Apple Hard Disk 160SC
Revision as of 13:13, 4 October 2026 by Josh (talk | contribs) (New page: Apple Hard Disk 160SC, from Apple Tech Info Library specifications and Apple Technical Procedures)
Apple's drawing of the case shared by the 20SC, 40SC, 80SC and 160SC
Type External SCSI hard disk drive
Interface SCSI, external DB-25 port of the Macintosh
Compatible Macintosh Plus, Macintosh SE, Macintosh SE/30, Macintosh II, Macintosh IIx, Macintosh IIcx
Dimensions 246 × 78 × 266 mm (9.7 × 3.1 × 10.5 in)
Weight 4.3 kg (9.5 lb)
Power 85-270 V AC, 47-64 Hz, 60 W maximum
Storage 160 MB formatted
The Apple Hard Disk 160SC is Apple's 160 MB external SCSI hard disk. It uses the case of the 20SC, 40SC and 80SC, with some parts of its own.[1] It connects directly to the external SCSI port of the Macintosh Plus, SE, SE/30, II, IIx and IIcx.[2] Inside is a half-height 5.25-inch drive; Apple sold the same 160 MB mechanism as an internal option for the Macintosh II and IIx.[3] The case, take-apart and repair are covered on Apple Hard Disk SC General Maintenance and Apple Hard Disk SC Troubleshooting Guide.
Apple's 1994 Apple External Hard Drive, built by La Cie, also came in a 160 MB model with "160SC" on its front panel. It is a different, later drive in a vertical case.[4]
Hard Disk 160SC specifications (Apple Tech Info Library article 6949)[2]
Item Value
Formatted capacity 160 MB
Data surfaces 5, one head per surface
Block size 512 bytes
Total blocks 327,780
Blocks per track 32 to 54
Average seek time 18 ms
Rotational speed 3,600 rpm
Start-up and spin-down 20 s each
Line voltage 85-270 V AC, 47-64 Hz
Maximum power 60 W
Operating temperature 10-40 °C (50-104 °F)
Storage temperature 0-50 °C (32-122 °F)
Relative humidity 20-80 %, non-condensing
Height × width × depth 7.8 × 24.6 × 26.6 cm (3.1 × 9.7 × 10.5 in)
Differences from the smaller models
Apple's parts list gives the 160SC its own versions of several case parts: a platinum case top (630-5802), case bottom (630-5647), hard disk frame (805-5081), an end bracket with the LED cable (076-0380), fan (699-5017) and drive-to-case cable (590-4037). The external 160 MB hard disk assembly is 661-0584.[1]
  • The LED cable comes off the end bracket with four screws, and Apple calls for a small Torx screwdriver for them.[1]
  • Like the external 20 MB drive, the external 160 MB service module ships in a frame that fits the external case and needs no reconfiguring. Apple's other external modules have to be converted from their internal configuration first.[1]
  • Apple also made a 3.5-inch 160 MB drive (661-0625), but only as an internal drive for the Macintosh IIci and IIfx.[1]
Apple II
Apple's documents disagree on whether the 160SC works with an Apple II. The 1989 announcement article says it cannot be used with the Apple II family, and the drive matrix in Apple's 1991 service procedures marks the 160 MB drives as Macintosh only.[3][1] The same service procedures also say any Apple SCSI drive can be connected to an Apple II SCSI card, but that the four-partition limit of ProDOS leaves much of a 160SC's capacity out of reach.[1]
Termination
A Tech Info Library article describes a Macintosh IIci with an internal drive that would not start once an external Apple 160 MB drive was added, although a 40 MB drive worked in its place. Apple's suggestions were to switch the external drive on before the Macintosh, set its SCSI ID to a number from 1 to 6, try it on another Macintosh without an internal drive, and swap the cable and terminator.[5]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Apple Computer, Apple Service Technical Procedures, Cross Family Peripherals, Volume One (PN 072-0230, 1991), SCSI Hard Disk Drives chapter, hosted as File:Apple Service Technical Procedures Cross Family Peripherals Volume One Apr 1991.pdf and described at Apple Service Technical Procedures Cross Family Peripherals Volume One. Basics, p. 1.3 (PDF p. 178): drive matrix and the 3.5-inch 160 MB drive in the IIfx and IIci; p. 1.10 (PDF p. 185): the four-partition limit; Take-Apart, pp. 2.2-2.3, 2.10 and 2.17 (PDF pp. 188-189, 196, 203): service modules and the LED cable; Illustrated Parts List, IPL.3, IPL.5 and IPL.9 (PDF pp. 256, 258, 262).
  2. ↑ 2.0 2.1 Apple Computer, "Apple HD 160SC: Specifications (Discontinued)", Tech Info Library article 6949, created 14 March 1991, revised 13 September 1993, in the archive.org collection Apple's Technical Information Library Articles, https://archive.org/details/APPLE_TIL_ARTICLES, file TIL00001_to_TIL60496.zip. Source for every figure in the specification table and the list of Macintosh models.
  3. ↑ 3.0 3.1 Apple Computer, "5.25-Inch 160MB SCSI Hard Disk Drive", Tech Info Library article 3514, copyright 1989, revised 11 April 1991, APPLE_TIL_ARTICLES collection (archive.org), file TIL00001_to_TIL60496.zip. Source for the half-height 5.25-inch form factor, the internal option in the Macintosh II and IIx, testing with the Macintosh OS and A/UX, the statement that the drive cannot be used with the Apple II family, and the 1.25 MB/s transfer rate.
  4. ↑ La Cie, Ltd., advertisement for the Apple External Hard Drive, 1994, hosted as File:Apple External Hard Drive advertisement (1994).jpg.
  5. ↑ Apple Computer, "SCSI Termination and External Hard Drives", Tech Info Library article 8140, created 14 May 1991, revised 6 September 1991, APPLE_TIL_ARTICLES collection (archive.org), file TIL00001_to_TIL60496.zip.
