Grandstand Astro Wars Capacitor Replacement Guide
The capacitors on the main board of the Grandstand Astro Wars and Epoch's identical Galaxy II.[1] No manufacturer's parts list exists as far as can be found. The values below come from a parts list compiled by an owner, bobmoo79, from his own board in 2018, checked against repairers' videos and against photographs of opened boards. Voltage ratings are given only where a repairer read them off the part or a photograph shows them.[2]
Is a recap needed?
[edit | edit source]Usually not. In the documented repairs the faults were the power transistor S02, the diode S06 or the driver transistor S03, not the capacitors:
- bobmoo79, codify and Retro Tech Repair each replaced every electrolytic while chasing a fault, and none of those recaps changed the fault.[3][4][5]
- retro_restos and PghGameFix found the electrolytics good on an ESR meter, including a crusty-looking one, and left them in.[6][7]
- Two repairers found a failed 330 μF 10 V capacitor: one blown on the +6 V line of a game that also had a failed power transistor and driver transistor, and one leaking and measuring 126 μF on a game that only came back when the power transistor was replaced.[8][9]
Replace a capacitor that has leaked, bulged or vented, or that measures well out of value, and look at S02, S03 and S06 before blaming the capacitors for a dead game. See Grandstand Astro Wars Troubleshooting Guide and Capacitor Failure Symptoms.
Capacitor list
[edit | edit source]| Ref | Type | Value | Voltage | Where it is | Notes |
| C01 | Electrolytic | 220 μF | Not published | Bottom edge, right of the round TY-33 transformer, beside S07 | Value from the parts list only[2] |
| C02 | Electrolytic | 330 μF | 10 V | Bottom right corner, below C09 and right of S03 | A 330 μF 10 V part failed on two games; one repairer describes his as next to the transformer, so check the printing on your own board[2][8][9] |
| C03 | Electrolytic | 47 μF | 50 V | Bottom left corner, beside ceramic C06 | 47 μF 50 V printed on the part; measured 0.11 Ω ESR on one game[2][7] |
| C04 | Electrolytic | 10 μF | 16 V | Upper right, between the L03 and L04 speaker-wire pads and S08 | Connects S02's emitter to the base of S04; Retro Tech Repair replaced it with a 25 V part[2][3][5] |
| C05, C06 | Ceramic | 47 nF (473Z) | C05 at the top beside the crystal; C06 bottom left beside C03 | [2] | |
| C07 | Ceramic | 2.2 nF (222K) | Below C08, to the right of S02 | [2] | |
| C08, C09 | Ceramic | 1.2 nF (122K) | C08 just below S02; C09 above C02 | [2] | |
| C10, C11 | Ceramic | 470 pF (471K) | Either side of the 400 kHz resonator X01 at the top of the board | [2] |
Positions were read from photographs of opened boards by bobmoo79 (Handheld Museum forum, December 2018), bpharoah (April 2023) and codify (June 2019), which all show the same silkscreen; these photographs are not freely licensed and are not reproduced here.[3][10][4] The C03 rating of 50 V is printed on the part in bpharoah's photograph and was also read out in PghGameFix's video. The C04 rating of 16 V comes from Retro Tech Repair, who read it off the part he replaced. The C02 rating comes from the failed parts described by My Mate VINCE and Philip Bryden.[10][7][5][8][9] No source gives the C01 rating; read it off the part.
The parts list does not cover the control board (96062) or the joystick board, and no capacitors on them are mentioned in any repair.[2]
Replacement procedure
[edit | edit source]- Open the case and lift out the main board as described in Opening the case. The board is held by four screws from the front; the battery wires and DC socket have to be freed to take it right out.[9]
- Note the polarity of each electrolytic before removing it. The board marks "+" beside each one.[3][10]
- Take care round the display. C01 and C03 sit at the lower edge of the board below the glass tube, which must not be bent or levered against.[5]
- The board uses leaded solder; fresh leaded solder or flux makes the old joints easier to clear. Old traces and pads lift easily with too much heat.[11][7][8]
- Fit capacitors of the same value and the same or a higher voltage. Owners have fitted 25 V parts at C02 and C04. Space under the hood is tight, so keep the replacements no larger than the originals.[9][5][8]
- Before refitting the case, power the board from a current-limited 6 V supply and check the current and the temperature of S02 (see below).
