Macintosh 512K
Revision as of 12:48, 23 April 2025 by Josh (talk | contribs)
Macintosh 512K
TypePersonal computer
ReleasedSeptember 10, 1984
DiscontinuedApril 14, 1986
Intro priceUS$3,195
CPUMotorola 68000 @ 7.83 MHz
Memory512 KB RAM (not expandable)
Storage400 KB 3.5″ floppy drive
Display9″ monochrome CRT (512 × 342 px)
SoundMonaural 8‑bit, 22 kHz (4‑voice)
Dimensions13.6″ H × 9.6″ W × 10.9″ D
Weight16.5 lb (7.5 kg)
OS / FirmwareSystem 1.0 – System 4.1
PredecessorMacintosh 128K
SuccessorMacintosh 512Ke
CodenameEngine, Hero
Model no.M0001W
The Macintosh 512K, released on September 10, 1984, was an improved version of the Macintosh 128K. It featured four times the RAM (512 KB), allowing for improved multitasking and compatibility with a wider range of software. It retained the same Motorola 68000 processor running at 7.83 MHz and the 9-inch monochrome display with a 400 KB floppy disk drive.
Due to its increased memory, the Macintosh 512K could run more advanced applications, including MacDraw, MacProject, and Microsoft Multiplan. However, it still lacked built-in support for an internal hard drive, relying on external floppy drives for additional storage. The 512K model was succeeded by the Macintosh Plus, which introduced expandable RAM and an external SCSI port.
Maintenance
Due to the 512K's similarities with the 128K, there is no difference in it's maintenance, PCB or Schmatics, please see the Macintosh 128K page for maintenance, guides and more information.
Sub-system Specification
CPU Motorola 68000 @ 7.8336 MHz (15.667 MHz ÷ 2)
Bus width 16-bit data • 24-bit address (16 MB logical space)
ROM 64 KB “Boot/Toolbox” (4 × 16 KB HN462716 mask ROMs)
RAM 512 KB DRAM (16 × 256-Kbit 150 ns) – *soldered, non-expandable*
Video 512 × 342 monochrome frame-buffer (22.1 KB) DMA-shared with system RAM
Sound 8-bit PWM DAC via VIA timers • 22 kHz low-pass to speaker / 3.5 mm jack
Disk I/O Sony OA-D34V 400 KB GCR 3.5″ drive • IWM controller
Ports DE-9 mouse/KB • DB-19 ext. floppy • RS-422 serial × 2 (230 kbps) • 3/8″ audio-out
Memory Map (Physical)
Macintosh 512K Address Space
Range Size Purpose
$000000 – $07FFFF 512 KB **DRAM** (program, frame-buffer, stack, heap)
$400000 – $41FFFF 128 KB **ROM** (Boot + Toolbox)
$480000 – $4BFFFF 256 KB **I/O space** (VIA 1 & 2, SCC, IWM, VBL PAL)
$500000 – $5FFFFF 1 MB **Reserved / not decoded**
$600000 – $FFFFFF Mirrors / “ghost ranges”
  • Frame-buffer note:* display memory occupies **$07B000 – $07FFFF** (22,016 bytes).
DMA steals cycles from the 68000 only during active scan-lines, identical to the 128 K.
ROM Layout (64 KB)
Offset Size Module (v3.3 ROM set)
$400000 8 KB 68000 vectors + mini-shell
$402000 16 KB QuickDraw 1.0 (mono)
$406000 20 KB Macintosh Toolbox routines
$40B000 12 KB SANE (IEEE fp) + traps
$40E000 8 KB Sony IWM floppy driver / boot
Video Timing
Parameter Value (NTSC)
Pixel clock 7.833 MHz
Horizontal total 704 px (512 active)
Vertical total 370 lines (342 active)
Refresh rate 60.15 Hz
Floppy-Disk Format
  • 80 tracks • single-sided variable-speed GCR
  • 12 sectors/track (outer) → 8 sectors/track (inner)
  • 512-byte sectors • 400 KB formatted capacity
Key I/O ICs
  • 6522 VIA × 2 – system timers, sound PWM, keyboard/mouse handshake
  • 8530 SCC – dual RS-422 serial ports
  • IWM – “Integrated Woz Machine” floppy controller
  • MC6883 PAL – VBL interrupt generator & DRAM time-slot arbiter
Sound Path
The 68000 writes 8-bit samples to VIA Port A. VIA Timer 1 toggles Port B at 22.254 kHz, producing pulse-width-modulated audio → RC filter → LM380 amplifier → speaker/headphone jack.
Hardware Easter Egg
  • Hold* **⌘ + ⌥ + ⇧ + Clear** at boot to hear the hidden “bass” startup chime.
(The 512K retains this ROM routine; it was removed in the 512Ke/Plus.)
