Apple 12" RGB Display Troubleshooting Guide
Fault-finding for the Macintosh 12" RGB Display: Apple's symptom charts first, then faults that owners have found and repaired at component level. Apple lists cures in order of likelihood; refit the original module before the next cure if a replacement did not help.[1] Boards and tubes come in Rev. A and Rev. B versions that must not be mixed; see Revisions.
Discharge the CRT before working inside; see CRT Discharge Procedure. Apple's take-apart procedures start by discharging the CRT and removing the anode cap, and warn never to wear a grounding wrist strap until it has been discharged.[2]
[edit | edit source]| Symptom | Cures, in Apple's order |
| No raster, LED off | Check the video cable. Check the power cord. Check the internal power connectors. Replace a blown fuse. Replace the external power cable assembly. Replace the main deflection board |
| No raster, LED on | Check the video cable. Adjust contrast and brightness. Check the video card. Check the main deflection board and CRT/video board connectors. Replace a blown fuse. Do the screen voltage adjustment. Replace the main deflection board. Replace the CRT/video board. Replace the CRT |
| Raster short, tall, narrow or wide | Adjust V-HEIGHT or H-WIDTH on the main deflection board. Replace the main deflection board. Replace the CRT |
| Raster not centred | Move the display to rule out the environment. Adjust H-CENT or V-CENT. Replace the main deflection board |
| Horizontal linearity bad | Replace the main deflection board |
| Vertical linearity bad | Adjust V-LIN. Replace the main deflection board |
| Raster bows | Move the display. Check V-HEIGHT, V-CENT, H-WIDTH and H-CENT. Some bowing from the environment is within tolerance. Replace the main deflection board. Replace the CRT |
| Whole raster tilted | Move the display. Switch off, remove the rear cover, loosen the frontmost screw on the CRT neck, twist the yoke and retighten (not too tight, or the neck can break). Replace the main deflection board |
| Other distortion | Move the display. Check all cables. Do the geometry adjustments. Replace the main deflection board, then the CRT/video board, then the CRT |
| Picture breaks into diagonal lines | Try another monitor to check the video signal. Adjust H-HOLD. Replace the main deflection board |
| Picture rolls vertically | Check the video card. Adjust V-HOLD. Replace the main deflection board |
| Single vertical or horizontal line | Check yoke connector DY. Replace the main deflection board. Replace the CRT |
| Predominant red, blue or green tint | Check the video cable. Check the video card. Do the white balance adjustment. Replace the CRT/video board. Replace the CRT |
| Picture too dark or too bright | Adjust contrast and brightness. Check the video card. Do the cutoff and white balance adjustments. Replace the main deflection board, then the CRT/video board, then the CRT |
| Cannot adjust brightness, contrast or colour | Replace the contrast/brightness assembly. Replace the main deflection board. Replace the CRT/video board |
| Out of focus | Adjust the focus control on the flyback transformer. Do the screen voltage adjustment. Replace the main deflection board. Replace the CRT |
| Shuts down intermittently | Check the video cable. Replace the main deflection board |
| Picture jitters or flashes | Check the ground cables. Check nearby equipment is grounded, move electrical devices away and switch off fluorescent lights. Replace the main deflection board |
| Flashing or wavy screen | Crimp the metal tabs on the video connector. Replace the main deflection board |
| Black spots (burnt phosphor) | Replace the CRT |
The adjustments named are on the general maintenance page.
Fuse
[edit | edit source]The fuse is F901 on the main deflection board. Remove the rear cover, discharge the CRT and remove the anode cap, then lever the fuse out of its holder with a small flat-blade screwdriver.[3] Apple lists it only as part 941-5222, without a rating.[4]
Faults found by repairers
[edit | edit source]Apple treated the main deflection board as a module. Owners repairing these boards today report the following; they are individual repairs, not Apple data.
- A collector who keeps many of these displays reports that distortion in the upper part of the picture is cured by replacing capacitors on the main deflection board, and that focus which goes soft after about 30 minutes points to the flyback transformer, which has the focus control built in and is replaced as a unit.[5]
- No picture, no power light and a high-pitched whine after a recap: in one repair the board had been corroded by electrolyte leaking from the capacitors around C418 and C419, which sit next to the large resistors R525 and R534 near the board edge. Transistor Q501 had failed (it tested as a resistor). Before the repair the 80 V test point read 13 V, the 12 V test point 1.5 V, and the +12 V feed to the flyback 0 V; replacing Q501 with a KSC2383 restored all three.[6]
The same repairer replaced R525 and R534, bridged the thin underside trace between them with solder, bent the resistors away from the capacitors and shielded the capacitors with Kapton tape, because the resistors run hot and cook the capacitors beside them. Scrape any corrosion back to bright copper and seal the area afterwards.[6]
When swapping boards between displays, one collector matches donor boards to a display made in the same month, because the CRT and board pairings changed during production.[5]
[edit | edit source]- Apple 12" RGB Display
- Apple 12" RGB Display General Maintenance
- Macintosh 12 RGB Display Service Source
- Capacitor Failure Symptoms
- CRT Discharge Procedure
[edit | edit source]- ↑ 1.0 1.1 1.2 Apple Computer, Macintosh 12" RGB Display (Service Source), hosted as File:12 rgb display.pdf. Troubleshooting: general p. 1, symptom charts pp. 2-10 (PDF pp. 9-18).
- ↑ Macintosh 12" RGB Display Service Source, Take Apart, pp. 1-46 (PDF pp. 20-65).
- ↑ Macintosh 12" RGB Display Service Source, Take Apart, Fuse, pp. 8-9 (PDF pp. 27-28).
- ↑ Macintosh 12" RGB Display Service Source, Exploded View (PDF p. 113).
- ↑ 5.0 5.1 Macintosh 12" RGB Display M1296 - Observations and Questions, TinkerDifferent forum (Scott), 2026-06-29—link(accessed 2026-10-02)
- ↑ 6.0 6.1 Macintosh 12" RGB Display Repair - Need some help, TinkerDifferent forum (jibsaramnim, MacMaster), 2026-03—link(accessed 2026-10-02)
