Apple Color OneScanner 600/27 General Maintenance
Apple Color OneScanner 1200/30, which shares its case and mechanism with the 600/27 (Apple data sheet, 1996)
The Apple Color OneScanner 600/27 and Apple Color OneScanner 1200/30 need little routine care: clean glass, a locked carriage whenever the scanner is moved, careful handling of the optical assembly, and correct SCSI settings. Apple's user's manual covers the owner's side and the Service Source chapters the service side; both apply to the two models.[1][2][3] Faults are worked through in the Apple Color OneScanner 600/27 Troubleshooting Guide.
Carriage lock
The carriage is locked for shipping and the scanner will not work while it is locked. To unlock it, lift off the top cover by gripping both sides, turn the lock at the top of the glass 90 degrees with a coin or flat-blade screwdriver, and refit the cover. The small arrow on the lock's dial shows the position, not the screwdriver slot. Relock it before moving or shipping the scanner.[4][2] Do not tip the scanner on its side or turn it upside down.[1]
Cleaning
Apple's cleaning procedure:[1]
  1. Switch off the scanner and the computer and unplug the scanner.
  2. Dampen a cloth with water or a mild cleaner and wring it out thoroughly.
  3. Wipe the document glass, the cover and the outside of the case.
  4. Dry the damp areas with a clean, soft, dry cloth, and wipe dust from the power socket and connectors with a dry cloth.
Do not spray water or cleaner onto the glass: it can run underneath and contaminate the mirrors and lenses. Do not use chemically treated cloths or cleaners containing alcohol, benzene or ammonia, which can discolour or melt the case, and do not lubricate the scanner.[1] Apple's service charts start blurred or streaked images with a wipe of the glass using a soft dry cloth, then a check of the white plate under the glass and of the mirrors for dust.[2][3]
Optical assembly
The optical assembly carries the xenon lamp, two mirrors and the CCD board. Apple warned its service staff that assemblies were being damaged during removal. Lift the assembly only by its long sides. The CCD board on the short front side is delicate, and touching it or the mirrors can leave the scanner not working.[2] Dust on the mirrors shows as black arcs on 600/27 scans; Apple's advice was to have the optical assembly cleaned by a service provider.[5] The lamp is part of the optical assembly and is not sold separately. Apple rated it for 100,000 scans or five years.[6]
Moving the optical assembly to the service position
To reach parts under the carriage, Apple moves it with the SCSI ID switch:[2]
  1. Remove the top cover with hinge. Leave the power cord connected, switch the scanner off and disconnect the SCSI cable.
  2. Set the SCSI ID switch to 7 (termination off position) and switch on. Wait for the start-up sequence to finish and the lamp to go out.
