Macintosh Performa 5200
Revision as of 23:04, 23 September 2026 by Josh (talk | contribs) (Collapse duplicate named-ref definitions to a single definition per ref)
ReleasedApril 1995
Discontinued1996
Intro priceN/A
CPUPowerPC 603 @ 75 MHz
Memory8 MB RAM (expandable to 64 MB)
Storage500 MB IDE hard drive, 1.44 MB floppy
Display15" shadow mask CRT (640ร—480 @ 16-bit, 832ร—624 @ 8-bit)
Sound16-bit monophonic input, 16-bit stereophonic output, nominally 0.5 V RMS into 39 ohms
Dimensions17.5" H ร— 16.0" W ร— 15.1" D (44.5 ร— 40.6 ร— 38.4 cm)
Weight21.15 kg (approx. 47 lb)
OS / FirmwareSystem 7.5.1 โ€“ Mac OS 9.1
PredecessorLC 575
SuccessorPerforma 5260CD
CodenameBongo, Transformer
Model no.M3046
The Macintosh Performa 5200 is the base model of Apple's Performa 5200 series, an all-in-one Macintosh personal computer introduced in April 1995. The Performa 5200 did not include a CD-ROM drive and was not widely sold; the Performa 5200CD was the primary consumer model.
The Performa 5200 shares the same chassis, logic board, and specifications as the rest of the 5200 series:
Component Specification
CPU PowerPC 603 @ 75 MHz
RAM 8 MB minimum in one SIMM slot, with no RAM soldered on the board; expandable to 64 MB across two 72-pin, 80 ns or faster SIMM slots[1]
Storage 500 MB IDE hard drive
Optical None
Floppy 1.44 MB 3.5" manual inject
Display 15-inch shadow-mask CRT, 12.8-inch viewable. 0.28 mm dot pitch, 66.7 Hz vertical, 240 ร— 185 mm nominal active raster, 9,300 K white point, P22-derivative aluminised phosphor[1]
Video modes 640ร—480 at 16-bit; 800ร—600 at 8-bit; 832ร—624 at 8-bit (832ร—624 does not support video input)[1]
L2 cache 256 KB[1]
ROM 4 MB[1]
SCSI One external DB-25 port, up to seven devices[1]
Serial Two RS-232/422 ports on mini DIN-8 connectors[1]
Power 100โ€“240 VAC, 47โ€“63 Hz, 125 W. The supply is rated 2.5 A maximum and 220 W maximum for all line and load conditions[1]
Frame buffer 1 MB of DRAM on the logic board, dedicated to video โ€” it is not taken from system RAM[1]
OS System 7.5.1 โ€“ Mac OS 9.1
For complete technical specifications, see the Macintosh Performa 5200CD article.
A note on the published weight. Apple's Power Macintosh/Performa 5200 and 5300 Service Source prints "Without CD-ROM: 17 lb. With CD-ROM: 19 lb. (21.15 kg)" โ€” figures that contradict each other, since 19 lb is 8.6 kg. 17 lb and 19 lb are the weights Apple publishes for the desktop Performa 6200/6300, and appear to have been carried into the 5200 manual by mistake; 21.15 kg is the figure consistent with a 15-inch all-in-one. The metric figure is the one used here.[1][2]
For detailed maintenance practices, refer to the Macintosh Performa 5200CD General Maintenance page.
Detailed capacitor replacement guidelines can be found on the Macintosh Performa 5200CD Capacitor Replacement Guide page.
Apple's Repair Extension Program
The 5200 and 6200 families are the Macintoshes most often written about second-hand, and the folklore has drifted a long way from what Apple actually documented. Apple ran a genuine Repair Extension Program for system freezes and for sudden changes in video colour hue on the Power Macintosh/Performa 52xx and 53xx (except the 5260 and 5280). The checks are specific and you can make them yourself.[1]
What to check Where What is wrong Apple's remedy
Clock chip U10 on the logic board Part number is not 343S1191 or 343S1121 (ignore any trailing letters) Replace the logic board
Cache/ROM DIMM Vertical DIMM on the logic board Laid out as in Apple's figure and the middle vertical IC has no sticker Replace the DIMM, part 661-1278
Version B logic board U6, with U27 on the underside U6 has no picture of Texas and is p/n 343S0138-a, and there is no wire at U27 Replace the logic board
Ethernet card fence Communications slot Card fence does not hook onto the logic board fence Replace the fence; without the hook the card rocks out of the slot and the network drops intermittently
Internal RGB cable Between the logic board and the video board Sudden or intermittent changes in monitor colour hue Replace the internal RGB cable, part 922-2357
A "Version B" logic board is identified by a B at the end of the serial number printed on the board near the communications port.[1]
Apple also required the EMI clips to be replaced on any machine where the logic board was not being replaced, because the clips prevent damage to the board when expansion cards are fitted.[1]
Two cautions that follow from Apple's own wording:
  • A consistent colour cast is not the RGB cable. Apple says that if the monitor still shows a consistent hue after the internal RGB cable has been replaced, the analogue board is the part at fault.[1]
  • Type 11 errors are not this fault. Apple explicitly directs those to a clean install of system software or a third-party software update, not to a board swap.[1]
Open Transport 1.1 does not work on these machines; they require 1.1.1. If installing 1.1.1 raises a dialogue saying a hardware issue was detected, that is Open Transport refusing to install until the cache/ROM DIMM is replaced โ€” the repair covered by the programme above.[1]
A comprehensive troubleshooting guide is available on the Macintosh Performa 5200CD Troubleshooting page.
  1. โ†‘ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 Apple Computer, Inc., Power Macintosh/Performa 5200 and 5300 Service Source, Basics (Rev. B, 5000 Series; Open Transport), Specifications, Troubleshooting → Symptom Charts, REA Procedures and Exploded View. Hosted on this wiki as File:Powermac.perf 5200.5300.pdf.
  2. โ†‘ Apple Computer, Inc., Performa 6200/6300 Series Service Source, Specifications, Troubleshooting → Symptom Charts, Additional Procedures and REA Procedures. Hosted on this wiki as File:Performa 6200.6300.pdf.
