Atari SM194 Documentation
Documentation for the Atari SM194 19-inch monochrome monitor.
SM194 technical manual
[edit | edit source]A 41-page scan with an Atari cover reading "SM194 Technical Manual, Februari 1991". Most of it is Moniterm Corporation's technical manual for its VCX series monitors, which the SM194 is; the appendix adds Moniterm's alignment specification and notes in Dutch on Atari Benelux letterhead.[1]
Contents
[edit | edit source]| PDF page | Contents |
| 1 | Atari cover |
| 2 | Table of contents |
| 3 to 12 | VCX series: scope, general description, electrical characteristics, display performance, controls, options, mechanical description, environmental performance, agency compliance, interface (9-pin D-sub and analogue BNC) |
| 13 to 24 | Theory of operation: deflection board (sync processing, horizontal and vertical deflection, power supply sync, focus modulation, high-voltage shut-down), low-voltage and high-voltage power supplies, 1-bit ECL video board, low- and medium-bandwidth analogue video boards. PDF page 17 repeats part of page 15. |
| 25 and 26 | Appendix title; Figure 1, the MC1391 phase-locked loop (U2) with its waveforms |
| 27 and 28 | Power supply schematics (Moniterm drawing "P65-R2 Power Supply", two sheets: the high-voltage section and the low-voltage supply) |
| 29 | Figure 2, the TDA1670 vertical circuit (U3) with its presets |
| 30 | Troubleshooting chart: monitor does not turn on |
| 31 | Block diagram: power supply, deflection board, video board |
| 32 and 34 | Moniterm Configuration and Alignment Specification, Viking VCX 91 DPI 220V, part number 903-0279-03 Rev. B (two copies) |
| 33 | Atari Benelux notes on the Moniterm training of 19 April 1989 (Dutch) |
| 35 | Atari Benelux repair tips: normal resistances of the supply outputs (Dutch) |
| 36 | Atari Benelux notes on the Moniterm Viking models and the Atari interface card (Dutch) |
| 37 to 41 | Schematics: deflection board and video board |
[edit | edit source]- A parts list.
- Step-by-step alignment procedures. The alignment specification gives the targets and refers to paragraph numbers in a Moniterm procedure that is not included.[1]
- Figures specific to the SM194 in the main text, which describes the VCX series at a typical 66 kHz; the alignment specification is the SM194-specific page.
- The interface card for the Mega ST. The Atari Document Archive catalogues a separate Atari SM194 Controller Board and Monitor Installation Manual (Version A, May 1989), which is not on the Internet Archive.[2]
Pages that cite this document
[edit | edit source]- Atari SM194: specifications, interface, hardware and repair notes
- Atari TTM194: as the nearest circuit-level document for the TTM194
Download: Atari SM194 Technical Manual (February 1991).pdf
[edit | edit source]- ↑ 1.0 1.1 SM194 Technical Manual, February 1991. File:Atari SM194 Technical Manual (February 1991).pdf; source Internet Archive item Atari_SM194_Technical_Manual_Feb_1991.
- ↑ Atari Document Archive (docs.dev-docs.org), search results for "sm194". https://docs.dev-docs.org/htm/search.php?find=sm194
