PowerBook Duo 280
Revision as of 09:45, 2 October 2026 by Josh (talk | contribs) (Cite mitchW panel report)
PowerBook Duo 280 and 280c
PowerBook Duo 280c (Alexander Schaelss, Wikimedia Commons, CC BY-SA 3.0)
TypeSubnotebook computer
Released16 May 1994
Discontinued14 November 1994 (280); 27 January 1996 (280c)
Intro priceUS$2,600 (280); US$3,750 (280c)
CPUMotorola 68LC040 at 33 MHz (66 MHz internal); no FPU
Memory4 MB on the logic board; one Duo RAM card slot, to 40 MB
Storage240 MB (280) or 320 MB (280c) 2.5-inch SCSI hard drive
Display280: 9-inch active-matrix greyscale, 640 × 400; 280c: 8.4-inch colour active-matrix, 640 × 480 at 256 colours or 640 × 400 at thousands
Sound—
ROM1 MB
PowerType III NiMH battery; 24 V DC adapter (25 W for the 280, 36 W for the 280c)
Dimensions1.4 in (280) or 1.5 in (280c) × 10.9 × 8.5 in
Weight4.2 lb (280); 4.8 lb (280c)
OS / FirmwareSystem 7.1.1 to Mac OS 8.1
The PowerBook Duo 280 and PowerBook Duo 280c are the 68LC040 PowerBook Duos, introduced on 16 May 1994 to replace the PowerBook Duo 250 and PowerBook Duo 270c. They share a logic board, a 33 MHz 68LC040 with no floating-point unit, a 40 MB memory ceiling and the Type III battery. The 280 has a greyscale active-matrix screen; the 280c has a colour one and is thicker and heavier. The 280c was the last 68k Duo, sold until January 1996.[1][2] The PowerBook Duo 2300 followed in August 1995.[3]
Apple's specifications[4][1][2]
Item Duo 280 Duo 280c
Processor Motorola 68LC040, 66/33 MHz, 8 KB cache, no FPU
RAM 4 MB soldered; one Duo RAM card, to 40 MB with a 36 MB card; 70 ns[5]
Display 9-inch backlit active-matrix greyscale, 640 × 400, 16 shades 8.4-inch backlit active-matrix colour, 640 × 480 at 256 colours or 640 × 400 at thousands
Hard drive 240 MB 320 MB
Main battery NiMH Type III, 1.6 Ah; about 2 to 3 hours
Power adapter 24 V DC, 1.04 A (25 W) 24 V DC, 1.5 A (36 W)
Height and weight 1.4 in; 4.2 lb 1.5 in; 4.8 lb
Gestalt ID 102 103
Low End Mac gives the launch prices as US$2,600 and US$3,750 and lists the M7783 adapter for the 280 and the M2693 for the 280c.[6] Apple gives the 280c display as 8.4 inches against 9 inches for the 270c, yet MacDat names the same Sharp LQ9D041 panel for both and gives one capacitor list for the two; mitchW recorded an LQ9D041 in a 270c,[7] and jmacz recorded the panel in a 280c as an LQ94D041.[4][8][9]
Logic board
Apple's service board for both models is 661-0051.[4] Console5 lists its electrolytics with designators: C2 47 µF 35 V; C3, C7, C8 and C9 100 µF 35 V; C6 100 µF 25 V; C72 33 µF 25 V. This matches MacDat's count.[10][8]
Duo 280/280c logic board with the seven electrolytics marked: red 100 µF 35 V, cyan 100 µF 25 V, lime 47 µF 35 V, pink 33 µF 25 V (photo by jmacz, annotated by MacDat)
Apple fits a large foam heatsink pad under the CPU stiffener tab of a 280 or 280c, where the 210, 230, 250 and 270c take a small one. A replacement stiffener needs the right pad.[4]
Displays
The 280's greyscale panel and its inverter carry no electrolytic capacitors, according to MacDat.[8] The 280c's colour panel is described by nvdeynde on 68kMLA as full of small surface-mount electrolytics, some already leaking or with high ESR.[11] jmacz recapped a 280c panel with polymer parts of the original size and later broke one solder joint by gripping the lid hard, and suggested low-profile polymer tantalums instead. The same machine had a high-pitched whine from the inverter's coils, which stopped once the coils were coated with thin superglue.[9]
The 280 kit for a 250 includes a new display cable, slightly longer than the 250's; Apple says to leave the extra length loose. A 270c becoming a 280c keeps its own cable.[4]
Common problems
  • Leaking electrolytics in the power circuit. FlyingToaster's 280c ticked from the DC-DC circuit and never worked again, and techknight warned that this damage is usually terminal.[11] See PowerBook Duo Capacitor Replacement Guide.
