PowerBook 160 Troubleshooting
PowerBook 160/180 rear panel, with the reset and interrupt buttons at the right (Apple developer note, Figure 1-3)
Fault-finding on the PowerBook 160 uses Apple's symptom charts for the 160/165/180 series, which work at module level. Try the cures in the order listed, test after each, and refit the original module before trying the next.[1] The charts also cover the 165 and the active-matrix 180. Many 160s found today need their LCD and inverter recapped before the video charts are any use; see PowerBook 140 Capacitor Replacement Guide.[2]
Before you start
  • Test the adapter: 7.5-7.9 V between the inside (positive) and outside of the plug, on a meter's 10 V DC range.[1]
  • Test the main battery: below 5.7 V, recharge it first and replace it if it does not recover.[1]
  • Reset the power manager when battery and adapter are good but the machine will not start or restart. First remove the adapter and battery for 3-5 minutes, refit them and switch on. If that fails, remove them again for 3-5 minutes and then hold the reset and interrupt buttons on the back down together with two paper clips for 5-10 seconds before refitting and switching on.[1]
  • Check the backup battery: set the time, shut down, remove the main battery and adapter for ten minutes, and switch on again. If the time is lost, leave the machine on the adapter for 48 hours to recharge the cell, and replace it if that does not work.[1]
Power
Symptom Probable cause Action
Blank screen, no response Battery; power manager; connections; keyboard; boards Apple's order: restart; connect the adapter and restart after 3-4 minutes; try a known-good battery; check the interconnect board, daughterboard and motherboard connections; reset the power manager; replace the keyboard, interconnect board, daughterboard, motherboard[1]
Settings lost after removing the main battery Backup cell; cables; interconnect board; boards Check cables; replace the interconnect board, daughterboard, motherboard. Test the backup cell first as above[1]
Battery desk accessory does not show the charger Normal with a full battery; connection; battery; adapter; thermistor cable Apple notes this is normal when the battery is fully charged; otherwise check the charger connection, try a known-good battery and adapter, check the battery thermistor cable, replace the motherboard[1]
Runs on the adapter, not on a good battery Battery contacts; fuse; motherboard Reseat the battery; replace the removable fuse on motherboards that have one; replace the motherboard[1]
Intermittent shut-downs or failed boots Worn DC jack croissantking found failing jacks on several 140-180 machines and replaces them as routine[3]
Startup
Eight-tone error chord after the startup chime RAM Reseat and check the PSRAM card; replace the card, the daughterboard, the motherboard[1]
Eight-tone chord only with a RAM card fitted Wrong or faulty card Apple's minimum RAM speed for the 160 is 85 ns. Wawavoun's 160 failed with a card using 100 ns chips, and his daughterboard reported only 2 MB of its 4 MB, which pointed to a faulty board[4][5]
Four-tone error chord Drive or motherboard Disconnect the hard disk cable and restart; if normal, reconnect and retest, then replace the drive. Repeat with the floppy cable. Then replace the motherboard[1]
Checkerboard, no chime RAM card; daughterboard; display cable Reseat and replace the RAM card; replace the daughterboard; reseat the display cable[1]
Video
On the 160 and 165, Apple treats a thin white line across the middle, rainbow colours at extreme angles, uneven brightness and a display that fails below about 5 °C or above 40 °C and recovers as normal.[1] Owners add ghosting around window edges to that list.[6]
Blank grey screen, backlight on, machine runs Leaking LCD capacitors 3lectr1cPPC's diagnosis for this symptom: recap the LCD[7]
Picture visible only at a steep angle after an LCD recap; contrast slider washes it out Inverter capacitors DaveW cured this by replacing the inverter's 33 µF and 47 µF capacitors[8]
Picture fluctuates between nearly right and washed out after a recap Poor joints, leftover electrolyte, dirty contrast control j2theLj redid a first recap whose joints were poor; 3lectr1cPPC also suspected a dirty contrast potentiometer[9]
Contrast usable over only a few millimetres of slider travel Worn or dirty contrast control Shaddam IV's 160 showed this, and he set out to clean the slider. 3lectr1cPPC suggested contact cleaner on the slider for a similar fault on a 145[10][11]
Row or part row never on (white line) Cables; display cable; display; interconnect board Check cables; replace the display cable and display; replace the interconnect board. Apple: on a 160 or 165 with a serial number below FC247xxxxxx or CK247xxxxxx, replace both the display and the daughterboard (but not a Rev. B daughterboard)[1]
Row or part row always on (black line) Cables; display cable; display; interconnect board Check cables; replace the display cable, display, interconnect board[1]
Flicker, two black lines, picture going dark Display cable contact If squeezing the right side of the bezel changes it, fit Apple's shim to the display cable[1]
