games in general: the games play and make their sounds without the display; displays fade unevenly with heavy use; he has never had a display fail unless the glass was broken.
