Atari 822 Documentation
The Atari 822 documentation hosted here is the operator's manual for the Atari 822 thermal printer and Atari's technical specification for its circuit board.
822 Thermal Printer Operator's Manual
[edit | edit source]The 822 Thermal Printer Operator's Manual is Atari part number C015954 Rev. 2, copyright 1980. The hosted copy is the Internet Archive's 12-page text-layer PDF of the scan.[1]
Contents
[edit | edit source]| Section | PDF pages |
| Cover | 1 |
| Introduction, unpacking, setting up your printer | 3 |
| Caution on connecting the power adapter; installing paper | 4 |
| Paper loading diagram, paper storage caution, technical specifications | 5 |
| Printing speed, I/O data cord, reorder numbers | 6 |
| Printer commands in BASIC (LPRINT, LIST "P:) | 7 to 8 |
| Plotting graphic designs: a BASIC program that copies a graphics mode 8 screen to the printer | 9 to 10 |
| Back cover with the part number | 12 |
[edit | edit source]- Any service, adjustment or cleaning information.
- The printer's control codes.
Pages that cite this manual
[edit | edit source]- Atari 822: specifications, dimensions, paper and its loading, power adapter caution
- Atari 822 Troubleshooting: power adapter caution, paper
Download: Atari 822 Thermal Printer Operator's Manual C015954.pdf
822 Thermal Printer technical specification
[edit | edit source]The 822 technical specification is a 14-page Atari document, drawing number TS015897-01 Rev. 1, that describes the printer's circuit board block by block, each block with a partial schematic, and then the board test run on Atari's 822 test fixture. It is undated.[2]
Contents
[edit | edit source]| Page | Subject |
| 1 | Block diagram |
| 2 | Power supply: description and circuit, with the 12.4 V ±10 % figure for the +12 V rail |
| 3 | Main logic: Z200 (C015945), 4.00 MHz crystal, self-test jumper J200 |
| 4 | Power-on reset |
| 5 to 6 | Computer I/O |
| 7 to 8 | Motor buffers for the paper advance and carriage advance stepper motors |
| 9 | Print head buffers, home switch, thermal print head |
| 10 | Board test blocks 1 and 2: +5 V and +12 V limits |
| 11 to 13 | Board test blocks 3 to 6: print head, carriage motor and paper motor pulse widths, computer I/O |
| 14 | Interpreting the test fixture's printout |
[edit | edit source]- A parts list or a complete schematic. The circuit appears as separate figures, one per block.
- Component values for anything not drawn in those figures.
- Disassembly, adjustment or mechanical service procedures.
- The test fixture itself or its program.
The text on page 2 says the +15 V supply feeds the reset circuit and Z200; the figures on pages 3 and 4 show both on +5 V.
Pages that cite this document
[edit | edit source]- Atari 822: hardware, power supply
- Atari 822 Troubleshooting: supply rails and limits, self-test, drive pulse limits, I/O and reset
- Atari 822 Capacitor Replacement Guide: capacitor values and positions
Download: Atari 822 Thermal Printer Technical Specifications TS015897-01.pdf
[edit | edit source]- ↑ Internet Archive item atari_822_operators_manual, "Atari 822 Operator's Manual".
- ↑ Internet Archive item atari822technicalspecifications, "Atari 822 Technical Specifications".
