Apple High Resolution Monochrome Monitor Troubleshooting Guide
Rear view from Apple's Service Source
Fault-finding on the Apple High-Resolution Monochrome Monitor from Apple's Service Source symptom charts. Apple lists cures in order of likelihood: try the first, check whether the symptom remains, and if a module swap does not cure it, refit the original module before trying the next cure.[1]
Read CRT Discharge Procedure before opening the monitor, and Apple High Resolution Monochrome Monitor General Maintenance for the take-apart and adjustments.
Symptom charts
Apple High-Resolution Monochrome Monitor symptom charts (Service Source pp. 2-6)
Symptom Cures, in order
No raster, LED off Check the video cable to the computer or video card; check the power cord; check the internal power connectors; replace the fuse; the power supply; the power switch
No raster, LED on Check the video cable; adjust brightness and contrast; replace the computer's video card if fitted; adjust sub-brightness (cutoff); check the logic board connection to the power supply; replace the fuse; the main board; the power supply; the power switch assembly; video board C; the contrast control board
Raster stretched or compressed at a side or the top Check whether the distortion comes from the surroundings; do the geometry adjustments; replace the main board; the CRT
Picture breaks into diagonal lines Check the computer's video signal on another monitor; replace the main board
Picture rolls vertically Check the computer's video card; adjust vertical hold; check the connector on the I/O connector board; replace the main board
One horizontal or vertical line Check the yoke connectors; replace the main board; the CRT
Picture too dark or too bright Adjust the brightness knob; check the video card; adjust sub-brightness (cutoff); replace the main board; video board C; the CRT
Brightness will not adjust Replace the contrast control board; the main board; video board C; the CRT
Out of focus Do the focus adjustment; replace the main board; video board C; the CRT
Picture jitters Check the grounding cable connections to the chassis; check that nearby computer equipment is properly grounded, move electrical devices away and turn off fluorescent lights for a test; replace the main board
Flashing lines on the screen Check the contact of the video connector on the CRT neck; replace the contrast control board; the main board
Black spots (burnt phosphor) Replace the CRT
Notes
  • The monitor runs at one fixed timing: 640 × 480, 35.0 kHz horizontal, 66.7 Hz vertical.[2] Apple's charts check the card before the monitor.[1]
  • Shut-down while setting the cutoff control is the monitor's protection. Turn cutoff fully anticlockwise, wait 30 seconds and start again.[3]
  • Video board C is mounted on the tube neck; twisting it while removing it can crack the neck.[4]
  • If the Service Source charts do not settle it, Apple refers to its flowchart for the product family and to Apple Technical Support.[1] The 1987 Technical Procedures have their own symptom chart.[5]
  1. ↑ 1.0 1.1 1.2 Apple Computer, Apple High-Resolution Monochrome Monitor (Service Source), Troubleshooting, General and Symptom Charts, pp. 1-6 (PDF pp. 9-14). Hosted here: File:Highres monochrome monitor.pdf (see Apple High-Res Service Source).
  2. ↑ Apple High-Resolution Monochrome Monitor Service Source, Specifications, Characteristics, pp. 1-2 (PDF pp. 3-4).
  3. ↑ Apple High-Resolution Monochrome Monitor Service Source, Adjustments, Video, p. 12 (PDF p. 62).
  4. ↑ Apple High-Resolution Monochrome Monitor Service Source, Take Apart, Video Board C, p. 23 (PDF p. 38).
  5. ↑ Apple Computer, High-Res Monochrome Monitor Technical Procedures, 1987, Section 4, Troubleshooting. Hosted here: File:Apple High-Res Monochrome Monitor Technical Procedures.pdf.
