Atari 410
| Atari 410 Program Recorder | |
| A later Atari 410, without the carrying handle | |
| Manufacturer | Atari, Inc.; mechanisms by Bigston, then Transtek or Chelco[1] |
| Type | Cassette data recorder |
| Release date | Introduced January 1979, with the Atari 400 and 800[2] |
| Price | US$85.00 (Sears catalogue, late 1979)[2] |
| Interface | Atari SIO, captive data cord[2][3] |
| Compatible | Atari 400, Atari 800 and later Atari 8-bit computers |
| Successor | Atari 1010[1] |
| Power | Built-in mains supply on most versions; external 6 V DC adaptor on the 410 P[2] |
| Media | Compact cassette; data on one track, audio on the other[2] |
The Atari 410 Program Recorder is the cassette data recorder that Atari introduced with the Atari 400 and Atari 800 at the Winter Consumer Electronics Show in January 1979.[2] It stores programs and data at 600 bit/s on ordinary audio cassettes. One track carries the data and the other an audio track, which a program can play through the television while it runs.[2] The Atari 1010 replaced it in the XL range.[1]
Versions
[edit | edit source]Atari sold several 410s under the same number.
| Version | How to recognise it | Source |
| Original (Bigston mechanism) | Large case with a metal carrying handle that slides out of the front; a modified Sears 799.21672500 recorder | [1] |
| Revised (Transtek or Chelco, Hong Kong) | Smaller, more rounded case, no handle, PAUSE key; the most common version | [1][4] |
| 410a | Taiwan-built version | [2] |
| 410 P | Rare; powered by an external 6 V DC, 300 mA, centre-positive adaptor instead of a mains cord | [2] |
Atari's field service manual describes the Transtek-built recorder; its parts list is headed "Final Assy (Transtek)".[5] A tech tip from February 1983 lists component values that Chelco-built units should be checked for and says the Transtek units already have them.[6]
The revised 410 has a more powerful playback amplifier than the original. Atari's tech tip of November 1982 says it raised background noise on early Atari tapes to the point of causing load errors, and that Atari remastered all its cassette software and replaced its stock from 1 March 1982.[4]
[edit | edit source]- Data rate: 600 bit/s.[2]
- Capacity: about 100,000 bytes per 60-minute cassette.[2]
- Tracks: four-track, two-channel; digital data on one channel, audio on the other.[2]
- Keys: REC, PLAY, REWIND, ADVANCE, STOP/EJ and PAUSE on the revised model, with a counter reset button.[7] The 1979 operator's manual notes that only some machines have PAUSE and that on some STOP and EJECT are separate keys.[3]
- Connection: a data cord fixed to the recorder. The 410 has no second I/O connector, so it must be the last device on the SIO chain.[2]
[edit | edit source]The data and motor circuits are on one board. Figures are from Atari's manual for the Transtek version.[5]
- Playback: the read head feeds a high-gain limiting amplifier (A100D). Two active filters (A100A and A100B) separate the 5327 Hz and 3995 Hz tones, and their rectified outputs drive a comparator (A100C). Q100 then drives the data line to the computer. A100 is an LM324 quad op-amp.[5]
- Head preamplifier and audio: an LM3086N transistor array (A101) amplifies the head signal and the audio track. Its output at A101D pin 11 is Atari's head-alignment test point.[5]
- Motor control: SIO pin 8 comes from Q102 in the 400 or Q107 in the 800. It switches Q102 and Q101 in the recorder. S102 closes when PLAY is pressed; S101 runs the motor for REWIND and ADVANCE.[5]
- Power: the mains transformer feeds a full-wave rectifier (CR104, CR105, type MR501) and a 2200 µF reservoir, C127. The motor runs through Q101 and a filter of L101 (100 µH) and C126 (220 µF). The manual notes that the 410 receives its motor control power (+5 V) from the computer, and the schematic marks the motor control wire as the recorder's +5 V source.[5]
| SIO pin | Wire colour | Signal |
| 3 | White | Data out to computer |
| 4 | Black | Ground |
| 5 | Brown | Data in from computer |
| 8 | Orange | Motor control |
| 11 | Red | Audio |
Electrolytic capacitors
[edit | edit source]The parts list for the Transtek board gives eight aluminium electrolytics.[5]
| Ref | Value | Rating | Atari P/N |
| C127 | 2200 µF | 16 V | C014373 |
| C126 | 220 µF | 16 V | FC100018 |
| C120 | 47 µF | 16 V | C015505 |
| C102, C104, C121, C122, C125 | 4.7 µF | 35 V | C014369 |
Four 820 pF polystyrene capacitors (C108 to C111, Atari C010821) set the tone filters.[5] Atari's head-alignment checklist names them as a cause of bad signals at the LM324.[6]
Known faults
[edit | edit source]- Belts: Atari's manual says the counter belt fails most often.[5] Owners replacing all the belts in a Hong Kong 410 describe the rewind belt as the hardest to reach.[8]
- Dirty or worn head, dirty capstan and pinch roller, broken head wires and cold solder joints.[5]
- Head azimuth out of adjustment, giving errors 138, 140 and 143.[6]
- Dirty contacts in the RECORD/PLAY switch S100.[5]
- Loading errors that are not faults: a long tape leader, a recorder connected through a peripheral that does not pass the signal, or a PAL operating system.[4][7]
The Atari 410 Maintenance Guide covers cleaning, belts and alignment, and the Atari 410 Troubleshooting page covers Atari's tests and test-point voltages.
