Atari SC1425 Documentation
Documentation for the Atari SC1425 colour monitor. No Atari service manual or parts list for the SC1425 has been found. The hosted schematic is the Philips circuit diagram that came with one SC1425, and Atari's 1986 monitor memo shows the specification Atari first planned under the SC1425 name.
Philips CM8852/CM8832 circuit diagram
Philips's circuit diagram for the CM8852/00 and CM8832 colour monitor chassis, drawing 4822 727 31481 (PRS.01474), with the TTL interface "Schema B" (assembly 1108, PRS.01496). An Atari-Forum member scanned it from the paper copy supplied with an SC1425 and shared it in January 2026.[1][2] The hosted PDF has three pages at about 300 dpi, half the resolution of the original scan.
Contents
Schematic PDF, page map
PDF page Contents
1 Left half of the main circuit diagram (grid columns 1 to 24): legend with the component symbols and capacitor voltage codes; mains input and switch-mode power supply; SCART input; TTL input connector; TDA3505 video processor; TDA2595 sync and horizontal oscillator; TDA2653A vertical output; TDA2611A audio input; the box of CM8832 changes
2 Right half of the main circuit diagram (columns 9 to 29): video output stages, line output stage with the BU508A, CRT panel, audio output, and the component location index
3 "Schema B", the TTL interface (74LS368, 74LS05 and BC548 output buffers), with its own component index
  • A parts list with part numbers. Values are printed on the drawing only.
  • Voltage ratings for 17 of the electrolytic capacitors, which carry no voltage code.
  • Adjustment procedures, waveform tables, board layouts or fault-finding.
  • Any statement of which of the two Philips models the SC1425 corresponds to.
Pages that cite this document
Download: Atari SC1425 Schematic (Philips CM8852 and CM8832).pdf
Atari Monitor Summary Specifications, May 1986
Atari's memo of 14 May 1986 includes an SC1425 column: a 14-inch tube, 0.31 mm dot pitch, analogue RGB input, 32 MHz dot rate, 640 × 480 resolution and 31.5 kHz horizontal scan, with the connector "TBD". The covering note asks for a pin-out for the "SC1425 EST" monitor. This is not the 15.625 kHz SC1425 that went on sale in 1988.[3] The memo is described on Atari SC1224 Documentation.
  1. ↑ Philips, circuit diagram CM8852/00 and CM8832, 4822 727 31481. File:Atari SC1425 Schematic (Philips CM8852 and CM8832).pdf.
  2. ↑ "Atari SC 1425 monitor schematics", Atari-Forum, post by gligli, 2 January 2026. https://www.atari-forum.com/viewtopic.php?t=45681
  3. ↑ Atari Corp., Atari Monitor Summary Specifications, 14 May 1986, pp. 1-2. File:Atari Monitor Summary Specifications (1986-05-14).pdf.
