Atari 1010
(Redirected from Atari 1010 Program Recorder)
Atari 1010 program recorder
Manufacturer Atari, Inc.; mechanisms by Sanyo (1010S) and Chelco (1010C)
Type Cassette data recorder
Release date Introduced December 1982; shipping from spring 1983[1]
Price US$99 (December 1982)[1]
Interface Atari SIO, two I/O connectors[1]
Compatible Atari 8-bit computers[1]
Predecessor Atari 410 Program Recorder[2]
Successor Atari XC11 and XC12[2]
Power External 9 V AC adaptor[3][1]
Media Compact cassette; data on one track, audio on the other[1]
The Atari 1010 Program Recorder is the cassette data recorder Atari introduced in December 1982 alongside the 1200XL, styled to match the XL computers. It shipped in spring 1983.[1] It stores programs and data at 600 bit/s on ordinary audio cassettes, using one track for data and the other for an audio track that a program can play through the television while it loads.[1]
Versions
Atari built two versions with different mechanisms and boards. Its field service manual calls them the 1010S and the 1010C.[3]
Telling the two 1010 versions apart (FD100223)
1010S 1010C
Mechanism maker Sanyo Chelco
FCC ID prefix (on the base) BPA99H-1010 BPA7YJ-1010
Button order, left to right PAUSE before STOP/EJ STOP/EJ before PAUSE
Sticker inside the cassette bay Orange Silver
Data circuit LA3160 (IC1) and MB3614 (IC2) LM324 quad op-amp (A100) and discrete transistors
The FCC prefixes, button order and data circuits are from Atari's manual;[3] the sticker colours are from Wikipedia;[2] the makers' names are from the FAQ.[1] Owners on AtariAge describe the Sanyo version as Japanese-built and the Chelco version as built in Hong Kong.[4]
  • Data rate: 600 bit/s.[1]
  • Capacity: about 100,000 bytes per 60-minute cassette.[1]
  • Tracks: four-track, two-channel, with digital data on one channel and audio on the other.[1]
  • Data encoding: frequency-shift keying between 3995 Hz and 5327 Hz.[3]
  • Connectors: two SIO I/O connectors, so the recorder can sit anywhere in the daisy chain, and a POWER IN jack for the adaptor.[1][5]
  • Controls: REC, PLAY, REWIND, ADVANCE, STOP/EJ and PAUSE keys, a counter reset button and a power light.[5]
Both versions take 9 V AC from an external adaptor and rectify it with a bridge on the board. On early units the power LED lights as soon as the adaptor is plugged in; on later units it lights only after PLAY, REWIND or ADVANCE is pressed.[3]
The computer starts and stops the tape through the motor control line, SIO pin 8. On the 1010C it drives Q107 and Q108, and a switch on the mechanism closes when PLAY, ADVANCE or REWIND is pressed. The 1010C's data circuit takes its +5 V from the computer.[3]
The 1010S records with maximum current at 5327 Hz; C10 tunes the record/play head to a peak near 5.5 kHz, and the limiter equalises the 3995 Hz and 5327 Hz tones before two envelope detectors and a low-pass output stage turn them into data at 600 baud.[3] In the 1010C, an LM324 limiting amplifier (A100A) feeds two active filters (A100B and A100C), whose rectified outputs drive a comparator (A100D); Q103 then drives the data line to the computer.[3]
Power adaptor
The FAQ lists the 1010's North American adaptor as 9 V AC, 4.5 VA (500 mA), Atari CO61515 or CO61516, and the UK version as 8.5 V AC, 4.25 VA, CO61516/34. The larger 9 V AC adaptors sold with the 400, 800 and 1050 also suit it.[1] Atari's service manual parts lists name C017945, the 31 VA adaptor, for both versions.[3]
Known faults
  • Stretched or perished drive and counter belts.[4]
  • Head out of alignment or worn; many of Atari's flowcharts end in a new head.[3][4]
  • Motor speed drift, set by a trimmer on the 1010S and a screw inside the motor on the 1010C.[3]
  • Loading errors 138 and 143 when the tape leader is read as data.[5]
The fixes are on the Atari 1010 Maintenance Guide and the Atari 1010 Troubleshooting page.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 Michael D. Current (ed.), Atari 8-Bit Computers: Frequently Asked Questions, comp.sys.atari.8bit FAQ, last modified 29 November 2009: section 3.1 (program recorders), section 6.7 (power requirements) and section 11.1 (history, December 1982 to spring 1983, including the US$99 introductory price). faqs.org. Community reference.
  2. ↑ 2.0 2.1 2.2 Wikipedia, "Atari Program Recorder", section "1010". en.wikipedia.org. Used for history and the bay sticker colours.
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 Atari, Inc., 1010 Cassette Recorder Field Service Manual, FD100223 Rev. 02, September 1983. Introduction (p. v); theory of operation (pp. 1-1 to 1-3); testing and troubleshooting (pp. 3-1 to 3-12); diagnostic flowcharts (section 4); symptom checklists (pp. 5-1 and 5-2); parts lists (pp. 6-1 and 6-2). Hosted here as File:Atari 1010 Cassette Recorder Field Service Manual FD100223 Rev 02.pdf.
  4. ↑ 4.0 4.1 4.2 "Atari 1010 belt sizes - drive and counter - anyone?", AtariAge Forums, Atari 8-Bit Computers, thread started by TheRealAnubis, 21 June 2014, replies by russg and mike.2000 (29 November 2018). forums.atariage.com. Community repair report.
  5. ↑ 5.0 5.1 5.2 Atari, Inc., The Atari 1010 Program Recorder Owner's Guide (1982), set-up, controls, loading and saving, and care pages. Hosted here as File:Atari 1010 Program Recorder Owner's Guide.pdf.
