Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
Recent changes optionsShow last 50 | 100 | 250 | 500 changes in last 1 | 3 | 7 | 14 | 30 days
Hide registered users | Hide anonymous users | Hide my edits | Show bots | Hide minor edits
Show new changes starting from 13:58, 27 September 2026
Page name:
List of abbreviations:
N
This edit created a new page (also see list of new pages)
m
This is a minor edit
b
This edit was performed by a bot
(±123)
The page size changed by this number of bytes
27 September 2026
     13:56  Macintosh TV diffhist +2,801 Josh talk contribs (Apple Service Source: Apple gives 4 MB of DRAM on board expandable to 8 MB in one 72-pin SIMM - there is no 1 MB SIMM and no 5 MB configuration (5 MB is the Performa 575/577 figure); weight is 41.5 lb (18.9 kg), not the Performa 550's 40.5 lb; sound is monaural IN and stereo out; VRAM is 512K and cannot be expanded, so the 256-colour ceiling is not a missing SIMM; added Apple's 120 W supply, 160 MB SCSI drive, 13-inch viewable / 0.26 mm Trinitron figures, two ADB ports, the 3.0 V lithium batt...)
     13:49  Macintosh Quadra 950 diffhist +2,850 Josh talk contribs (Apple Service Source: case height is 16.8 in (473 mm), not 18.6 in; the Quadra 950 weight was printed as 36.8 lb (11.5 kg), an internal contradiction - Apple gives 36 lb 12 oz (16.7 kg) without a hard drive; the 950's standard RAM is 8 MB (16/32/48 MB parity configurations are the AWS 95); added Apple's 303 W rating, five NuBus slots, ONE ADB port, 8-bit built-in video upgradeable to 24-bit, the seven-year lithium clock cell, the SCSI-upgrade note that the OS supports only 7 devices, and the...)
     13:49  Macintosh Quadra 900 diffhist +2,832 Josh talk contribs (Apple Service Source: case height is 16.8 in (473 mm), not 18.6 in; the Quadra 950 weight was printed as 36.8 lb (11.5 kg), an internal contradiction - Apple gives 36 lb 12 oz (16.7 kg) without a hard drive; the 950's standard RAM is 8 MB (16/32/48 MB parity configurations are the AWS 95); added Apple's 303 W rating, five NuBus slots, ONE ADB port, 8-bit built-in video upgradeable to 24-bit, the seven-year lithium clock cell, the SCSI-upgrade note that the OS supports only 7 devices, and the...)
     13:49  Macintosh Quadra 840AV diffhist +3,162 Josh talk contribs (Apple Service Source: case dimensions and weight corrected (14.25 x 7.75 x 16.0 in, 24 lb / 10.9 kg - the page said 25.3 lb / 11.5 kg); removed the unsourced '48 kHz' and 'DSP 3210 @ 66.7 MHz' figures; added Apple's ROM (2 MB), 128 MB maximum on 60 ns CAS-before-RAS SIMMs, the VRAM pixel-depth table, mini DIN-9 GeoPort, AUI-15 Ethernet, automatic SCSI termination, the per-NuBus-card and per-SCSI-device power budgets, and the 3.2 V lithium PRAM threshold)
     13:49  Macintosh Quadra 800 diffhist +2,512 Josh talk contribs (Apple Service Source: case dimensions corrected to 14.25 x 7.75 x 16.0 in (360 x 196 x 396 mm); sound is 8-bit monaural in and 8-bit stereo out; added Apple's 200 W continuous rating, the 60 ns SIMM requirement, the full VRAM pixel-depth table, 140-pin PDS and three 96-pin Euro-DIN NuBus slots, AUI-15 Ethernet, and the 3.2 V lithium PRAM threshold; noted that Apple's own metric weight (11.3 kg for 24 lb) is wrong)
     13:45  Macintosh Quadra 700 diffhist +1,992 Josh talk contribs (Apple Service Source: Ethernet is AUI-15, not AAUI-15 - different connector, different transceiver; sound is 8-bit stereo sampling at 44.1 kHz with four-voice wavetable, not 22 kHz; weight is 14 lb (6.4 kg) with a hard drive; deleted an unsourced VRAM/resolution table (six VRAM slots, 2 MB, 24-bit at 832x624) and an untraceable 4 MB/s SCSI figure - Apple's volume gives no VRAM capacity for this machine and documents built-in video as 640x480 up to 8-bit; recorded Apple's own 8/20 MB memory ce...)
