Atari SC1425 Capacitor Replacement Guide
Electrolytic capacitors in the Atari SC1425 14-inch colour monitor, read from the Philips CM8852/CM8832 circuit diagram that was supplied with an SC1425.[1] No Atari or Philips parts list for the SC1425 has been found, so the values come from the drawing alone.
The SC1425 has a colour CRT and a switch-mode power supply whose primary side the schematic marks "not mains isolated". Unplug the monitor, discharge the CRT as described in CRT Discharge Procedure, and check that C112 is discharged before working on the board.[1]
Reading the schematic
[edit | edit source]The legend on the drawing marks a capacitor's type with a symbol and a dot code: ▵▵ for ceramic, ●● for film ("flat foil") and a single ● for electrolytic. A letter after the code gives the working voltage: e 16 V, f 25 V, g 40 V, h 63 V, j 100 V, r 250 V, u 400 V, v 500 V, w 630 V.[1] Seventeen of the electrolytics carry no voltage letter. For those, read the rating off the fitted part before ordering, and use at least the voltage of the line the part sits on where the drawing shows it. The component index on the drawing lists every capacitor with its grid position.[1]
Main board
[edit | edit source]| Ref | µF | Voltage | Notes |
| C112 | 100 | Not marked | Mains reservoir after the bridge D107-D110. The ●● u marking beside it belongs to C111 |
| C116 | 47 | 25 V | |
| C122 | 1 | 63 V | |
| C144 | 47 | Not marked | |
| C145 | 470 | 40 V | |
| C146 | 470 | 25 V | |
| C204 | 100 | 16 V | SCART red input coupling |
| C205 | 100 | 16 V | SCART green input coupling |
| C206 | 100 | 16 V | SCART blue input coupling |
| C214 | 100 | 25 V | |
| C216 | 47 | 25 V | |
| C232 | 47 | 25 V | |
| C233 | 100 | 25 V | |
| C234 | 1 | 63 V | |
| C318 | 22 | Not marked | IC301 (TDA2611A audio) |
| C323 | 220 | 16 V | Loudspeaker coupling |
| C324 | 1000 | Not marked | IC301 supply |
| C334 | 0.47 | 63 V | |
| C345 | 10 | Not marked | IC302 (TDA2653A vertical) |
| C346 | 470 | 40 V | |
| C347 | 100 | Not marked | IC302 |
| C352 | 680 | 40 V | |
| C361 | 47 | 25 V | |
| C401 | 2.2 | 63 V | |
| C412 | 10 | Not marked | |
| C433 | 100 | Not marked | |
| C446 | 1 | Not marked | IC402 (TDA2595) |
| C447 | 4.7 | 63 V | IC402 |
| C461 | 2.2 | 63 V | |
| C462 | 22 | 40 V | |
| C473 | 4.7 | Not marked | |
| C474 | 1 | 63 V | |
| C482 | 1 | Not marked | |
| C485 | 22 | Not marked | |
| C491 | 470 | 25 V | Before IC403 (L7812) |
| C492 | 100 | 16 V | After IC403 |
| C493 | 470 | 40 V | |
| C494 | 47 | Not marked | On the +125 V line |
| C574 | 100 | 25 V | IC502 (TDA3505) |
| C585 | 4.7 | 63 V | IC502 |
| C634 | 22 | Not marked | |
| C636 | 22 | Not marked | |
| C638 | 100 | Not marked | On the -20 V line |
| C717 | 4.7 | Not marked | On the +125 V line to the CRT panel |
That is 44 electrolytics on the main drawing. Two more, C496 (47 µF) and C497 (1.5 µF), are drawn on the schematic but listed as deleted on the CM8832; check whether they are fitted on the board in front of you.[1]
TTL interface board
[edit | edit source]The TTL interface (assembly 1108, "Schema B") has one electrolytic, C258, 47 µF 25 V, on its +5 V supply. The other capacitors on that board are C251 to C254 (22 pF), C255 (100 pF) and C256 and C257 (22 nF).[2]
Procedure
[edit | edit source]- Unplug the monitor and remove the rear cover.
- Discharge the CRT anode to the chassis earth (CRT Discharge Procedure).
- Measure C112 and discharge it through a resistor if it holds a charge. It is the reservoir on the rectified mains, after the bridge D107 to D110.[1]
- Replace one capacitor at a time. Match polarity to the board marking. Use the voltage in the table where the drawing gives one; where it does not, read it from the part being removed.
- Parts marked with the warning triangle on the drawing are safety parts; replace them only with the same type.[1]
- Refit the board, reconnect the anode cap, and check the picture before adjusting anything.
[edit | edit source]- Atari SC1425
- Atari SC1425 Documentation
- Atari SC1435 Capacitor Replacement Guide
- Capacitor Failure Symptoms
- CRT Discharge Procedure
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Philips, circuit diagram CM8852/00 and CM8832, 4822 727 31481 (PRS.01474): legend, component index and main diagram, pages 1 and 2 of File:Atari SC1425 Schematic (Philips CM8852 and CM8832).pdf.
- ↑ Philips, "Schema B", TTL interface 1108 (PRS.01496), page 3 of File:Atari SC1425 Schematic (Philips CM8852 and CM8832).pdf.
