Atari XC11 and XC12 Documentation
The Atari XC11 and XC12 documentation below comprises the owner's manuals Atari packed with its two XE-styled cassette recorders, the Atari XC11 and the Atari XC12. Both carry the part number C070347 and follow the same layout.
Atari XC11 Program Recorder Owner's Manual
The Atari XC11 Program Recorder Owner's Manual is Atari Corp.'s 12-page manual for the XC11, part number C070347 Rev. A, dated 1985 and printed in Japan. The cover says it is for use with all Atari 8-bit computers.
Contents
Section Pages
Button/connector control 2
Button functions (REC, PLAY, REWIND, ADVANCE, STOP/EJECT, PAUSE, counter reset, power light) 3
Connecting 4
Loading cassette programs, with the note on errors 138 and 143 5–6
Saving programs to cassette, with the safety tabs 7–8
Radio and television interference 9
There are no specifications, power requirements, care instructions or service information. The rear-panel drawing on page 3 shows the built-in cable as "I/O connector 1" and the SIO socket as "I/O connector 2".
Pages that cite this manual
  • Atari XC11: keys, connectors, loading and the 138/143 errors
Download: Atari XC11 Program Recorder Owner's Manual C070347.pdf
Atari XC12 Program Recorder Owner's Manual
The Atari XC12 Program Recorder Owner's Manual is the 12-page manual for the XC12, part number C070347/A Rev. B, dated 1986 and printed in Taiwan. The cover lists the Atari XE, 800XL, 600XL, 800 and 400 computers. Its contents list is the same as the XC11's, with F.FWD in place of ADVANCE, a SAVE indicator in place of the power light, and a single I/O cable in place of the two connectors.
As with the XC11 manual, there are no specifications, power requirements, care instructions or service information.
  • Atari XC12: keys, connection, loading, saving and the 138/143 errors
Download: Atari XC12 Program Recorder Owner's Manual C070347 Rev B.pdf