  • Broken screw posts and a broken speaker mount inside the display housing; jmacz printed replacement stand-offs and epoxied them in.[9]
  • A gummed-up trackball, cleaned with isopropyl alcohol.[9]
  • Mushy or dead keys; cleaning the contacts and relubricating the key stems helped, but did not cure every key.[9]
See PowerBook Duo Troubleshooting and PowerBook Duo General Maintenance. Replacing the hard drive with a SCSI emulator needs a new mount, because the drive fixes from the side; jmacz published a 3D model for one.[9]
Upgrades
Apple's 280/280c kit upgraded a 250 to a 280 or a 270c to a 280c. It was a 280 case bottom, logic board and CPU stiffener assembly with a Type 3 battery and a 36 W adapter.[4] The 2300 kit later replaced the same assembly with a PowerPC board, and the 280c display then connects to the 2300c board's TFT connector, J7.[4]
  1. ↑ 1.0 1.1 Apple, "Macintosh PowerBook Duo 280: Technical Specifications" (retrieved 2026-10-02). 68LC040 at 66 MHz (33 MHz bus), 8K L1 cache, no FPU; 25 W, 1.04 A; Duo NiMH Type III battery; 4 MB on board, 4-40 MB; 640 × 400 at 4 bits; introduced 5/16/1994, discontinued 11/14/1994; Gestalt ID 102; 4.2 lb; 1.4 in high; System 7.1.1 with PowerBook Duo Enabler v2.0, supported to 8.1; 240 MB hard drive.
  2. ↑ 2.0 2.1 Apple, "Macintosh PowerBook Duo 280c: Technical Specifications" (retrieved 2026-10-02). 68LC040 at 66 MHz, no FPU; 36 W, 1.5 A; Duo NiMH Type III battery; 4 MB on board, 4-40 MB; 640 × 400 at 16 bits, 640 × 480 at 8 bits; introduced 5/16/1994, discontinued 1/27/1996; Gestalt ID 103; 4.8 lb; 1.5 in high; System 7.1.1 with PowerBook Duo Enabler v2.0, supported to 8.1; 320 MB hard drive.
  3. ↑ Wikipedia, "PowerBook Duo" (retrieved 2026-10-02). Duo 280 and 280c released May 1994 as 68LC040 replacements for the 250 and 270c, supporting 40 MB; 280c shipped with the Type III battery; Duo 2300c August 1995. Used for history only.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 4.6 Apple Computer, PowerBook 200 Series Service Source, hosted here as File:PowerBook Duo 200 Series Service Source.pdf (see PowerBook Duo 200 Series Service Source). PDF page numbers: processor and memory pp. 14-17; display pp. 22-23; electrical pp. 24-25; physical p. 26; CPU stiffener heatsinks pp. 132-134; 280/280c upgrade pp. 216-226; 2300 upgrade pp. 227-239; exploded view p. 266.
  5. ↑ Apple Computer, Apple Memory Guide (May 2000), hosted here as File:Apple Memory Guide (May 2000).pdf (see Apple Memory Guide). PowerBook Duo 280/280c, PDF p. 111: 4 MB soldered; cards of 4, 6, 8, 10, 12, 16, 20, 24 or 36 MB; 40 MB maximum with a third-party 36 MB card; Apple supplies an 8 MB card.
  6. ↑ Low End Mac, "PowerBook Duo 280" and "PowerBook Duo 280c" (retrieved 2026-10-02). 280 introduced 1994.05.16 at $2,600, discontinued 1994.11.14, power supply M7783; 280c introduced 1994.05.16 at $3,750, discontinued 1996.01.27, 8.4-inch display, power supply M2693. Secondary source.
  7. ↑ 68kMLA forum thread "PowerBook Duo 270c Restoration", mitchW, September 2023. 270c capacitor lists, including the Sharp LQ9D041 panel. Community repair report.
  8. ↑ 8.0 8.1 8.2 MacDat, "PowerBook Duo 280c Capacitor Reference" and "PowerBook Duo 280 Capacitor Reference" (retrieved 2026-10-02). Logic board (both): four 100 µF 35 V, one 100 µF 25 V, one 47 µF 35 V, one 33 µF 25 V; 280c Sharp LQ9D041 LCD: fifteen electrolytics; 280c inverter: one 10 µF 35 V; the 280's LCD and inverter have no electrolytics. Logic board photo by jmacz. Secondary source.
  9. ↑ 9.0 9.1 9.2 9.3 9.4 9.5 68kMLA forum thread "Powerbook Duo 280c + Accessories Maintenance", jmacz, March 2025. Full recap of a 280c (logic board, LCD, inverter, power adapter); inverter coil whine stopped with superglue; broken display stand-offs and speaker mount; trackball cleaning; ZuluSCSI with a 3D-printed side mount; keyboard cleaning. Community repair report.
  10. ↑ Console5 TechWiki, "Macintosh PowerBook 280c" (retrieved 2026-10-02). Cap list: C2 47 µF 35 V; C3 100 µF 35 V; C6 100 µF 25 V; C7, C8, C9 100 µF 35 V; C72 33 µF 25 V. Secondary source.
  11. ↑ 11.0 11.1 68kMLA forum thread "Notice to Powerbook Duo Users!", techknight, nvdeynde, FlyingToaster and others, February-March 2012. Leaking DC-DC electrolytics on a 270c; a 280c that ticked from the DC-DC circuit and then died; leaking and high-ESR capacitors behind the 280c LCD. Community repair report.