     13:45  Macintosh Quadra 660AV diffhist +2,269 Josh talk contribs (Apple Service Source: added Apple's figures - 8 MB (4 soldered + 4 MB SIMM) to 68 MB, 1 MB of VRAM in two soldered banks that CANNOT be expanded, the full maximum-pixel-depth table, the PSC DMA controller and AT&T DSP3210, 86 W supply, and the 3.2 V lithium PRAM threshold; recorded that the volume has no Adjustments chapter)
     13:45  Macintosh Quadra 650 diffhist +1,708 Josh talk contribs (Apple Service Source: maximum RAM is 132 MB, not 136 MB (136 MB is the Quadra 800 figure); sound is monaural in / stereo out; added Apple's 112 W rating, three NuBus slots plus an inline PDS, on-board Ethernet, and the 3.2 V lithium PRAM threshold; recorded that the volume has no Adjustments chapter)
     13:45  Macintosh Quadra 610 DOS Compatible diffhist +3,312 Josh talk contribs (Apple Service Source: the DOS Compatible is a 68LC040, not a 68040 - Apple lists it separately from the plain Quadra 610 for exactly that reason; the DOS card's one 72-pin SIMM slot takes up to 64 MB, not 32 MB, and the card carries 512K of its own 80 ns video DRAM; sound is mono in / stereo-capable out, not 8-bit mono; added Apple's electrical, memory and battery (3.2 V) figures and the resolution of Apple's misprinted 4.2 in case depth)
     13:45  Macintosh Quadra 610 diffhist +3,299 Josh talk contribs (Apple Service Source: the page had sound the wrong way round - Apple gives one stereo-capable OUTPUT and one monaural INPUT; Apple offers the Quadra 610 with either the 68LC040 or the 68040 and the FPU comes only with the 68040; added Apple's 112 W rating, 68 MB maximum, VRAM 512K-1 MB, the single slot taking a PDS or 7-inch NuBus card, the 3.2 V lithium PRAM threshold, and the resolution of Apple's own misprinted 4.2 in depth (really 15.6 in, from the 660AV and 6100 volumes for the same chas...)
     13:45  Macintosh Quadra 605 diffhist +2,143 Josh talk contribs (Apple Service Source: case height and depth were wrong (Apple: 3.0 in H x 12.2 in W x 15.0 in D, 8.8 lb); sound input is mono with stereo output only; added Apple's 26 W maximum power, 512K ROM expandable to 1 MB, two 256K VRAM SIMMs to 1 MB, the 114-pin slot's explicit refusal of 030 accelerator and cache cards, the 3.0 V lithium PRAM threshold, and the fact that the volume has no Adjustments chapter at all)
     13:43  Power Macintosh 6500 diffhist +4,671 Josh talk contribs (Apple Service Source: the 6500 supply is 140 W maximum continuous, not 220 W (220 W is the 6400); processor is the 603ev; video goes to 1280x1024 at 8-bit and 32-bit at 800x600 on 2 MB of 88 MHz SGRAM, not '832x624 at 24-bit max'; the built-in speaker is a single mono full-range speaker/subwoofer; input is 90-130 or 180-264 VAC set manually on a voltage switch; L2 is 512K standard on the /275 and /300. Added the 3.0 V lithium PRAM threshold)
     13:43  Macintosh Performa 6420 diffhist +4,756 Josh talk contribs (Apple Service Source: the processor is a PowerPC 603ev, not a 603e; the DIMM specification differs between the Performa (168-pin fast-page 70 ns) and the Power Macintosh (168-pin EDO 60 ns) versions of the same machine; the 6420 ships with up to 24 MB and has 256K L2 as standard; the 6400/180 shipped a 4X AppleCD 600i and a 1.2 GB drive; the built-in speaker is a single MONO full-range speaker/subwoofer, stereo only via external speakers; and the input is 90-130 or 180-264 VAC set MANUALLY on...)
