Apple Lisa
Revision as of 17:45, 30 April 2025 by Josh (talk | contribs) (Memory Map)
Apple Lisa
Apple Lisa with ProFile hard drive
DeveloperApple Computer, Inc. (Project led by John Couch; GUI inspired by Xerox PARC)
TypePersonal/business computer
ReleasedJanuary 19, 1983
DiscontinuedAugust 1, 1986
Intro priceUS$9,995 (base model)
Units sold~10,000
CPUMotorola 68000 @ 5 MHz
Memory1 MB RAM (expandable to 2 MB)
Storage2 × 5.25″ Twiggy floppy (871 KB each); optional 5 MB ProFile hard drive
Display12″ monochrome CRT, 720 × 364 pixels
SoundInternal piezo speaker
Dimensions15.2″ H × 18.7″ W × 18.0″ D
Weight48 lb (21.8 kg)
OS / FirmwareLisa OS 1.0–3.1; Microsoft Xenix available
PredecessorApple III
SuccessorMacintosh XL
Codename“Lisa” (often backronymed “Local Integrated Software Architecture”)
Model no.A6S0200
The Apple Lisa was Apple Computer’s first personal computer to offer a complete graphical user interface (GUI) and mouse-driven interaction, targeted at business users. It pioneered features such as protected memory, cooperative multitasking, and document-centric applications. Despite its innovations, its high cost and performance limitations led to modest sales and an eventual market withdrawal.
Historical Context
In 1978, Apple launched the Lisa project under the leadership of John Couch, motivated by CEO Steve Jobs’s desire to deliver a user-friendly, office-oriented computer. Early in development, key engineers visited Xerox PARC and observed the Alto’s pioneering WIMP (Windows, Icons, Menus, Pointer) interface. Inspired by PARC’s research, Apple set out to commercialize a similar GUI. After years of hardware development delays—most notably the unreliable 5.25″ “Twiggy” floppy drives and escalating component costs—the Lisa finally debuted at nearly US$10,000. Although the GUI and software suite impressed reviewers, businesses were deterred by cost and complexity, especially as the IBM PC platform gained traction. In 1984, Apple introduced the lower-priced Macintosh, which cannibalized Lisa demand. Subsequent revisions (Lisa 2, Lisa 2/5, Lisa 2/10) adopted more reliable 3.5″ drives; the final Lisa 2/10 was rebranded as the Macintosh XL in 1985, running a Macintosh-compatible ROM. By mid-1986, Apple ceased Lisa production, shifting focus entirely to the Macintosh line.
Architecture
Memory Map
Range (hex) Size Device/Function
$000000–$00FFFF 64 KB Monitor ROM & I/O vectored jump table
$010000–$03FFFF 192 KB Lisa OS ROMs
$040000–$07FFFF 256 KB Expansion slots & I/O registers
$080000–$17FFFF 1 MB Main RAM (base)
$180000–$1FFFFF 512 KB Optional RAM board
$200000–$3FFFFF 2 MB Unused / reserved for future expansion
Lisa PDS Slots (Pinout)
Lisa’s three 0.3″-pitch card-edge connectors expose:
Pin(s) Signal Description
A0–A15, A16–A23 Address bus 24-bit addressing (high 8 bits tied low)
D0–D15 Data bus 16-bit data
/AS, /UDS, /LDS Address & data strobes Bus timing
/DTACK Data transfer ack Slave response
R/W Read/write Bus direction
/RESET, /HALT, /BG, /BR Control System control / bus arbitration
Vcc (+5V), GND Power rails +5 V supply, ground
IRQ, NMI Interrupts CPU interrupt lines
Hardware Components
Central Processor and Timing
At the core of the Lisa sits the Motorola 68000 CPU, clocked at 5 MHz. The 68000 features a 16-bit data bus with a 32-bit internal architecture, enabling efficient manipulation of large data structures required by the GUI. A 25 MHz crystal oscillator and a built-in PLL generate all bus and video timing signals, while the Lisa ASIC handles bus arbitration, DRAM refresh, and DMA for video.
Memory Subsystem
The base Lisa configuration shipped with four proprietary 256 K×1 DRAM SIMMs, totaling 1 MB of main memory—ample for multitasking document applications. An optional internal RAM expansion board added 512 KB more, bringing the maximum to 1.5 MB; some third-party upgrades further extended to 2 MB. The Lisa ASIC generates refresh cycles and multiplexes CPU and video access to main RAM, eliminating separate video RAM.
Storage Devices
Initially, Lisa employed two Shugart-mechanism “Twiggy” 5.25″ floppy drives, each offering 871 KB formatted capacity. These dual-read/write-head drives proved mechanically delicate and suffered frequent head misalignment and media wear. In 1984’s Lisa 2 upgrade, Apple replaced Twiggy with single-headed Sony 3.5″ floppy drives (400 KB per disk). Optional storage included the external 5 MB ProFile hard drive, connected via AppleBus at roughly 70 KB/s sustained transfer, and an internal “Widget” 10 MB hard drive offered on late Lisa 2/10 models.
