Atari XF551 Capacitor Replacement Guide
XF551 power supply on Atari's schematic C100727: C102, C103 and C104 are the three 4700 µF capacitors
The Atari XF551 controller board rectifies the adaptor's 9 V AC itself, so its power supply carries three large electrolytic capacitors. Atari's schematic C100727 gives six electrolytics on sheet 1: the three 4700 µF parts, two 47 µF output capacitors and the 1 µF reset capacitor of the microcontroller.[1] The scan of the schematic has no sheet 2, and the drive mechanism's own board is not covered by it, so check the board in front of you for any electrolytic not in the table.
Signs of failure
  • +12 V missing at TP14 or J5 pin 4 while +5 V is present. The +12 V rail depends on the voltage doubler, C102 with D2 and D3, and on C104.[1]
  • Bulging tops on the three large capacitors. The white material round their bases is adhesive against vibration, not leaked electrolyte.[2]
  • A drive that runs hot for long periods: the capacitors sit near the regulators' heatsink and the rectifier, and Gramblička adds heatsinking partly to keep them cooler.[3]
See Capacitor Failure Symptoms for general signs.
Capacitor list
Atari XF551 electrolytic capacitors (schematic C100727, sheet 1)
Ref Value Voltage Where it sits Notes
C102 4,700 µF 35 V Voltage doubler, between the bridge D1 and the junction of D2 and D3
C103 4,700 µF 35 V Input of Q5, the +5 V regulator About 14 V DC in use (Gramblička)
C104 4,700 µF 35 V Input of Q6 (7812), after the doubler About 23 to 26 V DC in use (Gramblička)
C109 47 µF 16 V Output of Q5, +5 V
C110 47 µF 16 V Output of Q6, +12 V, at TP14
C113 1 µF Not marked Reset input of U1 (pin 4) to ground
Values, ratings and positions are from Atari's schematic; the working voltages are Gramblička's figures.[1][2][4] The other capacitors in the power supply are not electrolytics: C101, C111 and C112 are 0.033 µF film capacitors at the AC input, and C105 to C108 are 0.1 µF decoupling capacitors at the regulators.[1]
Gramblička notes two board versions, of 1987 and 1988, and says the later one drops some of the extra DC filtering, and that boards exist with duplicated component designators.[5][2] Atari's drawing is dated November 1987. Identify each capacitor on the board by its position in the circuit as well as by its printed designator.
In his own XF551 design Gramblička uses a 1 µF 50 V reset capacitor and 47 µF 35 V output capacitors, having moved the outputs up from 16 V parts because he prefers the higher rating.[6]
Procedure
  1. Unplug the adaptor and the SIO cables, and wait for the large capacitors to discharge. Measure across C102, C103 and C104 before touching them.
  2. Open the case. The drive mechanism sits over the controller board and has to be moved out of the way to reach it.[2]
  3. Note the polarity of each capacitor before removing it, and replace them one at a time.
  4. Use parts of the same capacitance and at least the same voltage rating, and check that the larger replacements clear the heatsink.
  5. Refit the mechanism and close the case.
Checks after recapping
Voltages to check
Point Expected Source
J5 pin 1 +5 V Atari schematic[1]
J5 pin 4, TP14 +12 V Atari schematic[1]
Across C103 About 14 V DC Gramblička[2]
Across C104 About 23 to 26 V DC Gramblička[4][2]
Then boot a known-good disk and format a spare one.
Switching regulators
Gramblička replaces the 7805 and 7812 with Traco TSR 1-2450 and TSR 1-24120 switching modules, which fit the same positions and run almost cold.[4] Writing about the 1050, whose supply works on the same principle, he also warns that if a switching DC adaptor is used instead, with the bridge and doubler removed, 4700 µF capacitors are too large for the adaptor's output and 470 to 1000 µF is enough.[4]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Atari (Japan) Corporation, Schematic Diagram XF551 (FCC), drawing C100727 rev. 1, sheet 1 of 2, preliminary release 19 November 1987: power supply (C101 to C112, Q5, Q6, D1 to D3, J5, TP14) and microcontroller reset (C113). Hosted as File:Atari XF551 Schematic C100727.pdf.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Igor Gramblička (Igi), "Atari XF551 – doplnkové informácie / Atari XF551 – additional information", Igi blog, 26 March 2019 with later additions to September 2024, blog.3b2.sk (retrieved 2026-10-06), in Slovak. Rectified voltages, the adhesive round the large capacitors, duplicated designators, opening the drive. Community repair experience.
  3. ↑ Igor Gramblička (Igi), "Atari XF551 – ešte raz oživenie tejto jednotky / once again reviving this unit", Igi blog, 17 March 2020, blog.3b2.sk (retrieved 2026-10-06), in Slovak. Added heatsinks.
  4. ↑ 4.0 4.1 4.2 4.3 Igor Gramblička (Igi), "ATARI 1050, ATARI XF551 – napájací zdroj / Power Supply modification", Igi blog, 4 November 2013, blog.3b2.sk (retrieved 2026-10-06), in Slovak. Regulator input voltages, Traco replacements, capacitor size with switching adaptors.
  5. ↑ Igor Gramblička (Igi), "Atari XF551 – originálna schéma / original circuit", Igi blog, 6 February 2020, blog.3b2.sk (retrieved 2026-10-06), in Slovak. Board versions of 1987 and 1988.
  6. ↑ Igor Gramblička (Igi), "Atari XF551 – circuit version ála Igi", Igi blog, 20 February 2020, updated 19 July 2022, blog.3b2.sk (retrieved 2026-10-06), in Slovak. Reset capacitor 1 µF 50 V; 47 µF 35 V output capacitors.
