Power Macintosh 6100 Capacitor Replacement Guide
Revision as of 23:02, 23 September 2026 by Josh (talk | contribs) (Verification drive: capacitor list verified - there is none. Removed the unsourced '10uF to 470uF' logic-board range and the unnamed PSU capacitor list; Apple's 6100 Service Source is module-level and names no capacitor. Replaced the 'wait 24 hours' discharge advice with a real discharge-and-measure instruction)
Replacing electrolytic capacitors (recapping) in your Power Macintosh 6100 is an important maintenance task for long-term reliability. Capacitors from the early 1990s may leak, dry out, or fail, causing various system problems.
Capacitor Inspection
Before recapping, inspect the logic board and power supply for signs of capacitor failure:
  • Bulging Tops – The normally flat or slightly indented top of the capacitor is domed or bulging
  • Leaking Electrolyte – Brown or black residue around the base or top of capacitors
  • Corrosion or PCB Staining – Discoloration on the circuit board near capacitors
Symptoms of Capacitor Failure
Common symptoms that may indicate the need for recapping:
  • System won't power on or randomly shuts off
  • Audio distortion or no sound
  • System fails to boot reliably
  • Random crashes or freezes
  • Power supply makes buzzing or clicking noises
What documentation exists for this machine
No component-level capacitor list has been found for the Power Macintosh 6100. Apple's Power Macintosh 6100/WS 6150 Service Source is module-level throughout: it gives specifications, take-apart procedures, a symptom chart and an exploded view of replaceable assemblies, and it names no capacitor anywhere — the power supply is a single orderable part, 661-1688.[1] Apple published no schematic and no populated parts list for this machine, and none has surfaced in the wiki's own holdings or on archive.org.
This page therefore gives no values. An earlier revision listed "various values from 10 µF to 470 µF" on the logic board and unnamed "main filter" and "ripple suppression" capacitors in the power supply; neither came from a source and both have been removed. Read the values off your own board — they are printed on the cans — and match them.
  1. Discharge and Prepare
    • Unplug the system, then discharge the power supply's primary reservoir through a resistor and verify with a meter that it has come down
    • Remove the top case and locate the logic board
    • Use a wrist strap to prevent ESD damage
  1. Document Capacitor Locations
    • Photograph the board before starting
    • Note polarity markings (negative stripe on capacitor, + or - on PCB)
  1. Remove Old Capacitors
    • Use a temperature-controlled soldering iron (recommended 350°C/660°F)
    • For through-hole: heat each lead and gently pull the capacitor free
    • Use desoldering braid or pump to remove excess solder
  1. Prepare Pads
    • Clean pads with isopropyl alcohol and a brush
    • Check for lifted traces or pad damage
    • Apply fresh solder to tin the pads
  1. Install New Capacitors
    • Verify correct polarity (negative stripe to negative marking)
    • Use quality replacement capacitors rated for the same or higher voltage
    • Solder securely with minimal heat application time
  1. Trim and Inspect
    • Trim leads flush on through-hole capacitors
    • Check for solder bridges or cold joints
    • Use a multimeter to verify no shorts exist
  1. Clean and Test
    • Clean the board with isopropyl alcohol
    • Allow to dry completely
    • Reassemble and test the system
  • Temperature-controlled soldering iron (chisel tip recommended)
  • Desoldering pump or wick/braid
  • Fine solder (0.5mm–0.8mm diameter)
  • Isopropyl alcohol (90%+) and ESD-safe brush
  • Multimeter for continuity testing
  • Magnifying glass or loupe
  • Anti-static wrist strap
  • Safety glasses
Voltage Check After Recap
Apple publishes no per-rail voltages or tolerances for this machine. The Power Macintosh 6100 / WS 6150 Service Source gives the input side only — 100–240 VAC automatically configured, 50–60 Hz, 132 W maximum continuous and 201 W peak input, with 86 W continuous DC output — and no adjustment procedure.
After a recap, check that the +5 V rail sits inside the range the board's 5 V logic is specified for, which is 5 V ±5 per cent, or 4.75 V to 5.25 V. For the ±12 V rails there is no published figure; look for a steady reading under load and for the absence of visible ripple rather than for a number.
Additional Tips
  • Use quality Japanese-brand capacitors (Nichicon, Panasonic, Rubycon)
  • Match or exceed original voltage ratings
  • Match the capacitance printed on the part you removed
  • Consider replacing all electrolytic capacitors at once for thorough restoration
  • Photograph each capacitor before removal; that photograph, not this page, is your parts list
  • Take photos throughout the process for reference
  1. ↑ Apple Computer, Inc., Power Macintosh 6100/WS 6150 Service Source (Specifications, Take Apart, Additional Procedures, Exploded View). The whole manual is module-level; it names no capacitor anywhere. Hosted on this wiki as File:Powermac 6100 series.pdf.