Very light or white picture Contrast; connections; inverter; interconnect board; cable; display; boards Adjust contrast; check connections; replace the inverter, interconnect board, display cable, display, daughterboard, motherboard[1]
Backlight does not light Pinched or cut cables; inverter; inverter cable; boards Check the cables are not pinched or cut; check connections; replace the inverter, inverter cable, interconnect board, display cable, display, daughterboard, motherboard[1]
Screen goes blank Sleep; display cable; daughterboard Press a key; check the display cable; reseat and then replace the daughterboard[1]
Polariser darkening or blotching after storage Polariser breakdown (vinegar syndrome) mitchW's 160 developed it after two years in storage; the remedy is new polariser film[12]
Drives, keyboard and peripherals
Internal hard disk does not work External SCSI devices; cable; driver; drive; motherboard Disconnect external SCSI devices; check the cable; reinitialise with HD SC Setup; replace the cable, drive, motherboard[1] Original Conner and Quantum drives are now unreliable, and non-Apple SCSI drives need a third-party formatter[5]
Floppy initialisation or read and write errors Media; missing inverter shield; cable; drive Try a known-good disk; fit an inverter shield if absent; check and replace the cable and drive[1]
No response from any key Power manager; keyboard and interconnect connections; keyboard; boards Reset the power manager; check the keyboard to interconnect and interconnect to daughterboard connections; replace the keyboard, interconnect board, daughterboard[1] Broken wires in the interconnect board's flexible cable also kill keys[3]
Cursor does not move with the trackball Connections; trackball; keyboard; boards Restart; check cables and connections; try a low-power ADB mouse and, if it works, replace the trackball or keyboard; replace the interconnect board, daughterboard, motherboard[1]
No sound from the speaker Volume; external speaker plugged in; connections; boards Set the volume above 0; unplug any external speaker; check the speaker, interconnect, daughterboard and motherboard connections; replace the interconnect board, daughterboard, motherboard[1]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 1.20 1.21 1.22 1.23 Apple Computer, PowerBook 160/165/180 Series Service Source, hosted here as File:PowerBook 160, 165 and 180 Service Source.pdf (see PowerBook 160, 165 and 180 Service Source). PDF page numbers: General p. 20; Power Manager Reset pp. 21-22; Symptom Charts: Startup pp. 23-24, Power pp. 25-27, Video pp. 28-37, Hard Drive p. 39, Floppy Drive pp. 40-42, Peripherals pp. 43-48, Internal Modem pp. 49-51, Miscellaneous pp. 52-53; Battery Verification pp. 150-151; AC Adapter Verification pp. 152-153; Shim Installation pp. 154-160; Backup Battery Verification pp. 166-167.
  2. ↑ MacDat, "Capacitor Reference - PowerBook 160" (retrieved 2026-10-02). LCD, inverter and trackball capacitors; none on the logic board. Secondary source.
  3. ↑ 3.0 3.1 68kMLA forum thread "How to repair a Powerbook 140-180 interconnect cable", January 2024 to February 2026. croissantking: interconnect cable rebuild on a 160/165/180 (72-pin); dead keys and brightness controls from broken wires; failing DC jacks cause intermittent shut-downs and failed boots. Community repair guide.
  4. ↑ Apple, "Macintosh PowerBook 160: Technical Specifications" (retrieved 2026-10-02). Minimum RAM speed 85 ns; RAM 4-14 MB.
  5. ↑ 5.0 5.1 68kMLA forum thread "Powerbook 160 revival !", July 2022. Wawavoun: death chord with a PSRAM card whose chips were marked -10 (100 ns) against -85 on the daughterboard; the system showed 2 MB of the 4 MB on the daughterboard; 3lectr1cPPC: original Conner and Quantum drives are unreliable, IBM-branded ones less so; non-Apple SCSI drives need a third-party formatter. Community repair report.
  6. ↑ 68kMLA forum thread "Newly recapped Powerbook 160, screen artifacts or typical passive matrix?", August 2025. Ghosting normal; croissantking: brightness should go from off to low and then rise gradually; a jump from off to high has cleared by itself on his machines, possibly related to the PRAM battery or the daughtercard interconnect cable; Shaddam IV and Byrd: CCFL tubes dim with age. Community experience.
  7. ↑ 68kMLA forum thread "PowerBook 160 Blank Screen", September 2023. Blank grey screen; 3lectr1cPPC: the LCD capacitors are bad. Community experience.
  8. ↑ 68kMLA forum thread "Powerbook 160 display can only be read off-axis", March 2026. ObeyDaleks suggested the inverter; DaveW replaced its 33 µF 10 V and 47 µF 16 V capacitors and the contrast returned. Community repair report.
  9. ↑ 68kMLA forum thread "PowerBook 160 Screen issues", February 2023. imactheknife: check the solder and clean off the leakage; 3lectr1cPPC: dirty contrast slider or leftover leakage. Community repair report.
  10. ↑ 68kMLA forum thread "PowerBook 145: No contrast AFTER recap", January 2022. Spode: contrast barely changes until the end of the slider's travel; 3lectr1cPPC: the slider may be bad and may need DeoxIT. Community experience.
  11. ↑ 68kMLA forum thread "Powerbook 160 contrast slider cleaning", December 2023. Shaddam IV: contrast changes only within about 3 mm either side of centre. Community report.
  12. ↑ 68kMLA forum thread "PowerBook 160 with vinegar syndrome LCD", March 2024. Community report.