Video Subsystem
The Lisa’s display engine is integrated into the Lisa ASIC, which performs DMA from main memory to drive a 720×364-pixel monochrome CRT at 67 Hz vertical refresh. The light-pen interface samples raster counters for X/Y position capture. Display memory resides in main RAM, with the ASIC arbitrating CPU and video access; this unified architecture simplified board design at the cost of a modest performance penalty during heavy display updates.
Input/Output and Expansion
Lisa provides two RS-422 serial ports (Mini-DIN 8-pin) for printer, modem, and AppleTalk networking; a standard parallel-printer D-sub port; and a proprietary AppleBus I/O connector for the ProFile drive. Three internal PDS (Processor Direct Slot) connectors expose the 68000’s 24-bit address bus, 16-bit data bus, and control signals, allowing third-party co-processor cards (e.g., Xenix CPU accelerators), network interfaces, and memory expansions. A simple piezo speaker inside the case generates click and beep notifications.
Operating System and Software
Lisa OS
Lisa OS 1.0 debuted with the hardware. Its WYSIWYG GUI featured overlapping windows, pull-down menus, drag-and-drop icons, and document-centric workflows (e.g., “stationery” templates). Core services provided a protected memory sandbox per application, cooperative multitasking via event-loop scheduling, and a ProDOS-inspired hierarchical file system. Subsequent OS revisions added support for larger RAM configurations and refined UI performance; the final Lisa OS 3.1 was shipped with Lisa 2/10.
Microsoft Xenix on Lisa
An optional Microsoft Xenix port transformed Lisa into a UNIX-like multi-user system when paired with the RAM expansion and ProFile HDD. Xenix on Lisa supported multiple terminal sessions over serial ports, a Bourne shell, standard UNIX utilities, and software development tools—demonstrating the Lisa’s versatility beyond its GUI orientation.
Software Suite
Apple bundled a suite of seven integrated programs under the “LisaOffice” umbrella:
  • LisaWrite – A full-featured word processor with WYSIWYG layout and proportional fonts.
  • LisaCalc – Spreadsheet with cell-based formula editing and charting.
  • LisaDraw – Vector-based drawing and illustration.
  • LisaGraph – Data visualization and chart creation.
  • LisaProject – Project management with Gantt chart scheduling.
  • LisaList – Simple database and report generator.
  • LisaTerminal – 3270/Telnet terminal emulator for host connectivity.
Variants & Evolution
Lisa 2 (1984)
  • Replaced Twiggy with a Sony 3.5″ 400 KB floppy drive.
  • Models:
Lisa 2/5 — One 3.5″ drive + ProFile 5 MB. Lisa 2/10 — Two 3.5″ drives + internal Widget 10 MB HDD.
Macintosh XL (1985)
  • Rebranded Lisa 2/10.
  • Shipped with MacWorks XL ROM emulator to run Macintosh System Software.
  • Limited to 64 KB 06 macro ROM shadowing.
The Apple Lisa was Apple Computer’s groundbreaking business-oriented personal computer, introduced on January 19, 1983. It was the first mass-market machine to feature a complete graphical user interface (GUI) and a mouse, along with advanced operating system features such as protected memory and cooperative multitasking. Despite its technical innovations, the Lisa’s high price, complex “Twiggy” floppy drives, and competition from the IBM PC and Apple’s own Macintosh led to modest sales of approximately 10,000 units before its discontinuation in August 1986.
Maintenance and Troubleshooting
Aging Lisa units commonly require:
  • Capacitor replacement – Electrolytic capacitors on the power supply and logic board often dry out, causing voltage ripple and instability.
  • Floppy drive service – Twiggy drives need head alignment and lubrication; many owners retrofit Sony 3.5″ mechanisms.
  • Hard drive care – ProFile units benefit from lubrication of the spindle motor and occasional belt replacement.
  • Keyboard and mouse cleaning – Contact oxidation in the detachable keyboard cable and mouse potentiometers can cause intermittent input.
  • Logic board reflow – Rare VLSI chips and ROM sockets benefit from careful solder reflow to restore proper connections.
For step-by-step procedures, see the dedicated Apple Lisa Maintenance Guide and Apple Lisa Troubleshooting Guide pages.
Legacy and Impact
Although commercially unsuccessful, the Lisa laid the foundational architecture for the Macintosh GUI, protected memory concepts, and integrated office productivity software. Many engineers and designers from the Lisa team transitioned to Macintosh development, carrying forward lessons in human–computer interaction and system design. Today, the Lisa is revered by historians and collectors as a pivotal moment in the evolution of personal computing.
