Atari SM124 Troubleshooting Guide
The MT-9 power board: fuse F901, reservoir C905, regulator IC901 and the bridge D901 to D904 (Atari service manual)
Fault-finding for the Atari SM124 monochrome monitor, drawn from Atari's service manuals for the MT-9 and MT-21 chassis, the 1985 owner's manual and owners' repair notes.[1][2][3] The two chassis have different power supplies and horizontal circuits, so work out which one you have first (see Atari SM124 General Maintenance#Identify the chassis).
The tube runs at up to 12 kV, and the MT-21's power supply rectifies the mains directly. Discharge the tube before handling the chassis (CRT Discharge Procedure).[4][5]
Before opening the monitor
First checks
Symptom Check
No picture The monitor is switched on (the on/volume knob turned clockwise, green lamp lit), the mains lead is plugged in, the video cable is pushed fully into the ST's Monitor socket, and brightness and contrast are not turned fully down.[3][6]
A program will not run The attached monitor decides which resolutions the ST offers; with the SM124 that is 640 × 400 only. Software written for the colour modes needs a colour monitor.[7]
Picture rolls, vibrates, is distorted or blurred Atari's owner's manual sends these to a service centre for internal repair or adjustment; the service adjustments are on Atari SM124 General Maintenance#Adjustments.[3]
No sound The SM124 has a speaker; the on/volume knob sets the level.[6] Check the cable, then the sound chart below.
Atari's troubleshooting charts
Both manuals start from the same main chart: check the connection between the monitor and the computer, then follow the power chart if the front lamp does not light, the video chart if the picture is wrong and the sound chart if the sound is wrong. If none of these applies, switch the monitor on, check it again after 15 minutes, and adjust it.[1][2]
MT-9: power chart
MT-9 power chart[8]
Check Result
Lamp lit? Lit: go to the main chart. Not lit or weak: continue
+22 V DC at the input of IC901 Present: go to the next row. Absent: check the fuse F901
F901 open? Open: replace it; if the new fuse blows, the fault is in the bridge diodes D901 to D904. Not open: check P5 and P4 on the power board
17 V AC at P5 and P4 Present: the chart gives "replace power switch". Absent: replace the power transformer
+12 V DC at the output of IC901 and pin 2 of connector P901 Present: go to the main chart. Absent: replace IC901 or Q901
MT-21: power chart
MT-21 power chart[9]
Check Result
Lamp lit? Lit: go to the main chart. Not lit or weak: check D930
+27 V DC (the B+ set by VR901) Present: check the output of the flyback transformer. Absent: check the fuse F901
F901 open? Open: replace it; if the new fuse blows, the fault is in D901 or IC901. Not open: check Q702
Q702 (BU806, horizontal output) open? Yes: replace Q702. No: replace Q901, the 2SC3507 switching transistor
Video charts
If there is a picture but it is wrong, both charts start by adjusting the presets (MT-9: V-hold VR601, H-centre VR701, sub-brightness VR702; MT-21: V-size VR601, H-hold VR701, sub-brightness VR702), then checking the video, horizontal and vertical circuits in turn.[10][11] With no picture at all, work from the input towards the tube. The voltages are peak-to-peak signal levels.
No picture: video path[10][11]
MT-9 check If absent MT-21 check If absent
1.6 V p-p at pin 3 of P301 Signal cable 1.0 V p-p at P301 Signal cable
5 V p-p at pin 5 or 9 of IC302 IC301 or Q304 3.3 V p-p at the collector of Q301 Q301
4.8 V p-p at pin 8 or 6 of IC302 IC302 or Q301 7.1 V p-p at the collector of Q302 Q302
28 V p-p at the cathode on the CRT board Check Q303 and Q302; if they are faulty, replace them 30 V p-p at the cathode on the CRT board Check Q304 and Q305; if they are faulty, replace them
Flyback circuit normal Flyback transformer Flyback circuit normal Flyback transformer
All of the above normal Picture tube All of the above normal Picture tube
Sound charts
With the power on, check the connectors in order: P901, P402 and P401 on the MT-9, P602, P402 and P401 on the MT-21. If all are good, the MT-9 chart blames IC401 (AN5265) and C403 (470 µF 16 V), and the MT-21 chart blames Q401.[12][13][14]
Voltage charts
DC voltages from the service manuals, measured with no signal and with a 1 V p-p video signal.[15][16]
MT-9 transistor voltages (V)[15]
Transistor Type Function B (no signal) E (no signal) C (no signal) B (signal) E (signal) C (signal)
Q301 KTC1959 Brightness/contrast 3.87 3.25 11.94 3.92 3.28 11.91
Q302 BSX20 Video output 0.26 0 5.58 1.93 1.37 5.52
Q303 KTC2229 Video output 5.0 5.0 7.2 5.88 5.51 51.0
