Macintosh Performa 6200
Revision as of 23:05, 23 September 2026 by Josh (talk | contribs) (Verification drive: width and depth were swapped (Apple: 16.5 in wide, 12.6 in deep); the 1 MB frame buffer is dedicated DRAM on the logic board, not carved out of system RAM; added Apple's Repair Extension Program checks (U10 343S1191/343S1121, Cache/ROM DIMM 661-1278, U6/U27 version-B check, RGB cable) and the electrical spec; cited to the Performa 6200/6300 Service Source)
TypePersonal Computer
ReleasedJuly 11, 1995
DiscontinuedApril 1, 1996
CPUPowerPC 603 @ 75 MHz
Memory8 MB RAM (expandable to 64 MB)
Storage1 GB IDE hard drive
Display640ร—480 @ 16-bit, 800ร—600 or 832ร—624 @ 8-bit
SoundStereo 16-bit, 22 kHz
Dimensions4.3" H ร— 16.5" W ร— 12.6" D (10.95 ร— 41.95 ร— 32 cm)
Weight17 lb (7.7 kg) without CD-ROM; 19 lb (8.6 kg) with
OS / FirmwareSystem 7.5.1 โ€“ Mac OS 9.1
PredecessorQuadra 630
SuccessorPerforma 6360
CodenameCrusader
Model no.M3076
The Macintosh Performa 6200 is a PowerPC-based desktop computer introduced by Apple Computer on July 11, 1995. It is the non-CD-ROM variant of the Performa 6200CD, sharing the same logic board and case design but without the CD-ROM drive.
Differences from Performa 6200CD
The Performa 6200 differs from the Performa 6200CD only in the absence of the CD-ROM drive, offering a lower-cost entry point for consumers who did not require optical media.
The Performa 6200 uses a PowerPC 603 processor running at 75 MHz with integrated FPU.
Cache Configuration
  • L1 Cache: 16 KB on the PowerPC 603 (8 KB instruction, 8 KB data)
  • L2 Cache: 256 KB[1]
Memory and Storage
RAM Configuration
Specification Details
RAM Type 72-pin SIMM
Minimum Speed 80 ns or faster[1]
Standard RAM 8 MB minimum, fitted in one SIMM slot; none is soldered to the board[1]
Maximum RAM 64 MB across two SIMM slots[1]
RAM Slots 2[1]
ROM 4 MB[1]
The 1 MB video frame buffer is separate DRAM on the logic board, not a slice of system RAM. Apple's specification reads "DRAM Frame Buffer: 1 MB DRAM on board, for video support".[1] Fitting more system memory does not change the available video memory, and the machine does not lose 1 MB of its 8 MB to video.
Storage Systems
  • Hard Drive: 1.0 GB IDE internal drive
  • Floppy Drive: 1.44 MB 3.5" manual-inject
Display and Graphics
  • Standard Resolution: 640ร—480 at 16-bit color
  • Extended Resolution: 800ร—600 or 832ร—624 at 8-bit color
  • Frame buffer: 1 MB of dedicated DRAM on the logic board[1]
Apple ran a genuine Repair Extension Program covering system freezes and sudden changes in video colour hue on the Performa 62xx family. The published checks are specific:[1]
What to check Where What is wrong Apple's remedy
Clock chip U10 Part number is not 343S1191 or 343S1121 (ignore trailing letters) Replace the logic board
Cache/ROM DIMM Vertical DIMM on the logic board Laid out as in Apple's figure and no sticker on the middle vertical IC Replace the DIMM, part 661-1278
Version B logic board U6, with U27 on the underside U6 carries no picture of Texas and is p/n 343S0138-a, and there is no wire at U27 Replace the logic board
Ethernet card fence Communications slot Fence does not hook onto the logic board fence Replace the fence โ€” otherwise the card rocks out of the slot and the network drops intermittently
Internal RGB cable Between logic board and video board Sudden or intermittent colour-hue changes Replace the internal RGB cable
A "Version B" board shows a B at the end of the serial number printed near the communications port. Apple's diagnostic application for the programme was 5XXX/6XXX Tester, shipped on the Service Source Companion CD; it tests for the freeze-related component issues but not for colour-hue faults.[1]
Apple also directs Type 11 errors away from this programme and towards a clean system install or a third-party software update.[1]
Power
Specification Value
Line voltage 100โ€“240 VAC[1]
Frequency 47โ€“63 Hz[1]
Power 125 W. Surge voltage 300 V RMS for 100 ms; peak inrush 40 A; 2.5 A maximum and 220 W maximum for all line and load conditions[1]
Apple publishes no per-rail voltages, no rail tolerances and no power-supply adjustment procedure for this machine.
For detailed maintenance practices, refer to the dedicated Macintosh Performa 6200CD General Maintenance page.
Detailed capacitor replacement guidelines can be found on the Macintosh Performa 6200CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide is available on the Macintosh Performa 6200CD Troubleshooting page.
  1. โ†‘ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 Apple Computer, Inc., Performa 6200/6300 Series Service Source, Specifications, Troubleshooting → Symptom Charts, Additional Procedures and REA Procedures → "Repair Overview for Freezing and Video Color Hue Issues". Hosted on this wiki as File:Performa 6200.6300.pdf.
