IBM PC (5150)
Revision as of 10:25, 21 May 2026 by Josh (talk | contribs) (Rewrite with verified information only โ€” remove fabricated part numbers (CGA 1501486, MDA 1501481, FDD Adapter 1501507, Fixed Disk Adapter 6181682, Model F dimensions/weight), remove placeholder image filenames, replace speculative capacitor designator table with verified minuszerodegrees.net source data (all tantalums marked C7, 10ยตF/16V), fix 5150 dimensions/weight to 20x16x5.5 inches / 21-28 lbs, fix Model F dimensions/weight to 19x9x1.5in / 7lb4oz / 3.3kg. Per Joshua's feedback: never pub...)
IBM Personal Computer
IBM 5150 Personal Computer with 5151 monochrome display and Model F keyboard
ManufacturerIBM
TypeDesktop personal computer
ReleasedAugust 12, 1981
DiscontinuedApril 2, 1987
Intro priceUS$1,565 (base, 16 KB, no FDD); typical home/school system around US$3,000
CPUIntel 8088 @ 4.77 MHz
Optional Intel 8087 FPU
MemoryEarly board: 16-64 KB on-board
Later board: 64-256 KB on-board
Expandable to 640 KB via ISA RAM cards
StorageCassette port; one or two 5.25" floppy drives (TM100-1 single-sided 160 KB; TM100-2 double-sided 320/360 KB)
DisplayMDA + IBM 5151 monochrome display, or CGA + IBM 5153 colour display (separate adapter card)
SoundInternal PC speaker, driven by Intel 8253-5 timer channel 2
Dimensions20" W ร— 16" D ร— 5.5" H
Weight21 lb (no FDD); 25 lb (one FDD); 28 lb (two FDDs)
OS / FirmwareIBM PC DOS 1.0 through PC DOS 3.3; CP/M-86; UCSD p-System; IBM Cassette BASIC in ROM
SuccessorIBM PC XT (5160)
CodenameAcorn (development project name)
Model no.5150
The IBM Personal Computer (model 5150) is the original IBM PC, announced on August 12, 1981 and shipped from September 1981 through April 2, 1987. It was developed in roughly one year by a team in Boca Raton, Florida under Don Estridge and William C. Lowe, using off-the-shelf parts to bring an IBM-branded microcomputer to market quickly. The architecture it established โ€” Intel 8088 CPU, 8-bit ISA expansion bus, MS-DOS, an open BIOS interface, and Microsoft Disk BASIC in ROM โ€” became the standard for personal computers for the following two decades.
The 5150 uses an Intel 8088 running at 4.77 MHz, a 16-bit CPU with an 8-bit external data bus. A second socket on the motherboard accepts an Intel 8087 floating-point coprocessor, sold separately.
The CPU is supported by the IBM 8088-family chipset:
  • Intel 8259A โ€” programmable interrupt controller.
  • Intel 8237A-5 โ€” DMA controller, also responsible for DRAM refresh.
  • Intel 8253-5 โ€” programmable interval timer (system tick, refresh trigger, speaker).
  • Intel 8255A-5 โ€” programmable peripheral interface (keyboard input, DIP-switch readback, speaker enable).
  • Motorola MC6845 โ€” CRT controller, on the MDA and CGA display adapters, not on the motherboard.
Memory and ROM
Two motherboard revisions exist, distinguished by the amount of on-board RAM they accept and clearly marked in the silkscreen near the keyboard port.
IBM 5150 motherboard revisions
Silkscreen marking On-board RAM RAM chip type Banks
16KB-64KB (early) 16 KB – 64 KB 4116 (16 Kbit, requires −5 V) 4 ร— 16 KB
64KB-256KB (later) 64 KB – 256 KB 4164 (64 Kbit) 4 ร— 64 KB
The motherboard carries ROM in five sockets:
There are four documented BIOS revisions, all dated rather than numbered (date format MM/DD/YY):
IBM 5150 BIOS revisions
Date IBM part number Compatible board Notes
04/24/81 5700051 16KB-64KB only Recognises only 544 KB total RAM; ignores BIOS expansion ROMs (no EGA/VGA, no HDD)
10/19/81 5700671 16KB-64KB only Same two limitations as 04/24/81
08/16/82 5000024 (rare/possibly unreleased) Has a bug where EGA / 5150-compatible VGA fail if SW1 video bits are set ON-ON
10/27/82 1501476 16KB-64KB or 64KB-256KB Removes the 1981 BIOS limits; bug: a corrupted HDD expansion ROM at C8000 beeps "1 long + 2 short" instead of displaying "C800 ROM"
System configuration is set by two banks of DIP switches (SW1 and SW2) on the motherboard. The 5150 has no battery-backed CMOS — the DIP switches are read at every power-up.
Storage and Expansion
  • Cassette port (5-pin DIN, rear panel) for tape data, paired with the IBM Cassette BASIC ROM.
  • Floppy disk drive โ€” one or two half-height 5.25" drives: Tandon TM100-1 single-sided (160 KB at PC DOS 1.0; 180 KB at PC DOS 2.0+) on the earliest 5150s, then Tandon TM100-2 / TM100-2A or Micropolis 1015-5 double-sided (320 KB at PC DOS 1.1; 360 KB at PC DOS 2.0+). Drives connect to an IBM FDD Adapter ISA card; the motherboard has no on-board floppy controller.
  • No internal hard drive support from the original 63.5 W Type 1 PSU. The later 130 W Type 2 PSU made it possible to fit an MFM hard drive on an IBM Fixed Disk Adapter.
  • 5 ร— 8-bit ISA slots.
Display
The 5150 has no on-board video. All video is provided by an ISA adapter card driving a separate monitor:
Keyboard
The 5150 ships with the IBM Model F (83-key) XT-layout keyboard โ€” the original capacitive buckling-spring keyboard. It connects to the rear of the case via a 5-pin DIN connector. Unlike later AT-class machines, the 5150 has no keyboard controller IC on the motherboard โ€” the keyboard interface is read by the 8255 PPI.
Power Supply
Two PSU revisions exist:
  • Type 1 โ€” 63.5 W, sufficient for the base configuration of motherboard + floppy drive(s).
  • Type 2 โ€” 130 W, introduced to support an internal hard drive.
Both produce +5 V, +12 V, −5 V, −12 V on the motherboard's P8/P9 connectors. The −5 V rail is required by the 4116 DRAM on the early 16KB-64KB board, and by the cassette circuitry on the later 64KB-256KB board.
Cleaning procedures, PSU voltage checks, and preventive care are documented in IBM PC (5150) Maintenance Guide.
The 5150 uses tantalum capacitors on the motherboard and ISA cards. Short-circuit tantalum failure is one of the most common faults on this machine. Procedures and the verified motherboard capacitor information are at IBM PC (5150) Capacitor Replacement Guide.
POST beep codes, parity errors, RAM bank 0 failure, keyboard 301 errors, and PSU diagnostics are at IBM PC (5150) Troubleshooting Guide.
