Apple Color StyleWriter 2200 Troubleshooting Guide
Revision as of 11:29, 2 October 2026 by Josh (talk | contribs) (New page: Apple's symptom charts and driver messages for the Color StyleWriter 2200)
Color StyleWriter 2200 (photo: Scott Hoffman, CC BY-SA 2.0)
Fault-finding for the Apple Color StyleWriter 2200, taken from the symptom charts in Apple's Color StyleWriter 2200 Service Source.[1] Apple lists the cures in order of likelihood. Try the first, check whether the symptom has gone, and move to the next only if it has not; if a module was swapped and did not help, refit the original before trying the next cure.[1]
The printer has two LEDs, power and error. With the printer connected to a Macintosh running the printer software, the driver also names the fault.[1] Routine procedures referred to below (nozzle check, head cleaning, roller cleaning tool, waste ink reset) are on the general maintenance page.
Driver messages
Driver messages and the symptom they correspond to (Service Source, p. 24)[1]
Message Symptom
Out of paper Paper pickup error
Paper jam Paper jam
Ink cartridge jam Carriage control error
Obstruction, clear and try again Cleaning error
Problem with host computer Host originated error
Cartridge needs to be replaced Head temperature sensor error
Check connector and try again Temperature sensor error
Cartridge not installed properly Cartridge error
Check connectors and try again ROM/RAM error
Waste ink absorbers full Waste ink full error
Battery low, recharge battery Battery error
Door open Door open error
Error conditions
Error LED symptom chart (Service Source, pp. 30-31)[1]
Symptom Cures, in Apple's order
Paper pickup error Add paper. Use only specified media. Check the Page Setup settings. Fan the paper before loading it. Use the pickup roller cleaning tool
Paper jam Check the eject roller for obstructions or damage; clean or replace it. Use the pickup roller cleaning tool
Carriage control error Make sure the ink tank is latched securely
Temperature sensor error Check the cable connections. Replace the logic board
Cleaning error Check the eject roller for obstructions or damage; clean or replace it. Use the pickup roller cleaning tool
Cartridge error Make sure the cartridge and tanks are firmly seated, the latches secure and the cartridge clear of the cover plastic. Replace the cartridge
ROM/RAM error Check the cable connections. Reinstall the printer software. Replace the logic board
Waste ink full error Replace the print unit assembly (661-0240), then reset the waste ink count in the EEPROM
Head temperature error Replace the ink cartridge
The symptom charts say "logic board"; the exploded view calls the same module the controller board (661-0257).[1]
Power and operation
Operation symptom chart (Service Source, p. 27)[1]
No power Check the power cable connections. Replace the power cord. Replace the controller board
Does not print Switch the printer on and restart the computer. Check the interface cable. In the Chooser, check that the right driver and port are selected. Replace the printer driver
Carriage does not move to the centre when the front door is opened with the printer on Make sure the covers are securely closed. Check the carriage for obstructions. Replace the controller board
A low battery pack gives the "Battery low, recharge battery" message.[1] The Service Source gives no output voltage for the AC adapter (922-1281 for 110 V).
Paper handling
Paper symptom chart (Service Source, pp. 25-26)[1]
Paper sticks together Remove excess sheets. Use only specified media. Check Page Setup. Fan the paper
Paper skews Remove excess sheets. Use only specified media. Stack the paper against the left side of the tray and set the guide. Check the sheet feeder rollers and eject roller; clean or replace them
Jam while loading, before printing Remove the paper carefully by hand
Jam inside the printer Pull the paper out carefully in the direction of output
Jam during output, after printing Pull the paper out in the direction of output. Check the eject roller for obstructions or damage; clean or replace it
Misfeeds or multiple sheets Use the pickup roller cleaning tool. Repeat the cleaning. Refer the customer to Apple Assist
Print quality symptom chart (Service Source, pp. 28-29)[1]
Missing dots or white streaks Run the nozzle check and print head cleaning. Make sure the cartridges are set firmly. Use only specified media. Replace the cartridge. Replace the logic board
Blurring or smudging Use only specified media. Clean the print head. Replace the cartridge
Missing dots followed by a blob of ink Set the print quality to Best in the driver before printing
Vertical lines distorted or wavy Open and close the blue lever next to the cartridge so that the cartridge seats properly
Poor image at the bottom of the page Increase the bottom margin to at least 0.8 in
The print head is built into each cartridge, which is why Apple's chart replaces the cartridge before the logic board.[1]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Apple Computer, Color StyleWriter 2200 (Service Source), 93 pp., hosted as Color StyleWriter 2200 Service Source (PDF). Page numbers are PDF pages. Troubleshooting: general p. 21, error messages and LEDs pp. 22-24, symptom charts for paper pp. 25-26, operation p. 27, print quality pp. 28-29 and error LEDs pp. 30-31; nozzle check pp. 73-76; print head cleaning pp. 77-81; pickup roller cleaning tool pp. 82-88; waste ink reset pp. 89-91; exploded view p. 93.