Checks after recapping
[edit | edit source]| Check | Expected | Source |
| Supply current at 6 V | About 0.2 A on one repaired game | [5] |
| S02 temperature | A little warm, not hot | [5] |
| Microcontroller supply | About −10 V | [12] |
| Display supply | About −39 V | [12] |
If S02 heats up quickly and the current rises above an ampere, switch off: that is the S06 fault, not a capacitor problem.[3][12]
[edit | edit source]- Grandstand Astro Wars
- Grandstand Astro Wars General Maintenance
- Grandstand Astro Wars Troubleshooting Guide
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ MAME source, hh_ucom4.cpp at commit d404316 (retrieved 2026-10-18). Driver notes for Epoch Galaxy II: PCB labels 19096 and 96062; NEC μPD553C microcontroller labelled D553C 153; cyan and red VFD NEC FIP10xM20T, revisions B (no. 1-8) and D (no. 2-21) with different graphics; released in the UK by Grandstand as Astro Wars. The file header notes that VFD colours fade after decades.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 bobmoo79, Astro Wars parts list (image posted in the Handheld Museum forum thread "Astro wars / galaxy ii repair", 7 December 2018, edited to January 2019; retrieved 2026-10-18). Compiled by the owner from his board: S02 D882 NPN; S03, S04, S05 C2785 NPN; S06, S07, S08 diodes, type not identified; S09 zener 11.5 V; S10 zener 7.5B2 (7.5 V); transformer TY-33; electrolytics C01 220 μF, C02 330 μF, C03 47 μF, C04 10 μF (no voltages given); ceramic C05, C06 47 nF (473Z), C07 2.2 nF (222K), C08, C09 1.2 nF (122K), C10, C11 0.47 nF (471K); resistor packs R01 95k, R02-R04 92k, R05 22k (five 22k resistors, no common pin); R06 333 Ω, R07 620 Ω, R08 2.2k, R09 3.9k, R10 8.2k, R11 1M; X01 400 kHz; display FIP10DM20T; microcontroller D553C-153.
- ↑ 3.0 3.1 3.2 3.3 3.4 Handheld Museum forum, "Astro wars / galaxy ii repair", pages 1-2, December 2018 - February 2019 (retrieved 2026-10-18). Owner bobmoo79's dead white-lettered Astro Wars: the D882 ran very hot, the supply fell to about 1.5 V and the game drew 1.5-1.7 A; a replacement D882, then all new transistors and all new electrolytic capacitors, made no difference; S06 read about 20 Ω both ways; with S06 lifted the μPD553 received its −10 V and ran when the display was fed separately; an S06 taken from a working red-lettered game ("a slightly different PCB revision") cured it. S06 is a glass diode with no printing, its cathode on transformer pin 1; with the good part fitted about 10 mA flows through it at 39 V; 32 V and 39 V zeners overheated. Transformer connections traced: pins 1, 2 and 5 ground, pin 3 +6 V, pin 4 S02 collector, pins 6 and 10 the display filament (display pins 1 and 30). Also a μPD553-to-display pin map credited to kevtris and an out-of-circuit display test (about 3 V on the filament, 12 V on a grid and a segment) whose voltages the owner did not guarantee. Other members: a healthy game should draw "more like 100mA" (blanka); the wrong AC adapter "will usually fry" a transistor, "the most frequent damage I've seen to VFD games" (Rik, site administrator).
- ↑ 4.0 4.1 Andy van Stokkum, "Repairing an Astro Wars", codify.nz, 15 June 2019 (retrieved 2026-10-18), with photographs of the opened game. S02 ran hot and was replaced; the game worked for about a month, then S02 failed again and S03 ran hot; finally replaced S06 (140 V zener; 2 W parts fitted where a 500 mW 1N5275B would do), S03-S05 (2SA1175), S02 (D882) and "all electrolytic capacitors (as labelled)". The adaptor plug is outer-positive and the game has no reverse-polarity diode; he added one. It runs from 5 V but the display is less bright than at 6 V.
- ↑ 5.0 5.1 5.2 5.3 5.4 5.5 5.6 Retro Tech Repair, "Astro Wars Repair (sound but no display or faint display)", YouTube, 29 January 2021 (transcript read 2026-10-18). Faint sound and no display on several games. Measured on a working board: about −1.5 V at the D882 base, −3 V at the base of S03 (a C945), fed from a −9 V line through the zener S09, and the −10 V microcontroller supply (24:00-33:00). A 10 μF capacitor next to the transistor and transformer, rated 16 V, was replaced with a 25 V part, and later the whole board was recapped, without effect (21:00-31:00). Earlier boards, with the Epoch logo, have one diode S06 under the display; later boards have two, S06 and S11, in series (39:00-46:00). The removed diodes broke down at about 140-143 V when tested on a stack of 9 V batteries, which he warns is not safe (48:00-54:00). On a Japanese Astro Wars ruined by the wrong charger, the D882 was burnt; a new D882 still overheated until S06 was replaced with a 1N5275B; the game then drew about 0.2 A with the D882 a little warm, and ran for several hours (57:00-67:00). S06 sits under the bottom edge of the display; bending the tube risks cracking it (61:00). The flat cables to the joystick board and power board broke after repeated handling (39:00).
- ↑ retro_restos, "Astro Wars Repair No Power & Broken Joystick", YouTube, 12 June 2023 (transcript read 2026-10-18). Adaptor: 6 V, negative tip (2:00). About seven screws, the middle one smaller; screws that do not drop out; the base tray is pulled forward to free the case (2:00-4:00). The fire button spring had come out of place; the power switch leaves were cleaned with alcohol and bent slightly (4:00). The batteries run through the DC socket, which disconnects them when a plug is inserted; continuity across the two red wires with no plug in (6:00). Four screws free the display (7:30). The D882 read as a resistor; a new one restored sound and display; the electrolytics tested good on an ESR meter and were left alone (10:00-13:00). Carbon pads cleaned with alcohol, switch cleaner on the joystick (14:00). The three-wire joystick cable had been snapped at the joystick board by an earlier repairer; trimmed and resoldered (18:00-22:00). The display appears to flicker on camera because of the shutter speed, not in real life (18:00, 24:00).