     13:43  Macintosh Performa 6410 diffhist +4,731 Josh talk contribs (Apple Service Source: the processor is a PowerPC 603ev, not a 603e; the DIMM specification differs between the Performa (168-pin fast-page 70 ns) and the Power Macintosh (168-pin EDO 60 ns) versions of the same machine; the 6420 ships with up to 24 MB and has 256K L2 as standard; the 6400/180 shipped a 4X AppleCD 600i and a 1.2 GB drive; the built-in speaker is a single MONO full-range speaker/subwoofer, stereo only via external speakers; and the input is 90-130 or 180-264 VAC set MANUALLY on...)
     13:43  Macintosh Performa 6400 diffhist +4,728 Josh talk contribs (Apple Service Source: the processor is a PowerPC 603ev, not a 603e; the DIMM specification differs between the Performa (168-pin fast-page 70 ns) and the Power Macintosh (168-pin EDO 60 ns) versions of the same machine; the 6420 ships with up to 24 MB and has 256K L2 as standard; the 6400/180 shipped a 4X AppleCD 600i and a 1.2 GB drive; the built-in speaker is a single MONO full-range speaker/subwoofer, stereo only via external speakers; and the input is 90-130 or 180-264 VAC set MANUALLY on...)
     13:43  Macintosh Performa 6118CD diffhist +3,648 Josh talk contribs (Apple Service Source: added Apple's figures for this logic board - 8 MB soldered to 72 MB in a matched pair of noncomposite 72-pin SIMMs, no VRAM (DRAM-based HDI-45 video), 132 W continuous / 201 W peak input and 86 W DC out, full 16-bit audio specification, single ADB port, mini DIN-9 GeoPort serial, and the 3.2 V lithium PRAM threshold requiring bicarbonate not vinegar)
     13:43  Macintosh Performa 6117CD diffhist +3,648 Josh talk contribs (Apple Service Source: added Apple's figures for this logic board - 8 MB soldered to 72 MB in a matched pair of noncomposite 72-pin SIMMs, no VRAM (DRAM-based HDI-45 video), 132 W continuous / 201 W peak input and 86 W DC out, full 16-bit audio specification, single ADB port, mini DIN-9 GeoPort serial, and the 3.2 V lithium PRAM threshold requiring bicarbonate not vinegar)
     13:43  Macintosh Performa 6116CD diffhist +3,648 Josh talk contribs (Apple Service Source: added Apple's figures for this logic board - 8 MB soldered to 72 MB in a matched pair of noncomposite 72-pin SIMMs, no VRAM (DRAM-based HDI-45 video), 132 W continuous / 201 W peak input and 86 W DC out, full 16-bit audio specification, single ADB port, mini DIN-9 GeoPort serial, and the 3.2 V lithium PRAM threshold requiring bicarbonate not vinegar)
     13:43  Macintosh Performa 6115CD diffhist +3,648 Josh talk contribs (Apple Service Source: added Apple's figures for this logic board - 8 MB soldered to 72 MB in a matched pair of noncomposite 72-pin SIMMs, no VRAM (DRAM-based HDI-45 video), 132 W continuous / 201 W peak input and 86 W DC out, full 16-bit audio specification, single ADB port, mini DIN-9 GeoPort serial, and the 3.2 V lithium PRAM threshold requiring bicarbonate not vinegar)
     13:43  Macintosh Performa 6112CD diffhist +3,648 Josh talk contribs (Apple Service Source: added Apple's figures for this logic board - 8 MB soldered to 72 MB in a matched pair of noncomposite 72-pin SIMMs, no VRAM (DRAM-based HDI-45 video), 132 W continuous / 201 W peak input and 86 W DC out, full 16-bit audio specification, single ADB port, mini DIN-9 GeoPort serial, and the 3.2 V lithium PRAM threshold requiring bicarbonate not vinegar)
