Apple IIc Plus
Revision as of 21:44, 26 March 2026 by Josh (talk | contribs) (Removed Category:Apple II series)
Apple IIc Plus
Apple IIc Plus
TypeHome computer
ReleasedSeptember 1988
DiscontinuedNovember 1990
Intro priceUS$675 (1988)
CPUMOS Technology 65C02 @ 4 MHz
Memory128 KB RAM (expandable to 1 MB)
StorageInternal 3.5" (800 KB) floppy disk drive, external 5.25" supported
Display40×24 or 80×24 text, 280×192 (colour), 560×192 (monochrome) graphics
Sound1-bit speaker (toggle), same as Apple II series
Dimensions30.5 cm × 29.2 cm × 7.6 cm
Weight3.6 kg
OS / FirmwareApple DOS 3.3, ProDOS, Apple Pascal
PredecessorApple IIc
SuccessorApple IIGS
CodenameRaisin
Model no.A2S4500
The Apple IIc Plus is the final model in the Apple IIc line, introduced by Apple Computer, Inc. in September 1988. It featured a faster 4 MHz 65C02 CPU, an internal 3.5" floppy drive, and several architectural enhancements over its predecessor, the Apple IIc.
The IIc Plus is powered by a 65C02 microprocessor running at 4 MHz, a significant speed increase over the original IIc’s 1 MHz. The system uses a custom ASIC for memory and peripheral management, and retains the IIc’s all-in-one compact design with built-in keyboard and power supply.
Key architectural features:
  • CPU: MOS Technology 65C02 @ 4 MHz (software switchable to 1 MHz for compatibility)
  • ASIC: Custom Apple chip integrates memory, I/O, and timing functions
  • ROM: 32 KB (with built-in firmware for ProDOS, AppleSoft BASIC, and utility routines)
  • System bus: 8-bit data, 16-bit address (64 KB addressable per bank)
Memory and Storage
The IIc Plus shipped with 128 KB RAM as standard, expandable up to 1 MB via third-party memory cards. The system features a built-in 3.5" double-sided 800 KB floppy disk drive, replacing the earlier IIc’s 5.25" drive. An external 5.25" drive can still be attached for backward compatibility.
  • RAM: 128 KB (expandable to 1 MB)
  • ROM: 32 KB
  • Internal storage: 3.5" Sony floppy (800 KB, GCR encoding)
  • External storage: Optional 5.25" floppy (140 KB), compatible with UniDisk 3.5 and external drives
Display and Graphics
The IIc Plus supports the same video modes as earlier Apple II models, with both colour and monochrome output:
  • Text: 40×24 or 80×24 characters (with 80-column card)
  • Graphics:
    • Low-res: 40×48 (16 colours)
    • High-res: 280×192 (6 colours)
    • Double hi-res: 560×192 (monochrome)
  • Video output: Composite video (NTSC), RGB via third-party adapters
Sound Capabilities
Sound is generated via a simple 1-bit speaker, toggled directly by software, as in all Apple II models. No dedicated sound chip is present, but third-party sound cards are supported.
  • Speaker: Internal, 1-bit digital (toggle)
  • Expansion: Supports Apple II-compatible sound peripherals
Input/Output and Expansion
The IIc Plus maintains the IIc’s compact, closed-case design, but provides a range of built-in ports for peripherals and expansion:
  • Serial ports: Two DIN-5 (modem and printer)
  • Video: Composite video output (RCA), monochrome output (DIN-8)
  • Disk port: For external 5.25" or 3.5" drives
  • Joystick/mouse port: DE-9 connector
  • Audio: Internal speaker only
  • Keyboard: Integrated
  • Expansion: Internal memory expansion slot (up to 1 MB), no standard Apple II slots