  3. Set the switch to 0 (termination on position), then back to 7, back to 0 and finally back to 7.
  4. The optical unit moves. Switch off when the mirror is between the set of four screws on the bottom.
SCSI settings
The scanner has built-in termination and two SCSI connectors. The ID selector between the connectors has two sets of numbers: black for termination off, used when an external terminator is fitted, and red for termination on. The factory setting is ID 2 with termination on.[7][2] Do not give the scanner ID 0 or 7. A Macintosh IIfx needs its special terminator with the scanner's termination off, and a PowerBook needs an external terminator; other Macintosh models need no external terminator when the scanner is the only or last device.[1] If the selector's label is misaligned, set it to 12 o'clock and count clicks clockwise.[8] Always switch the scanner on before the Macintosh.[1]
Document feeder
Clean the feeder with a wrung-out damp cloth and dry it, as for the scanner. If the delivery guide sheet under the feeder gets dirty, or vertical black lines appear in feeder scans, wipe both sides of the sheet with a soft dry cloth. The delivery guide sheet and the paper separator are both user-replaceable: a separator that keeps feeding two sheets or none needs replacing.[1] The service parts are the delivery guide sheet 922-2048, paper separator 922-2047 and deflector 922-2049.[2] Before using the feeder, check the glass is clear, or the scan comes out blank or striped.[9]
Transparent Media Adapter (1200/30)
The adapter's diffuser, its smooth underside, scratches easily and scratches show in every film scan. Clean it only with a dry, soft cloth and light pressure, never with alcohol, benzene or ammonia cleaners. Keep staples and clips away from it when scanning paper with the adapter fitted.[1]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Apple Computer, Apple Color OneScanner User's Manual for the Color OneScanner 600/27 and 1200/30, 1996. Hosted as File:Apple Color OneScanner 600-27 and 1200-30 User's Manual (1996).pdf. Chapter 1 system requirements p. 2; chapter 2 set-up, locking, SCSI ID and termination pp. 5-17; chapter 8 cleaning pp. 111-112; chapter 9 document feeder maintenance pp. 129-136; chapter 10 Transparent Media Adapter (1200/30 only) from p. 137; Appendix B troubleshooting pp. 155-158; Appendix C SCSI chains pp. 159-164.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Apple Computer, Service Source: Color OneScanner 600/27, PDF dated February 1996, from the Service Source 2.5 CD of 1997. Hosted as File:Apple Color OneScanner 600-27 Service Source (1996).pdf. Basics PDF pp. 3-9 (overview, features, optical assembly handling precautions); Specifications pp. 11-14; Troubleshooting pp. 16-27 (wiring diagram, normal start-up sequence, general troubleshooting with J101 voltages, image defects); Take Apart pp. 29-77; Additional Procedures pp. 79-86 (unlocking, SCSI ID, optical assembly to service position); Exploded View p. 88.
  3. ↑ 3.0 3.1 Apple Computer, Apple Color OneScanner 1200/30 (Service Source), 97 pages. Hosted as File:Color onescanner 1200 30.pdf and described on Apple Color OneScanner 1200/30 Service Source. Specifications PDF pp. 12-16; Troubleshooting pp. 18-31 (wiring diagram, normal start-up sequence, J101 voltages, symptom charts for the scanner, image defects, the document feeder and the Transparent Media Adapter); Take Apart pp. 33-86; Additional Procedures pp. 88-95; Exploded View p. 97.
  4. ↑ Apple Computer, Tech Info Library article 19448, "Color OneScanner 600/27: Chattering Sound due to Lock", created 5 March 1996, updated 29 April 1996. Copy at absurdengineering.org. Unlocking and relocking the carriage: top cover off, lock at the top of the glass turned 90 degrees; the arrow on the dial shows the position; relock before moving or shipping.
  5. ↑ Apple Computer, Tech Info Library article 19451, "Color OneScanner 600/27: Cause of Black Arcs on Pages", created 6 March 1996, updated 12 March 1996. Copy at absurdengineering.org. Black arcs on scans are dust on the two mirrors; an Apple service provider should inspect and clean the optical assembly.
  6. ↑ Apple Computer, Tech Info Library article 20065, "Color OneScanner 600/27: Expected Lamp Life", created 20 June 1996. Copy at absurdengineering.org. White xenon lamp designed for 100,000 scans or five years; supplied only as part of optical assembly 661-1084.
  7. ↑ Apple Computer, Tech Info Library article 19550, "Apple Color OneScanner 600/27: Terminator isn't required", created 1 April 1996, updated 17 April 1996. Copy at absurdengineering.org. Built-in termination; selector between the two SCSI ports; black numbers termination off, red numbers termination on; default ID 2 termination on.
  8. ↑ Apple Computer, Tech Info Library article 19455, "Color OneScanner 600/27: SCSI Selector Has Wrong SCSI ID", created 6 March 1996, updated 12 March 1996. Copy at absurdengineering.org. Misaligned SCSI selector label: set to 12 o'clock and count clicks clockwise.
  9. ↑ Apple Computer, Tech Info Library article 19452, "Color OneScanner 600/27: Blank Scans With Document Feeder", created 6 March 1996, updated 12 March 1996. Copy at absurdengineering.org. Paper left on the glass gives blank pages or vertical patterns with the feeder.