     13:43  Macintosh Performa 6110CD diffhist +3,647 Josh talk contribs (Apple Service Source: added Apple's figures for this logic board - 8 MB soldered to 72 MB in a matched pair of noncomposite 72-pin SIMMs, no VRAM (DRAM-based HDI-45 video), 132 W continuous / 201 W peak input and 86 W DC out, full 16-bit audio specification, single ADB port, mini DIN-9 GeoPort serial, and the 3.2 V lithium PRAM threshold requiring bicarbonate not vinegar)
     13:43  Macintosh Performa 6100 diffhist +3,648 Josh talk contribs (Apple Service Source: added Apple's figures for this logic board - 8 MB soldered to 72 MB in a matched pair of noncomposite 72-pin SIMMs, no VRAM (DRAM-based HDI-45 video), 132 W continuous / 201 W peak input and 86 W DC out, full 16-bit audio specification, single ADB port, mini DIN-9 GeoPort serial, and the 3.2 V lithium PRAM threshold requiring bicarbonate not vinegar)
     13:43  Power Macintosh 6100 DOS Compatible diffhist +3,684 Josh talk contribs (Apple Service Source: maximum RAM is 72 MB in two paired SIMM sockets, not 136 MB (136 MB is the Quadra 800 / 5400 figure); a non-AV 6100 has NO VRAM at all - video is DRAM-based off an HDI-45 port, so 'replace the VRAM' is not a repair step here; added Apple's electrical figures (132 W continuous / 201 W peak input, 86 W DC out), 3.2 V lithium PRAM threshold, noncomposite paired SIMM requirement, mini DIN-9 GeoPort, single ADB port, and the DOS card's SX jumper check)
     13:43  Power Macintosh 6100 diffhist +3,684 Josh talk contribs (Apple Service Source: maximum RAM is 72 MB in two paired SIMM sockets, not 136 MB (136 MB is the Quadra 800 / 5400 figure); a non-AV 6100 has NO VRAM at all - video is DRAM-based off an HDI-45 port, so 'replace the VRAM' is not a repair step here; added Apple's electrical figures (132 W continuous / 201 W peak input, 86 W DC out), 3.2 V lithium PRAM threshold, noncomposite paired SIMM requirement, mini DIN-9 GeoPort, single ADB port, and the DOS card's SX jumper check)
     13:42  Macintosh Performa 600CD diffhist +2,485 Josh talk contribs (Apple Service Source: sound is monaural IN and stereo OUT, not 8-bit mono audio; added Apple's figures - three NuBus slots plus an accelerator slot, VRAM colour depths by capacity, 2.8 V lithium PRAM threshold (bicarbonate not vinegar), and the electrical split that matters: A/C line INPUT is 100-120 VAC at 200 W while the 100-240 VAC figure is the switched monitor outlet, so 220-240 V machines have a different supply)
     13:42  Macintosh Performa 600 diffhist +2,485 Josh talk contribs (Apple Service Source: sound is monaural IN and stereo OUT, not 8-bit mono audio; added Apple's figures - three NuBus slots plus an accelerator slot, VRAM colour depths by capacity, 2.8 V lithium PRAM threshold (bicarbonate not vinegar), and the electrical split that matters: A/C line INPUT is 100-120 VAC at 200 W while the 100-240 VAC figure is the switched monitor outlet, so 220-240 V machines have a different supply)
     13:42  Macintosh Performa 560 diffhist +3,355 Josh talk contribs (Apple Service Source: RAM on board is 4 MB, not 5 MB - 5 MB is the Performa 575/577 figure and there is no 1 MB SIMM; base machine is 8-bit at 640x480, 16-bit only with the 768K VRAM SIMM fitted; two ADB ports, not one; sound input is monaural; added Apple's 120 W supply, 13-inch viewable / 0.26 mm Trinitron figures, the 3.0 V lithium battery threshold, the absence of any voltage adjustment, and Apple's statement that the damper-wire line is not a fault. Moved the service-documentation sectio...)
