Atari SM124 Documentation
Atari documentation for the Atari SM124 monochrome monitor: the service manuals for the two GoldStar chassis, MT-9 and MT-21, and the 1985 owner's manual. Atari's May 1986 summary specification for its ST monitors, which has an SM124 column, is described on Atari SC1224 Documentation.
SM124 Service Manual, chassis MT-9
Atari's SM124 High-Resolution Monochrome Monitor Service Manual for chassis MT-9, part number 483-303A, printed in Korea and undated. The hosted scan has 30 pages, and its PDF page numbers match the printed page numbers.[1]
Contents
MT-9 service manual contents
Page Contents
1 Cover and contents
2 Safety precautions: maximum high voltage 12 kV +1 −2 kV, discharge method, safety inspection and leakage checks
3 Specifications; adjustment and maintenance (circuit protection, centring, focus, brightness, vertical and horizontal size and linearity)
4 Geometry measurements (pincushion, trapezium, parallelogram, yoke tilt)
5 to 7 Theory of operation: video amplifier (Fig. 3), vertical deflection with the TDA1170D block diagram (Fig. 4), horizontal deflection (Fig. 5), power supply
8 Block diagram
9 Timing chart
10 Transistor and IC basing
11 and 12 Voltage charts: transistors, then the TDA1170D and AN5265 pin voltages
13 to 15 Board layouts: main board component and solder sides, power supply board
16 to 19 Troubleshooting charts: main, power, video, sound
20 to 25 Circuit waveforms: video, vertical and horizontal deflection
26 to 28 Replacement parts list
29 Exploded view and mechanical parts
30 Schematic diagram, P/N 484-476A
  • A procedure for opening the case.
  • Any coverage of the MT-21 chassis.
  • Agreement on every designator: the adjustment text names VR301 as the sub-brightness control, where the board legend and the video chart give VR702, and Q303 is a KTC2229 in the voltage chart and a KTC2249 in the parts list.[1]
An older scan of the same manual on the Internet Archive (item SM124_Service_Manual_MT-9) has ten pages replaced by "missing page" placeholders; the hosted copy is a later, complete scan. Four pages of this manual (the exploded view, the schematic, the geometry page and the specification page) are also bound into the SC1224 CA-3 scan, File:Atari SC1224 Service Manual (CA-3 chassis).pdf, at PDF pages 2 to 5.[2]
Pages that cite this document
Download: Atari SM124 Service Manual (MT-9 chassis).pdf
SM124 Service Manual, chassis MT-21
Atari's service manual for the SM124 on chassis MT-21, part number 483-351A, printed in Korea and undated. The scan has 27 pages and carries the stamp of Schaltungsdienst Lange, a Berlin schematic service, on the cover. PDF pages 1 to 22 are the manual itself, with printed page numbers matching the PDF; pages 23 to 27 are separate sheets.[3]
Contents
MT-21 service manual contents
Page Contents
2 Safety precautions and safety inspection
3 Specifications; adjustment and maintenance, including the B+ adjustment VR901 (27 V)
5 to 8 Theory of operation: video amplifier, vertical deflection (TDA1170D), horizontal deflection (AN5790N, Fig. 5), power supply with the TDA4601 block diagram, pin functions and Fig. 7, Power Circuit
9 to 11 Block diagram, timing chart, transistor and IC basing
12 and 13 Voltage charts
14 and 15 Main board layout, component and solder sides
20 to 22 Replacement parts list
23 "Revised video circuit SM124 monitor", with an annotated photograph of the board
24 to 27 MT-21 schematic diagrams and the exploded view
  • Clean values throughout. The scan is a photocopy, and some parts list entries disagree with the power circuit drawing (C909) or with the part number they carry (C305). See Atari SM124 Capacitor Replacement Guide.[3]
  • Any coverage of the MT-9.
Download: Atari SM124 Service Manual (MT-21 chassis).pdf
SM124 owner's manual
Atari's SM124 High-Resolution Monochrome Monitor Owner's Manual, copyright 1985, printed in Korea, 10 scanned pages. It covers unpacking, connecting the monitor to an ST, the on/volume, contrast and brightness controls, a short troubleshooting table, care and safety, customer support and specifications (220 V 50 Hz, 50 W, 17 lb).[4]
Download: Atari SM124 Owner's Manual (1985).pdf
Other documents not hosted here
The Atari Document Archive (dev-docs.org) lists the same three documents, and the Internet Archive holds a 13-page "Atari SM124 Schematic (1986)" set and a redrawn MT-21 schematic by Remon Pel.[5][6]
  1. ↑ 1.0 1.1 Atari, SM124 High-Resolution Monochrome Monitor Service Manual, chassis MT-9, P/N 483-303A. File:Atari SM124 Service Manual (MT-9 chassis).pdf; source Internet Archive item sm-124-service-manual-mt-9.
  2. ↑ Atari SC1224 Documentation, CA-3 service manual page map.
  3. ↑ 3.0 3.1 Atari, SM124 High-Resolution Monochrome Monitor Service Manual, chassis MT-21, P/N 483-351A. File:Atari SM124 Service Manual (MT-21 chassis).pdf; source Internet Archive item SM124_Service_Manual_MT-21.
  4. ↑ Atari Corp., SM124 High-Resolution Monochrome Monitor Owner's Manual, 1985. File:Atari SM124 Owner's Manual (1985).pdf; source Internet Archive item Atari_SM124_Owners_Manual_1985.
  5. ↑ "Atari SM124 Schematic (1986)(Atari)", Internet Archive item Atari_SM124_Schematic_1986_Atari, https://archive.org/details/Atari_SM124_Schematic_1986_Atari.
  6. ↑ "Atari SM 124 Schematic 1986 Atari (MT-21)", a reworked schematic of the MT-21 board, Internet Archive item atari-sm-124-schematic-1986-atari, https://archive.org/details/atari-sm-124-schematic-1986-atari.