Q304 BSX20 Video input 0.02 0 5.01 0.50 0 2.25
Q701 KTC562 H frequency detector 3.94 0.01 0 0.58 −0.14 0
Q702 KTC1959 Monostable 0.04 0 9.0 0.41 0 5.38
Q703 KTC1959 Monostable 0.69 0 0.04 −0.17 0 2.47
Q704 KTC1959 Astable −0.25 0 2.82 −0.07 0 2.46
Q705 KTC1959 Astable −0.78 0 4.2 −0.75 0 4.00
Q706 KTC1959 H inverter 0.48 0 0.33 0.46 0 0.35
Q707 KTC1959 H drive 0.33 0 2.93 0.33 0 2.71
Q708 BU806 H output −0.26 0 29.7 0.04 0 28.9
MT-21 transistor voltages (V), as printed[16]
Q301 2N2369 Video input 0 0 3.8 0.8 0 3.4
Q302 2N2369 Video amplifier 0.8 0 0.1 0.8 0 7.2
Q303 KTC1959 Brightness/contrast 8 7 12 8 7 12
Q304 2N3904 Video drive 0.3 0 12 7.2 6.7 13
Q305 2SC3503 Video output 12 12 60 12 13 57
Q701 KTC200 Horizontal drive 6.8 6.85 6.8 6.8 7 6.8
Q702 BU806 Horizontal output 6.4 0 180 6.4 0 180
Q901 2SC3507 Power switching 1.6 0 510 1.6 0 520
Q401 KTC1959 Audio input 0.7 0 0 0.7 0 0
Q402 KTC1959 Audio amplifier 6.6 1 12 6.6 1 12
Q403 KTC562 Audio amplifier 2.6 6 0 2.6 6 0
Q901 on the MT-21 sits on the rectified mains, about 500 V on its collector. Do not probe it without an isolation transformer and a meter rated for the voltage.[16][5] The MT-9 manual types Q303 as KTC2229 in its voltage chart and video amplifier figure, and as KTC2249 in the parts list.[15][14]
Faults reported by owners
Symptom Cause and fix
A single vertical line on the screen The bipolar capacitor C716 (2.2 µF 50 V) in the horizontal deflection circuit. Pawel Pieczul of oldcrap.org names it as the part most likely to fail on the SM124. It is C716 in the MT-21 parts list and C714 in the MT-9 list.[17][18][14]
Monitor will not switch on from the knob One owner reported a faulty switch on the combined on/volume control.[19] Atari's MT-9 parts list gives the switch as an EVV-G6LF20B14.[20]
Self-inflicted faults
  • Do not replace C716 with an ordinary electrolytic capacitor of the same rating. Pieczul reports that it blows up; he fits a polypropylene (MKP) film capacitor, which another owner also used.[17][19]
  • Do not trust a single capacitor list for the CRT board. An owner recapping a revision 1.2 board found that C302 and C303 were 100 µF 10 V; oldcrap.org's list had first given them as 10 µF 100 V and was corrected after his report.[19]
  • CRT Database warns that stretching the raster with the internal presets to fill more of the screen may cause premature failure of internal components.[21]
  1. ↑ 1.0 1.1 SM124 Service Manual (MT-9), Troubleshooting Chart, main chart, p. 16.
  2. ↑ 2.0 2.1 Atari, SM124 High-Resolution Monochrome Monitor Service Manual, chassis MT-21, P/N 483-351A, Troubleshooting Chart, main chart, p. 16. File:Atari SM124 Service Manual (MT-21 chassis).pdf.
  3. ↑ 3.0 3.1 3.2 Atari Corp., SM124 Owner's Manual, 1985, p. 4, "Troubleshooting". File:Atari SM124 Owner's Manual (1985).pdf.
  4. ↑ Atari, SM124 High-Resolution Monochrome Monitor Service Manual, chassis MT-9, P/N 483-303A, Safety Precautions, p. 2. File:Atari SM124 Service Manual (MT-9 chassis).pdf.
  5. ↑ 5.0 5.1 SM124 Service Manual (MT-21), Theory of Operation, power supply, pp. 7-8.
  6. ↑ 6.0 6.1 SM124 Owner's Manual, p. 3, "The On/Volume Control".
  7. ↑ "Atari ST", Wikipedia, section "Monitor". https://en.wikipedia.org/wiki/Atari_ST
  8. ↑ SM124 Service Manual (MT-9), Power Chart, p. 17.
  9. ↑ SM124 Service Manual (MT-21), Power Chart, p. 17.
  10. ↑ 10.0 10.1 SM124 Service Manual (MT-9), Video Chart, p. 18.
  11. ↑ 11.0 11.1 SM124 Service Manual (MT-21), Video Chart, p. 18.
  12. ↑ SM124 Service Manual (MT-9), Sound Chart, p. 19.
  13. ↑ SM124 Service Manual (MT-21), Sound Chart, p. 19.
  14. ↑ 14.0 14.1 14.2 SM124 Service Manual (MT-9), Replacement Parts List, pp. 26-27.
  15. ↑ 15.0 15.1 15.2 SM124 Service Manual (MT-9), Voltage Chart, p. 11, and Fig. 3, Video Amplifier, p. 5.
  16. ↑ 16.0 16.1 16.2 SM124 Service Manual (MT-21), Voltage Chart, p. 12.
  17. ↑ 17.0 17.1 Pawel Pieczul, "Atari SM124 Monitor", oldcrap.org, 20 October 2019, https://oldcrap.org/2019/10/20/atari-sm124-monitor/. Community source: the note on C716 under "Board".
  18. ↑ SM124 Service Manual (MT-21), Replacement Parts List, p. 21.
  19. ↑ 19.0 19.1 19.2 Comments on "Atari SM124 Monitor", oldcrap.org: a reader's question about a faulty power switch (27 April 2022) and krs's recapping report (8 and 12 October 2023). https://oldcrap.org/2019/10/20/atari-sm124-monitor/. Community reports.
  20. ↑ SM124 Service Manual (MT-9), Replacement Parts List, p. 28: power switch 180-291A, EVV-G6LF20B14.
  21. ↑ "Atari SM124", CRT Database, https://crtdatabase.com/crts/atari/atari-sm124-mt-9. Community source (CC BY-NC-SA 4.0), notes section.
