Power Macintosh 6100
This page contains detailed technical specifications for the Power Macintosh 6100 series.
Model Configurations
Power Macintosh 6100 Model Configurations
Model
Order Number
Processor
Bus Speed
L2 Cache
RAM
Hard Drive
CD-ROM
Price
6100/60
M2197LL/A
60 MHz
30 MHz
Optional 256k
8 MB
160 MB
None
$1,820
6100/60
M1878LL/A
60 MHz
30 MHz
Optional 256k
8 MB
160 MB
2X
$2,000
6100/60
M3078LL/A
60 MHz
30 MHz
Optional 256k
16 MB
250 MB
2X
$2,350
6100/66
M3631LL/A
66 MHz
33 MHz
256k
8 MB
350 MB
None
$1,750
6100/66
M3632LL/A
66 MHz
33 MHz
256k
8 MB
350 MB
2X
$1,950
6100/66 (PC)
M3972LL/A
66 MHz
33 MHz
256k
8 MB
500 MB
2X
$2,150
Model Number: M1596 | Gestalt ID: 75 (6100/60), 100 (6100/66)
Processor Specifications
CPU Specifications
Specification
6100/60
6100/66
Processor
PowerPC 601
PowerPC 601
Clock Speed
60 MHz
66 MHz
Architecture
32-bit RISC
32-bit RISC
Data Path
64-bit
64-bit
FPU
Integrated
Integrated
System Bus
30 MHz
33 MHz
L1 Cache
32 KB
32 KB
L2 Cache
Optional 256 KB
256 KB (standard)
Memory Specifications
RAM Specifications
Specification
Value
RAM Type
72-pin SIMM
Minimum Speed
80 ns
RAM Slots
2
Onboard RAM
8 MB
Standard RAM
8โ16 MB (varies by model)
Maximum RAM
72 MB [ 1]
SIMM rule
Must be fitted as a pair of the same size and speed; non-composite SIMMs only[ 1]
Apple's figure of 72 MB assumes the SIMM sizes on sale at the time. Larger non-composite
72-pin SIMMs are often reported to work, but Apple publishes no figure above 72 MB and no
source has been found for a higher one, so none is given here.
ROM
ROM Specifications
Specification
Value
ROM Type
Macintosh ROM
ROM Size
4 MB
Video Specifications
Specification
Value
Video Type
Built-in DRAM-based video on the logic board[ 1]
Video RAM
None fitted. Apple lists VRAM as "None" for every non-AV 6100 and 6150; the frame buffer is taken from main DRAM[ 1]
VRAM Upgradeable
No (the optional Power Macintosh AV Card carries its own 2 MB of VRAM)[ 1]
Maximum Resolution (16-bit)
640ร480
Maximum Resolution (8-bit)
832ร624
Second Display
Supported with NuBus video card (requires adapter)
Supported Display Modes
Resolution
Color Depth
512ร384
16-bit (thousands)
640ร480
16-bit (thousands)
832ร624
8-bit (256 colors)
Storage Specifications
Component
Specification
Hard Drive Interface
SCSI
Hard Drive Capacity
160, 250, 350, or 500 MB (varies by model)
Floppy Drive
1.44 MB 3.5" (manual eject)
CD-ROM
2X (optional or standard depending on model)
Audio Specifications
Specification
Value
Audio Output
16-bit stereo out[ 1]
Audio Input
16-bit stereo in[ 1]
Sample Rates
48, 44.1, 24 and 22.05 kHz[ 1]
Line Level
1 V peak-to-peak in and out[ 1]
Signal-to-Noise Ratio
82 dB, with no audible discrete tones[ 1]
Bandwidth
20 Hz โ 20 kHz (ยฑ2 dB) at a 44.1 kHz sample rate[ 1]
THD+N
Less than 0.05%, measured 20 Hz โ 20 kHz with a 1 V RMS sine input[ 1]
Expansion and Ports
Expansion Slots
Slot Type
Quantity
Notes
601 PDS
1
Processor Direct Slot
NuBus
1 (via adapter)
Requires M1402LL/A PDS-to-NuBus adapter
Drive Bay
1
Front-facing 5.25" (if no CD-ROM installed)
Ports
Port
Quantity
Notes
Serial
2
RS-232/RS-422 LocalTalk/GeoPort ports on mini DIN-9 connectors, backward compatible with mini DIN-8[ 1]
ADB
1
Apple Desktop Bus. Maximum draw 500 mA; maximum of three devices in total[ 1]
SCSI
1
External DB-25 connector. Supports six external devices, or five when a CD-ROM drive is fitted[ 1]
Video Out
1
HDI-45 DRAM-based video port. An HDI-45 to DB-15 adapter was supplied in the box[ 1]
Audio In
1
Stereo 3.5mm jack
Audio Out
1
Stereo 3.5mm jack
Ethernet
1
AAUI-15
Physical Specifications
Physical Dimensions
Specification
Imperial
Metric
Height
3.4 inches
8.6 cm
Width
16.3 inches
41.4 cm
Depth
15.6 inches
39.6 cm
Weight
14.0 lbs
6.4 kg
Power Specifications
Power Requirements
Specification
Value
A/C line input voltage
100โ240 VAC, RMS single phase, automatically configured [ 1]
Input line frequency
50โ60 Hz[ 1]
Input power
132 W maximum continuous, 201 W peak (not including monitor power)[ 1]
Power supply DC output
86 W continuous [ 1]
Apple publishes no per-rail voltages, no rail tolerances and no power-supply adjustment
procedure for this machine; the Service Source electrical specification stops at the four
figures above.[ 1] See Power Macintosh 6100 General Maintenance for what
can usefully be measured instead.
Operating System Support
Software Compatibility
Specification
Value
Original OS
System 7.1.2
Maximum OS
Mac OS 9.1
Supported Range
System 7.1.2โ7.5.1, 7.5.3โ9.1
Note
Mac OS 7.5.2 not supported
Timeline
Product Timeline
Event
Date
6100/60 Introduction
March 14, 1994
6100/60 Discontinued
January 3, 1995
6100/66 Introduction
January 3, 1995
6100/66 Discontinued
October 14, 1995
DOS Compatible Card Specifications
PC Compatibility Card (Optional)
Specification
Value
Processor
Intel 486DX2
Clock Speed
66 MHz
Maximum RAM
32 MB (dedicated)
Interface
NuBus
Operating System
MS-DOS, Windows 3.1
Related Pages
Apple Computers (1976-2001)
Apple I & II Series (1976-1993) Lisa Series (1983-1986) Compact Macintosh (1984-1998)
Original Compact Classic Series LC 500 Series
Macintosh II Series (1987-1993) LC Series (1990-1998)
Desktop LC All-in-One LC Special LC
Centris & Quadra (1992-1995)
Centris Quadra Desktop Quadra Tower
Performa Series (1992-1997)
200-400 Series 500-600 Series 5000 Series 6000 Series
PowerBook (1991-2001)
100 Series Duo Series 500 Series 5000/1400/2400/3400 Series PowerBook G3 PowerBook G4
Macintosh Portable (1989-1991) Power Macintosh (1994-2001)
First Generation (NuBus) Second Generation (PCI) Third Generation G3 Series G4 Series
iMac (1998-2001)
iBook (1999-2001) Server Products (1993-2001)
Workgroup Server Network Server Mac OS Server
Special Models