- ↑ 7.0 7.1 7.2 7.3 PghGameFix, "Try To Fix Ep2: Epoch Galaxy II (Grandstand Astro Wars)", YouTube, 12 October 2021 (transcript read 2026-10-18). A water-damaged Galaxy II with rusted contacts: four screws inside the case; wires to be desoldered before the boards come out (8:16-9:33). A crusty electrolytic marked 47 μF 50 V measured 0.11 Ω ESR in circuit, within specification; no other capacitor showed leakage (13:03-15:36). The battery feed is cut by a switch inside the DC socket (33:26). Sound but no display: a cracked glass diode at S10 (marked B1 and apparently 7.5) was replaced with a zener of unknown value from another device and the display returned (34:20-42:20).
- ↑ 8.0 8.1 8.2 8.3 8.4 My Mate VINCE, "1981 Grandstand ASTRO WARS Tabletop Game - No Power Fault - Trying to Fix", YouTube, 10 January 2021 (transcript read 2026-10-18). A previous owner had found a 330 μF 10 V capacitor blown on the +6 V line and replaced it, all the capacitors and the power transistor, but the new transistor kept overheating (0:00-3:00). The DC socket's battery contact did not reconnect the cells: a spring leaf rests on a shelf inside the riveted socket and the plug pushes it away; it was reformed and soldered as a temporary repair (6:00-21:00). Flat-cable joints and lifted pads were repaired with wire (12:00). The small transistor that drives the power transistor's base (marked C945) had a base-collector short; with it replaced the game ran, but the display was too dim to see and the power transistor ran very hot; a different power transistor (a BD139 as a stopgap) made the display bright. He concluded that the original faults were the blown capacitor, the small transistor and the power transistor (24:00-39:00). With a heatsink added to the power transistor, the board "just about fits but it is quite tight" in the case (33:00).
- ↑ 9.0 9.1 9.2 9.3 9.4 Philip Bryden, "Trying to fix a Grandstand Astro Wars (Super Galaxian, Galaxy 2) 1981", YouTube, 19 March 2024 (transcript read 2026-10-18). First game: the DC socket switches the positive battery lead and its dirty contact stopped battery operation; contact cleaner cured it (3:09-5:56); a piezo wire had broken off (6:49); the power switch only worked once the control section was screwed down properly (12:40-15:16). Second game, completely dead and drawing no current: a leaking 330 μF 10 V capacitor next to the transformer measured 126 μF and was replaced with 330 μF 25 V, without curing it (27:04-31:02); three C945 small transistors tested good (36:03-37:49); the NEC D882 had failed and a new one cured it (38:13-41:24). Four screws hold the silver hood and three smaller screws the control section; hold the control panel and pull the hood forward; the board is held by four screws from the front; the battery wires are unsoldered, negative at the top and positive at the bottom (22:00-26:31). Reassembled upside down the piezo falls out, so he taped the buttons in instead (9:04-10:09).
- ↑ 10.0 10.1 10.2 bpharoah, "More Astro Wars!", 24 April 2023 (retrieved 2026-10-18), with photographs. A dead game: 6 V with negative polarity at the DC socket; traced on the red wire to the power switch, bridged with a crocodile clip, and through the control panel cable to the main board; no leaking or bulging capacitors; the D882 power transistor had a base-emitter short; a new transistor cured it.
- ↑ My Mate VINCE, "Dead 1981 Grandstand Astro Wars Game - Repair Video", YouTube, 31 December 2023 (transcript read 2026-10-18). Seven cross-head screws on the underside; the top separates from the bottom with some prying (1:42). Slight corrosion and brown battery leakage under a spring, cleaned with a rotary tool (0:45, 17:01). The red battery wire runs through the DC socket's switch, which cuts the batteries when a plug is in and can stop them reconnecting when dirty (2:51-3:46). He judged the display good because its getter was still black, adding that a cracked tube goes whitish (2:16). The D882 had a 3 Ω short; it and the C945 next to it were replaced and the game worked (7:39-17:47). The board has a conformal coating (16:26).
- ↑ 12.0 12.1 12.2 All About Circuits forum, "Grandstand Astro Wars Game (Faulty) - help with component identification", February 2019 - January 2024 (retrieved 2026-10-18). bobmoo79: the circuit takes 6 V and makes −10 V for the microcontroller and −39 V for the display (measured on a working game); with the failed S06 the D882 (S02) gets very hot, the supply drops to about 2.5 V and the game draws 1.5 A; S06 is an orange glass diode with a red and a brown band (another member's has a single red band). Later posts: one member fixed the same fault with a 1N5275B zener; another fixed a game he had damaged in about 1985 with "the wrong mains brick" by replacing S06.
