PowerBook G4 (Titanium) Troubleshooting
PowerBook G4 (1GHz/867MHz) (Ashley Pomeroy, Wikimedia Commons, CC BY-SA 4.0)
Fault-finding on the four PowerBook G4 (Titanium) models. Apple's charts list the steps in order: try each, test, and refit the original part before moving on.[1][2][3] The charts for the DVI and 1 GHz models are the fullest; the first model's Service Source carries Apple's 2001 troubleshooting articles. Disassembly is on PowerBook G4 (Titanium) General Maintenance.
Will not start
Symptom Probable cause Action
No fan, no drive, no backlight Battery, adapter, power manager, keyboard, DC-in board, logic board Apple's order (DVI and 1 GHz): remove peripherals; press the battery button and check that at least one LED lights steadily; fit a known-good adapter of the right type and check that the DC plug lights; try without the battery; if Caps Lock lights, hold the power button six seconds and restart; reset the power manager with a non-metallic tool on the button left of the power button; check the power button cable; disconnect the keyboard; remove extra RAM and the AirPort Card; check and then replace the DC-in board; replace the logic board[1][2]
DC plug does not light DC-in board With a known-good adapter, replace the DC-in board[1][2]
Dead, or starts only intermittently, on the first model Flat backup battery Unplug the backup battery; owners have revived machines this way[4][5]
Adapter light green with no battery; amber then off with the battery fitted; fans run for a second (DVI) DC-in board or logic board joshc's machine was not fixed by disconnecting the backup battery or resetting the power manager; the forum suspected the DC-in board or logic board[6]
Fan and drive run, Caps Lock lights, but no chime or video Power manager, logic board Reset the power manager, wait five seconds and press the power button; then replace the logic board[1][2]
One beep at power-on No RAM found (there is none on the logic board) Refit the original or known-good memory; then the logic board[3][1]
Two beeps EDO memory fitted Fit compatible SDRAM[3][1]
Three beeps No memory bank passed Remove the upper module and restart; replace the lower module; then the logic board[3][1]
Four beeps Bad boot ROM checksum The ROM is on the logic board; after trying known-good memory, replace the logic board[3][1]
Flashing question mark Drive, flex cable, system Start from the restore disc; check and repair the drive in Disk Utility or Disk First Aid; reinstall the system; reseat the hard drive flex cable; replace the drive[1][2]
Mac OS 9 will not install from a retail CD Disc too old for the machine Mighty Jabba needed the machine's original restore CD[4]
Shut-downs and crashes
Shuts down intermittently Battery seating, overheating, fan, heat exchanger, adapter, DC-in board Disconnect peripherals; check the battery is fully in and charged; keep the vents clear and the machine off soft surfaces; check the fan and its cable; check the heat exchanger seating (new thermal material if it was separated); try a known-good adapter with the battery out and watch the DC plug light; then the DC-in board and logic board[1]
Shuts down just after startup Battery, logic board Check the battery and its connection; replace the logic board[1]
Kernel panic or "built-in memory test has detected an error" Memory Remove the upper module and retest; replace modules one at a time; run Apple Hardware Test in loop mode[1]
L2 cache missing or reported failed (400 MHz) Cache SRAMs, solder joints or processor Ivan Holmes's machine has two Samsung K7A403600M-QC20 SRAMs; reflowing them did not cure it[7]
Display
No picture or a dim picture, machine otherwise working Brightness, adapter, cables, inverter Remove peripherals; check that F1 is not stuck down; press F2 with and without Fn; restart; on the DVI model check that the correct adapter is fitted; check the inverter and LVDS cable connections and the cables for damage; replace the inverter board, then the display assembly, then the logic board[1][3]
Stripes or spots that change when the lid moves LVDS cable didius traced this on a DVI model to the LVDS cable; Apple's procedure for a damaged display cable is a new display module[8][3]
Striped picture after hinge work Display cables twisted Re-route the cables as they were[8]
No picture on a TV via S-video Connection order Connect the device while the computer is asleep or off[1]
Lid will not latch Display hook or top case latch The hook in the display is pulled down magnetically and should retract when the button is pressed; a faulty hook means a display assembly, a faulty latch or button a top case[1][3]
Battery, clock and sound
Battery will not eject Latch, rib chassis Hold the latch towards the PC Card button and ease the battery out with a plastic tool; if the latch does not move smoothly, Apple replaces the rib chassis assembly[3]
Date and time keep resetting Stuck reset button; backup battery; PMU card or logic board Check the reset button is not stuck; do the backup battery test; leave the machine on the adapter with the main battery out for at least five hours; then replace the backup battery, and after that the PMU card (first model) or logic board (DVI)[3][1]
No sound from the speakers Settings, cables, speaker wiring Reset PRAM; check the speaker cables at the logic board. If headphones work, Apple replaces the heat exchanger, which carries the speaker wires; then the top case and logic board.[1] Use the headphone jack on the side when testing: ScutBoy spent time testing the line-in jack at the back by mistake[9]
No sound and the Sound control panel shows an external device Headphone jack sensing Plug headphones in and out, restart, reset PRAM; then the logic board[3]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 Apple Computer, PowerBook G4 (DVI) Service Source, hosted here as File:PowerBook G4 (DVI) Service Source.pdf (see PowerBook G4 (Titanium) Documentation). Symptom charts, PDF pages: startup pp. 3-5; error beeps pp. 5-7; sound pp. 14-15; video p. 15; latch, date and time p. 16.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 Apple Computer, PowerBook G4 (1GHz/867MHz) Service Source, hosted here as File:PowerBook G4 (1GHz-867MHz) Service Source.pdf. Symptom charts, PDF pp. 113-115: will not power on, memory errors, flashing question mark, no chime or video, shut-downs; 65 W adapter 661-1798.
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 Apple Computer, PowerBook G4 Service Source (400 and 500 MHz), hosted here as File:PowerBook G4 (Titanium) Service Source.pdf. Troubleshooting articles of July-August 2001, PDF pp. 97-130: battery will not eject, latch not working, date and time resets (p. 121), error beeps (p. 127), no display or dim display; LVDS cable warnings pp. 70, 80, 82.
  4. ↑ 4.0 4.1 68kMLA forum thread "A tale of 3 Tibooks...", Mighty Jabba, October 2019. A non-working 500 MHz model showed signs of life after its PRAM battery was unplugged but still booted unreliably from its own drive. Community repair report.
  5. ↑ 68kMLA forum threads "Pram battery for titanium PowerBook g4 500 mhz", gheem, February 2023, and "Powerbook G4 titanium (Mercury model) won't turn on", Maxplayz51 and s_pupp, June 2024. Running with the PRAM battery unplugged; a bad PRAM battery suspected of stopping the early model starting. Community reports.
  6. ↑ 68kMLA forum thread "A1001 PowerBook G4 Titanium DVI startup/power problems", joshc and others, June 2023. Unresolved community report.
  7. ↑ 68kMLA forum thread "PowerBook G4 Titanium (400 MHz) cache chip replacement", Ivan Holmes and herd, July 2025. Unresolved community repair report.
  8. ↑ 8.0 8.1 68kMLA forum thread "TiBook with a screen problem", didius, Patnukem and Da Penguin, April-May 2008. Stripes on a DVI model's screen with the slightest cable movement; cables twisted during a hinge rebuild. Community repair report.
  9. ↑ 68kMLA forum thread "Late Gen Ti - No sound", ScutBoy, August 2020. Community report.