     13:42  Macintosh Performa 550 diffhist +2,387 Josh talk contribs (Apple Service Source: RAM on board is 4 MB, not 5 MB - 5 MB is the Performa 575/577 figure and there is no 1 MB SIMM; base machine is 8-bit at 640x480, 16-bit only with the 768K VRAM SIMM fitted; two ADB ports, not one; sound input is monaural; added Apple's 120 W supply, 13-inch viewable / 0.26 mm Trinitron figures, the 3.0 V lithium battery threshold, the absence of any voltage adjustment, and Apple's statement that the damper-wire line is not a fault. Moved the service-documentation sectio...)
     13:42  Macintosh Performa 588CD diffhist +2,616 Josh talk contribs (Apple Service Source: added Apple's figures - 4 MB on board to 52 MB in two 72-pin SIMM sockets, 1 MB non-expandable VRAM, 11.5-inch viewable image, 120 W / 2.0 A supply on a 90-264 V rms input, 9-pin mini-DIN modem port, 22-pin external video connector, and the 3.0 V lithium PRAM threshold (bicarbonate, not vinegar). Sound is mono in / 8-bit stereo out)
     13:42  Macintosh Performa 588 diffhist +2,616 Josh talk contribs (Apple Service Source: added Apple's figures - 4 MB on board to 52 MB in two 72-pin SIMM sockets, 1 MB non-expandable VRAM, 11.5-inch viewable image, 120 W / 2.0 A supply on a 90-264 V rms input, 9-pin mini-DIN modem port, 22-pin external video connector, and the 3.0 V lithium PRAM threshold (bicarbonate, not vinegar). Sound is mono in / 8-bit stereo out)
     13:42  Macintosh Performa 580CD diffhist +2,616 Josh talk contribs (Apple Service Source: added Apple's figures - 4 MB on board to 52 MB in two 72-pin SIMM sockets, 1 MB non-expandable VRAM, 11.5-inch viewable image, 120 W / 2.0 A supply on a 90-264 V rms input, 9-pin mini-DIN modem port, 22-pin external video connector, and the 3.0 V lithium PRAM threshold (bicarbonate, not vinegar). Sound is mono in / 8-bit stereo out)
     13:42  Macintosh Performa 580 diffhist +2,616 Josh talk contribs (Apple Service Source: added Apple's figures - 4 MB on board to 52 MB in two 72-pin SIMM sockets, 1 MB non-expandable VRAM, 11.5-inch viewable image, 120 W / 2.0 A supply on a 90-264 V rms input, 9-pin mini-DIN modem port, 22-pin external video connector, and the 3.0 V lithium PRAM threshold (bicarbonate, not vinegar). Sound is mono in / 8-bit stereo out)
     13:40  Macintosh Quadra 630 diffhist +2,221 Josh talk contribs (Apple Service Source gives the Quadra 630 as a full 68040 WITH floating-point unit, not the 68LC040 the page claimed (the LC 630 is the 68LC040); sound is 8-bit mono in / 8-bit stereo out, not 16-bit stereo I/O; added the two logic-board SIMM variants, 1 MB ROM, no-internal-SCSI, slot pinouts, 45 W supply, and an honest note on the 4.5/5.4 battery discrepancy in Apple's own text)
     13:40  Macintosh Performa 640CD DOS Compatible diffhist +2,011 Josh talk contribs (Apple Service Source: the Macintosh side is a full 68040 with FPU, not a 68LC040; the DOS card ships with 4 MB and tops out at 32 MB (not 8 MB); Mac-side maximum is 52 MB; case width and depth were transposed; sound is 8-bit mono in / 8-bit stereo out; added the PDS adapter board with its PC/AT game-controller connector and the separate DOS-Compatible sound board)
     13:40  Macintosh Performa 638CDV diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:40  Macintosh Performa 637CD diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:40  Macintosh Performa 636CD diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:40  Macintosh Performa 636 diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:40  Macintosh Performa 635CD diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:40  Macintosh Performa 631CD diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:40  Macintosh Performa 630CD diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:40  Macintosh Performa 630 diffhist +3,316 Josh talk contribs (Apple Service Source: case width and depth were transposed across the 630 family (Apple: 16.5 in W x 12.6 in D); sound is 8-bit MONO input and 8-bit stereo output (16-bit only in CD mode), not 16-bit stereo in and out; added Apple's 45 W supply rating, 1 MB ROM, the two logic-board SIMM variants 661-0158 (36 MB) and 661-1114 (52 MB), the no-internal-SCSI statement and the slot pinouts; recorded that Apple's own volume misprints maximum power as 5 W)
