Apple Color StyleWriter 2200 Troubleshooting Guide
Fault-finding for the Apple Color StyleWriter 2200, taken from the symptom charts in Apple's Color StyleWriter 2200 Service Source.[1] Apple lists the cures in order of likelihood. Try the first, check whether the symptom has gone, and move to the next only if it has not; if a module was swapped and did not help, refit the original before trying the next cure.[1]
The printer has two LEDs, power and error. With the printer connected to a Macintosh running the printer software, the driver also names the fault.[1] Routine procedures referred to below (nozzle check, head cleaning, roller cleaning tool, waste ink reset) are on the general maintenance page.
Driver messages
[edit | edit source]| Message | Symptom |
| Out of paper | Paper pickup error |
| Paper jam | Paper jam |
| Ink cartridge jam | Carriage control error |
| Obstruction, clear and try again | Cleaning error |
| Problem with host computer | Host originated error |
| Cartridge needs to be replaced | Head temperature sensor error |
| Check connector and try again | Temperature sensor error |
| Cartridge not installed properly | Cartridge error |
| Check connectors and try again | ROM/RAM error |
| Waste ink absorbers full | Waste ink full error |
| Battery low, recharge battery | Battery error |
| Door open | Door open error |
Error conditions
[edit | edit source]| Symptom | Cures, in Apple's order |
| Paper pickup error | Add paper. Use only specified media. Check the Page Setup settings. Fan the paper before loading it. Use the pickup roller cleaning tool |
| Paper jam | Check the eject roller for obstructions or damage; clean or replace it. Use the pickup roller cleaning tool |
| Carriage control error | Make sure the ink tank is latched securely |
| Temperature sensor error | Check the cable connections. Replace the logic board |
| Cleaning error | Check the eject roller for obstructions or damage; clean or replace it. Use the pickup roller cleaning tool |
| Cartridge error | Make sure the cartridge and tanks are firmly seated, the latches secure and the cartridge clear of the cover plastic. Replace the cartridge |
| ROM/RAM error | Check the cable connections. Reinstall the printer software. Replace the logic board |
| Waste ink full error | Replace the print unit assembly (661-0240), then reset the waste ink count in the EEPROM |
| Head temperature error | Replace the ink cartridge |
The symptom charts say "logic board"; the exploded view calls the same module the controller board (661-0257).[1]
Power and operation
| No power | Check the power cable connections. Replace the power cord. Replace the controller board |
| Does not print | Switch the printer on and restart the computer. Check the interface cable. In the Chooser, check that the right driver and port are selected. Replace the printer driver |
| Carriage does not move to the centre when the front door is opened with the printer on | Make sure the covers are securely closed. Check the carriage for obstructions. Replace the controller board |
A low battery pack gives the "Battery low, recharge battery" message.[1] The Service Source gives no output voltage for the AC adapter (922-1281 for 110 V).
Paper handling
| Paper sticks together | Remove excess sheets. Use only specified media. Check Page Setup. Fan the paper |
| Paper skews | Remove excess sheets. Use only specified media. Stack the paper against the left side of the tray and set the guide. Check the sheet feeder rollers and eject roller; clean or replace them |
| Jam while loading, before printing | Remove the paper carefully by hand |
| Jam inside the printer | Pull the paper out carefully in the direction of output |
| Jam during output, after printing | Pull the paper out in the direction of output. Check the eject roller for obstructions or damage; clean or replace it |
| Misfeeds or multiple sheets | Use the pickup roller cleaning tool. Repeat the cleaning. Refer the customer to Apple Assist |
Print quality
| Missing dots or white streaks | Run the nozzle check and print head cleaning. Make sure the cartridges are set firmly. Use only specified media. Replace the cartridge. Replace the logic board |
| Blurring or smudging | Use only specified media. Clean the print head. Replace the cartridge |
| Missing dots followed by a blob of ink | Set the print quality to Best in the driver before printing |
| Vertical lines distorted or wavy | Open and close the blue lever next to the cartridge so that the cartridge seats properly |
| Poor image at the bottom of the page | Increase the bottom margin to at least 0.8 in |
The print head is built into each cartridge, which is why Apple's chart replaces the cartridge before the logic board.[1]
[edit | edit source]- Apple Color StyleWriter 2200
- Apple Color StyleWriter 2200 General Maintenance
- Color StyleWriter 2200 Service Source
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Apple Computer, Color StyleWriter 2200 (Service Source), 93 pp., hosted as Color StyleWriter 2200 Service Source (PDF). Page numbers are PDF pages. Troubleshooting: general p. 21, error messages and LEDs pp. 22-24, symptom charts for paper pp. 25-26, operation p. 27, print quality pp. 28-29 and error LEDs pp. 30-31; nozzle check pp. 73-76; print head cleaning pp. 77-81; pickup roller cleaning tool pp. 82-88; waste ink reset pp. 89-91; exploded view p. 93.