[edit | edit source]- Atari 410 Documentation: the field service manual, both owner's manuals and the schematic.
- 410 Program Cassette Recorder Field Service Manual, FD100004 (May 1982), with two later tech tips bound in.
- The Atari 410 Program Recorder Owner's Guide, C060088 Rev. 1 (1981).
- Atari 410 Program Recorder operator's manual, C014810 Rev. 2 (1979).
Gallery
The original Bigston 410 with the cassette door open
Schematic of the Transtek 410 (FD100004 figure 7-1)
[edit | edit source]- Atari 410 Maintenance Guide
- Atari 410 Troubleshooting
- Atari 1010
- Atari 400
- Atari 800
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 Wikipedia, "Atari Program Recorder", sections "410 (original and revised versions)" and "1010". en.wikipedia.org. Used for the Bigston, Transtek and Chelco history and the Sears model number.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 Michael D. Current (ed.), Atari 8-Bit Computers: Frequently Asked Questions, comp.sys.atari.8bit FAQ: section 3.1 (program recorders: data rate, capacity, tracks and the 410 versions), section 6.7 (power: the 410 P adaptor and the mains-powered 410) and section 11.1 (history: January 1979 introduction; Sears catalogue price, November/December 1979). faqs.org. Community reference.
- ↑ 3.0 3.1 Atari, Inc., ATARI 410 Program Recorder operator's manual, C014810 Rev. 2, 1979: unpacking, set-up and key functions. Hosted here as File:Atari 410 Program Recorder Operator's Manual.pdf.
- ↑ 4.0 4.1 4.2 Atari, Inc., Consumer Product Service, Tech Tip 5, "ATARI 410 Recorder: 138, 140, and 143 Errors", 17 November 1982, servicer and user sections. Bound into the hosted copy of FD100004 (PDF pp. 20 to 34).
- ↑ 5.00 5.01 5.02 5.03 5.04 5.05 5.06 5.07 5.08 5.09 5.10 Atari, Inc., 410 Program Cassette Recorder Field Service Manual, FD100004, May 1982: maintenance areas (pp. 1-1, 1-2), theory of operation (pp. 2-1, 2-2), parts list (p. 6-1) and schematic (figure 7-1, p. 7-1). Hosted here as File:Atari 410 Program Cassette Recorder Field Service Manual FD100004.pdf.
- ↑ 6.0 6.1 6.2 Atari, Inc., Consumer Product Service, Tech Tip 9, "410 Cassette Recorders that register #143 error codes", 9 February 1983: head alignment procedure, Chelco component checks and head alignment symptom checklist. Bound into the hosted copy of FD100004 (PDF pp. 22 to 24).
- ↑ 7.0 7.1 Atari, Inc., The Atari 410 Program Recorder Owner's Guide, C060088 Rev. 1, 1981: button functions, errors 138 and 143, cleaning. Hosted here as File:Atari 410 Program Recorder Owner's Guide.pdf.
- ↑ "How to replace rewind belt in 410 Cassette deck", AtariAge Forums, Atari 8-Bit Computers, thread started by oryan_dunn, with later replies by rchennau. forums.atariage.com. Community repair report.
