Macintosh Floppy Drive Maintenance
Revision as of 23:32, 23 September 2026 by Josh (talk | contribs) (House style: rephrase the corrections as statements about the figures themselves rather than about this page's own history)
The internal floppy disk drives fitted to vintage Macintosh computers are 3.5-inch mechanisms made by Sony and Mitsubishi, used from 1984 into the late 1990s. Three generations matter:
  • 400 KB โ€“ single-sided, Sony 3.5-inch (128K and 512K)
  • 800 KB โ€“ double-sided, Sony 3.5-inch (Plus, SE and others)
  • 1.4 MB โ€“ high-density Apple SuperDrive, Sony and Mitsubishi mechanisms (later models)
They fail with age from dust, hardened grease in the eject mechanism, dried lubricant on the carriage rails, worn or dirty heads and cracked plastic gears. Cleaning and re-greasing recover most drives. Alignment does not โ€” see What cannot be adjusted below.
These drives have no belt
The Apple SuperDrive and its 400 KB and 800 KB predecessors are direct drive. The spindle is coupled straight to a DC brushless motor; there is no belt, no pulley and no belt part number.[1]
The word "belt" does not appear anywhere in Apple's service documentation for these drives โ€” not in the Apple 3.5 Drive, Apple 400K Drive, Apple 800K Drive, Apple SuperDrive or Macintosh HDI-20 1.4 MB Drive Service Source volumes.[2][3]
Advice to "check the drive belt" on a Macintosh floppy drive is wrong and has propagated from this page to several machine pages. Belt-driven floppy mechanisms are a 5.25-inch full-height phenomenon (Tandon TM100, CDC/MPI and similar) โ€” see Floppy Drive Repair.
Specifications you can measure against
Apple publishes a real specification for the 800 KB Apple 3.5 Drive, and it converts directly into bench checks.[2]
Apple 3.5 Drive (800 KB)
Parameter Apple's figure
Tracks per inch 80
Recording surfaces 2
Seek time, track to track 6 ms maximum
Settle time 30 ms maximum
Drive start-up time 600 ms maximum
Head position accuracy ยฑ0.035 mm
Formatted capacity 800 K (certified double-sided media)
Unformatted capacity 1,246 K
Operating temperature 5โ€“50 ยฐC (40โ€“122 ยฐF)
Relative humidity 5โ€“90%, no condensation
Apple 3.5 Drive โ€” current draw
Rail Standby Typical Peak
+12 V 10 ยตA 120 mA 600 mA, during eject only, 2 seconds maximum
+5 V 10 mA 360 mA โ€”
A drive that pulls far more than this, or that drags a rail down when it spins up, has a shorted motor driver or a seized mechanism. A drive that pulls nothing at all is not being powered โ€” check the cable before opening the drive.
Disassembly and cleaning
Before you start
  • Power off and unplug the Macintosh.
  • Work on a static-free surface with an anti-static wrist strap.
  • Most compact Macintosh cases need a Torx T15 driver (a long-shaft one for the case screws inside the handle well).
To remove the drive:
  1. Open the case.
  2. Disconnect the ribbon cable and, on drives that have one, the power connector.
  3. Remove the mounting screws and slide the drive out.
Floppy drive head
Cleaning the mechanism
  • Blow the dust out with compressed air, or lift it with a soft anti-static brush.
  • Clean the carriage rails and gears with isopropyl alcohol (>90%) and a lint-free cloth.
  • Clean the read/write heads with a cotton bud dipped in isopropyl alcohol, moving along the head rather than across it. Support the upper head arm โ€” do not let it snap down onto the lower head.
  • Apple's own first remedy for "drive is unable to read; many file transfer errors occur" and for "drive fails to format" is, in both cases, clean drive.[3]
Re-greasing
  • Re-grease the carriage rails, the eject gears and the worm drive with a plastic-safe synthetic grease. Hardened forty-year-old grease is the single most common cause of a drive that will not eject or that grinds.
  • Do not use WD-40 or any other penetrating oil: it creeps, attracts dust and degrades the plastics.
  • Do not over-apply. Grease on the head or on the media path will ruin disks.
