Apple IIe Platinum
Revision as of 18:20, 26 August 2025 by Josh (talk | contribs)
Apple IIe Platinum
Apple IIe Platinum with integrated numeric keypad
TypeHome computer
ReleasedJanuary 1987
Discontinued15 November 1993
CPU65C02 (CMOS 6502 variant) @ 1.023 MHz
Memory64 KB onboard + 64 KB on factory Extended 80-Column Card (128 KB standard); expandable via RAM cards
StorageExternal cassette; Disk II 5.25″ floppy; optional 3.5″ UniDisk (with controller); hard disk via controller (e.g., ProFile)
Display40×24 or 80×24 text; 280×192 hi-res; 560×192 double hi-res (requires 128 KB)
Sound1-bit built-in speaker (toggle)
Dimensions48 cm × 38 cm × 11 cm
Weight5.4 kg
OS / FirmwareApple DOS 3.3, ProDOS, CP/M (with Z-80 card); many third-party ROMs and utilities
PredecessorApple IIe Enhanced
SuccessorApple IIGS
CodenameDiana (IIe family)
Model no.A2S2128 (USA); A2S2128C (Canada); A2S2128X (International); A2S2064 (European "hybrid")
The Apple IIe Platinum (often styled "Platinum //e") is the final major revision of the Apple IIe family, introduced in January 1987. The revision is primarily cosmetic—adopting Apple’s "Platinum" case colour and a refreshed keyboard layout—but it also standardized an important configuration: a factory-installed Extended 80-Column Card (bringing total RAM to 128 KB and enabling Double Hi-Res graphics). The Platinum retained the Enhanced IIe firmware set and the CMOS 65C02 CPU, while a number of motherboard refinements reduced component count and improvedManufacturability.
Design & Positioning
Apple modernised the IIe's appearance to align with the product family introduced in the mid-1980s. Outside the new case colour and keyboard changes the machine behaves like an Enhanced IIe with the Extended 80-Column hardware present by default. The integrated numeric keypad and revised modifier keys (Command/Option in place of Open/Solid Apple on many shipments) improved ergonomics for business and education users.
What changed (high level)
The Platinum update is best thought of as a "final polish" rather than a re-engineering:
  • Factory-installed Extended 80-Column Card (compact form factor) so 128 KB and 80-column text were standard.
  • New Platinum case colour, revised keyboard with integrated numeric keypad and relocated Reset/power LED positions.
  • Internal motherboard consolidation: combined ROMs and higher-density DRAMs for a lower chip count and a smaller Extended 80-Column implementation.
Hardware (technical summary)
Component Specification
CPU 65C02 (CMOS variant of the MOS 6502) running at ≈ 1.023 MHz. The 65C02 was used across late IIe revisions for improved instruction set and reliability.
System bus 8-bit data bus, 16-bit address bus (64 KB addressable per bank); bank switching used for Extended RAM.
RAM 64 KB onboard + 64 KB on the factory Extended 80-Column Card (128 KB standard). Expandable further with third-party RAM cards (many collectors report 1 MB+ via aftermarket cards).
ROM Typically 16 KB system ROMs on early IIe families; later Platinum/production revisions used combined/expanded ROM images (~32 KB total) to consolidate Applesoft/Monitor/80-column routines.
Video NTSC composite (RCA) and RF outputs on domestic units; PAL variants for international production. Native modes: 40×24 text (40 columns), 80×24 text (80-column card), Low-res (40×48, 16 colours), Hi-res (280×192, 6 colours), Double Hi-Res (560×192, up to 16 colours via banked memory — requires 128 KB).
Sound Single bit speaker, software-driven toggling; third-party sound cards (e.g., Mockingboard family) provided multi-voice audio.
Storage Disk II (5.25″) common; UniDisk 3.5″ supported with controller; third-party hard disk controllers and Apple ProFile support via expansion. Cassette I/O retained for legacy use.
Expansion Seven standard Apple II Bus slots (50-pin) plus the Auxiliary slot (60-pin) used by 80-column/extended memory hardware; many external cards available (serial, parallel, disk controllers, Z-80 CP/M card, network cards, memory expansions).
I/O & connectors Composite video out, RF modulator, cassette in/out, game I/O header (joystick/paddle), numeric keypad connector (internal via factory keyboard on many Platinum units), DE-9 joystick on later boards/variants; serial/printer via expansion cards.
Keyboard Full-size built-in keyboard; Platinum revisions frequently include an integrated numeric keypad and IIGS-style key legends (Command/Option), plus relocated Reset and power LED. Some regional "hybrid" Platinum IIe used original IIe keyboard layout without numeric keypad.
Dimensions & weight 48 × 38 × 11 cm; ~5.4 kg (typical Apple IIe family dimensions/weight).
Typical model numbers A2S2128 (US Platinum with numeric keypad), A2S2128C (Canada), A2S2128X (International), A2S2064 (European "hybrid" Platinum using older case mold).
Compatibility & software
The Platinum IIe retains full Enhanced IIe compatibility; with 128 KB standard and Double Hi-Res enabled it is the most immediately capable IIe for later software (desktop publishing, advanced graphics, and productivity suites such as AppleWorks). CP/M remains available via Z-80 cards, and the 65C02 core maintains compatibility with the broad Apple II software library (with a small number of edge cases where very timing-sensitive or self-modifying code targeted the original NMOS 6502 behaviour).
Regional variants and notes
Apple shipped different assemblies for NTSC and PAL markets (different master crystal frequencies and video timing). Some European "Platinum" machines are best described as hybrids—they use the Platinum colour and updated internals but retain the older case/keyboard in certain runs. RFI suppression components were also modified on later boards which can affect certain high-speed game I/O peripherals; collectors sometimes remove or modify these components when restoring hardware for specialised peripherals.
Known issues & collector notes
The Platinum IIe is generally stable, but collectors should be aware that:
  • Factory-installed RIFA capacitors and aging electrolytics in the power supply are common failure points and are often preemptively replaced.
  • Because the Extended 80-Column Card is factory-fitted in a compact form, some aftermarket upgrades require different mechanical approaches than earlier IIe boards.
  • ROM and CPU revisions exist across production runs (SynerTek vs. WDC branded 65C02s and differing ROM images), so careful verification is recommended when sourcing replacement parts or buying online.
