Atari SH204 Documentation
Atari documentation for the Atari SH204 hard disk drive: the owner's manual for Atari's SH drives, the SH204 specification sheet and the schematic of the SH204's host adapter card.
SH hard disk drive owner's manual
Atari Corp.'s SH Hard Disk Drive for the ST Computer, Owner's Manual, part number C026263 Rev. B, copyright 1986, printed in Taiwan. The scan has 48 pages; printed page numbers run from 1 to 38, and printed page n is PDF page n + 6.[1]
Contents
SH owner's manual contents
Printed page Contents
1 Introduction: the drive holds a hard disk, controller, interface and power supply
3 to 7 Getting started: unpacking, connecting (18-inch maximum cable), the SH Boot Disk, booting
9 to 18 Working with the drive: HDX (format, partition, install, zero, mark bad sectors), SHIP.PRG, backing up, notes and warnings
19 to 21 Addressing multiple drives: opening the cover and setting the DIP switches
23 and 24 Appendix A: troubleshooting and preventive maintenance
25 to 32 Appendix B: controller command summary, operation codes, status structure and status error codes
33 and 34 Appendix C: partition table layout in logical sector 0
35 to 38 Customer support and index
  • A schematic, parts list or disassembly beyond removing the cover.
  • The name of the drive mechanism or controller inside.
  • The European mains rating; the manual's fuse advice (1½ A, type 3AG) is marked "USA only".[1]
Pages that cite this document
Download: Atari SH Hard Disk Drive Owner's Manual C026263 Rev B.pdf
Atari Corp.'s one-page SH204 Hard Disk Drive Specifications, part number C026320 Rev. B, copyright 1986, printed in Taiwan. It gives the US mains rating (120 V 60 Hz), power consumption, drive geometry, transfer rate, dimensions and environmental limits.[2]
Download: Atari SH204 Hard Disk Drive Specifications C026320 Rev B.pdf
Host adapter card schematic
Atari (Japan) Corporation's Host Adapter Card Schematic Diagram, drawing C026198, part number CA026199, size D, one sheet, marked "Used on SH204" with the revision "A, Production release". It shows the DMA (ACSI) interface to the ST, the 50-pin connector J2 to the disk controller, a PAL16L8 (U6) and the unit number switch.[3] The Internet Archive item that holds it is titled "German" and "1984"; the drawing is in English.
It does not cover the disk controller board, the power supply or the drive. The card in a drive photographed by atari-computermuseum.de is marked "Host Adapter Card C026266 Rev. C".[4]
Download: Atari SH204 Host Adapter Card Schematic C026198.pdf
Documents not hosted here
The Atari Document Archive (dev-docs.org) catalogues schematics for two SH204 power supplies, an Astec ASP34-4 (C100116 Rev. A, 23 October 1986) and a Delta DPS-40 BP, and a Dutch "HD Technical Info" pack covering the SH204, SH205, Megafiles and SLM804. Searches of the Internet Archive by title found none of them.[5] The Internet Archive item that holds the owner's manual also has disk images of the SH boot disk and Atari's HD boot disk.[6]
  1. ↑ 1.0 1.1 Atari Corp., SH Hard Disk Drive Owner's Manual, C026263 Rev. B, 1986. File:Atari SH Hard Disk Drive Owner's Manual C026263 Rev B.pdf; source Internet Archive item sh-hard-disk-drive-drivers-tools-with-manual-atari-st.
  2. ↑ Atari Corp., SH204 Hard Disk Drive Specifications, C026320 Rev. B, 1986. File:Atari SH204 Hard Disk Drive Specifications C026320 Rev B.pdf; same source item.
  3. ↑ Atari (Japan) Corporation, Host Adapter Card Schematic Diagram, drawing C026198. File:Atari SH204 Host Adapter Card Schematic C026198.pdf; source Internet Archive item Atari_SH204_Host_Adapter_Card_Schematic_German_1984.
  4. ↑ Photograph of the SH204 host adapter card, atari-computermuseum.de. File:Atari SH204 host adapter card (Atari Computermuseum).jpg.
  5. ↑ Atari Document Archive (docs.dev-docs.org), search results for "sh204". https://docs.dev-docs.org/htm/search.php?find=sh204
  6. ↑ "SH Hard Disk Drive Drivers, Tools and Manual for Atari ST", Internet Archive item sh-hard-disk-drive-drivers-tools-with-manual-atari-st, https://archive.org/details/sh-hard-disk-drive-drivers-tools-with-manual-atari-st.