Common failures and repairs
Eject mechanism
Mechanical eject systems fail through:
  • Eject motor failure
  • Hardened grease on the gears
  • Cracked or broken plastic gears โ€” the eject worm gear is a known casualty, and 3D-printed replacements are widely available
  • Dirty eject switches
Fixes: clean and re-grease with a plastic-safe grease, replace broken gears, clean the switches.
Drive will not read
  • Clean the heads thoroughly and inspect them under magnification for wear or a scored surface.
  • Check that the spindle turns freely by hand and that the stepper moves the carriage the whole way.
  • Verify the disk-insertion and write-protect sensors โ€” a blocked write-protect sensor makes every disk read-only, and a blocked insertion sensor makes the drive ignore disks entirely.
  • Try known-good media. Forty-year-old disks shed oxide, and a shedding disk will contaminate a freshly cleaned head in one pass.
Drive reads but will not write
Apple's chart sends this straight to "verify that drive is 1.4 MB SuperDrive", then to replacing the mechanism.[3] In practice, check the write-protect shutter and sensor first โ€” that accounts for most of them.
Stepper and carriage
  • Symptoms: no movement, failure to seek, tracking that drifts.
  • Clean and lightly lubricate the guide rails; check the stepper coil continuity with a multimeter.
  • A stepper that buzzes without moving is usually mechanically jammed rather than electrically dead.
Three procedures circulate for these drives: re-tensioning the head spring, aligning the track-zero sensor by loosening its screws, and aligning the heads by loosening the stepper motor and rotating it. None of them is in Apple's documentation, and all three are wrong for these mechanisms:
  • There is no felt pressure pad in a double-sided 3.5-inch drive. The felt pad belongs to single-sided 5.25-inch drives. A Sony or Mitsubishi 3.5-inch mechanism has an upper head on a sprung gimbal that loads against the lower head, and bending that spring changes the head load force away from the manufacturer's figure โ€” which is not recoverable without the manufacturer's jig.
  • Head alignment on these drives needs an alignment disk and an oscilloscope, not trial and error against known-good disks. Moving the stepper by hand destroys the drive's compatibility with every disk written elsewhere, including the ones that used to work.
  • Apple's own service documentation contains no adjustment procedure of any kind for these drives. Every symptom in the Apple SuperDrive and Apple 3.5 Drive charts ends in "clean drive" or "replace drive mechanism".[3][2]
If a cleaned, re-greased drive still misreads disks from other machines, the realistic options are a known-good donor mechanism or a modern replacement, not an alignment attempt.
Things that are not faults
  • A disk formatted on a 1.4 MB SuperDrive that a PC will not read. Apple's answer is to format all disks on the MS-DOS drive first, and then both drives can read and write them.[3]
  • A SuperDrive that reads 800 K disks but not high-density ones. Check it really is a 1.4 MB SuperDrive and not an 800 K mechanism in a later machine; Apple's chart asks this first.[3]
  • A single click on insertion. That is the mechanism clamping the hub, and it is normal.
Testing
  • Disk Copy verifies that a disk reads end to end and is the quickest way to prove a repair.
  • A known-good disk written on a different machine is the only test that distinguishes a dirty head from an alignment problem.
  • Apple HD SC Setup is a hard disk utility and has no role in floppy testing, despite being listed as one in several places.
Additional Resources
  1. โ†‘ Mitsubishi Electric, MF355C 3.5-inch Diskette Drive Specifications, UGD-0527A, February 1987: "The drive uses a DC brushless, direct-drive motor"; the disk rotation mechanism "uses a DC brushless direct-drive motor to directly rotate the spindle". Hosted on this wiki as File:Mitsubishi MF355C 3.5 inch Diskette Drive Specifications (UGD-0527A, Feb 1987).pdf.
  2. โ†‘ 2.0 2.1 2.2 Apple Computer, Inc., Apple 3.5 Drive Service Source (Specifications, Troubleshooting, Take Apart). Hosted on this wiki as File:Apple 3.5 drive.pdf.
  3. โ†‘ 3.0 3.1 3.2 3.3 3.4 3.5 Apple Computer, Inc., Apple SuperDrive Service Source (Troubleshooting → Symptom Charts; Take Apart). Hosted on this wiki as File:Apple superdrive.hdi 20.pdf.