     13:39  Macintosh Performa 6360 diffhist +2,120 Josh talk contribs (Apple Service Source: case width and depth were transposed; the 6360 has 16-bit STEREO input and output with SRS 3D Surround (not mono input) and one speaker, not two; supply is 150 W on a 90-270 VAC / 43-67 Hz input, not 220 W on 100-240 VAC; 256K L2 is standard not optional; PCI slot is 6.88-inch and replaces the PDS; added the 4.5 V battery pack and 3.0 V threshold)
     13:39  Power Macintosh 6300 diffhist +2,910 Josh talk contribs (Apple Service Source: case width and depth were transposed across this family (Apple: 16.5 in W x 12.6 in D); sound input is 16-bit MONO - the port accepts stereo but combines it - with 16-bit stereo output; added Apple's electrical figures, 256K standard L2, slot pinouts, and the 4.5 V battery pack with its 3.0 V replace-below threshold; noted the two errors in Apple's own text)
     13:39  Power Macintosh 6200 diffhist +2,910 Josh talk contribs (Apple Service Source: case width and depth were transposed across this family (Apple: 16.5 in W x 12.6 in D); sound input is 16-bit MONO - the port accepts stereo but combines it - with 16-bit stereo output; added Apple's electrical figures, 256K standard L2, slot pinouts, and the 4.5 V battery pack with its 3.0 V replace-below threshold; noted the two errors in Apple's own text)
     13:39  Macintosh Performa 6320CD diffhist +2,850 Josh talk contribs (Apple Service Source: case width and depth were transposed across this family (Apple: 16.5 in W x 12.6 in D); sound input is 16-bit MONO - the port accepts stereo but combines it - with 16-bit stereo output; added Apple's electrical figures, 256K standard L2, slot pinouts, and the 4.5 V battery pack with its 3.0 V replace-below threshold; noted the two errors in Apple's own text)
     13:39  Macintosh Performa 6310CD diffhist +2,850 Josh talk contribs (Apple Service Source: case width and depth were transposed across this family (Apple: 16.5 in W x 12.6 in D); sound input is 16-bit MONO - the port accepts stereo but combines it - with 16-bit stereo output; added Apple's electrical figures, 256K standard L2, slot pinouts, and the 4.5 V battery pack with its 3.0 V replace-below threshold; noted the two errors in Apple's own text)
     13:39  Macintosh Performa 6300CD diffhist +2,850 Josh talk contribs (Apple Service Source: case width and depth were transposed across this family (Apple: 16.5 in W x 12.6 in D); sound input is 16-bit MONO - the port accepts stereo but combines it - with 16-bit stereo output; added Apple's electrical figures, 256K standard L2, slot pinouts, and the 4.5 V battery pack with its 3.0 V replace-below threshold; noted the two errors in Apple's own text)
     13:39  Macintosh Performa 6300 diffhist +2,850 Josh talk contribs (Apple Service Source: case width and depth were transposed across this family (Apple: 16.5 in W x 12.6 in D); sound input is 16-bit MONO - the port accepts stereo but combines it - with 16-bit stereo output; added Apple's electrical figures, 256K standard L2, slot pinouts, and the 4.5 V battery pack with its 3.0 V replace-below threshold; noted the two errors in Apple's own text)
     13:39  Macintosh Performa 6290CD diffhist +2,910 Josh talk contribs (Apple Service Source: case width and depth were transposed across this family (Apple: 16.5 in W x 12.6 in D); sound input is 16-bit MONO - the port accepts stereo but combines it - with 16-bit stereo output; added Apple's electrical figures, 256K standard L2, slot pinouts, and the 4.5 V battery pack with its 3.0 V replace-below threshold; noted the two errors in Apple's own text)
