Macintosh Performa 5420CD
| Performa 5400 chassis. The 5420 is the same machine in graphite-coloured plastics | |
| Type | All-in-one Personal Computer |
| Released | April 22, 1996 |
| Discontinued | February 1, 1997 |
| CPU | PowerPC 603e @ 120 MHz |
| Memory | 8 MB soldered on the logic board, expandable to 136 MB |
| Storage | 1.6 GB IDE hard drive, 4X CD-ROM |
| Display | 15" shadow mask CRT (640ร480 16-bit, 832ร624 8-bit) |
| Sound | 16-bit stereophonic input and output with SRS surround, nominally 0.5 V RMS into 39 ohms |
| Dimensions | 17.5" H ร 16.0" W ร 15.1" D (445 ร 406 ร 383 mm) |
| Weight | 47 lbs (21.3 kg) |
| OS / Firmware | System 7.5.3 โ Mac OS 9.1 |
| Predecessor | Performa 5300 |
| Successor | Power Macintosh 5500 series |
| Codename | Alchemy |
| Model no. | M3046 |
The Macintosh Performa 5420CD is an all-in-one personal computer manufactured by Apple Computer, Inc. Apple describes it plainly: "The Performa 5420 is a graphite-colored Power Macintosh 5400/120 initially sold in Japan only. Plastic exterior parts for the Performa 5420 are in the graphite color, and all other hardware features are the same as the Power Macintosh 5400/120."[1]
Differences from the Power Macintosh 5400/120
The difference Apple documents is the colour of the plastics, not the software bundle:[1]
- Colour: graphite-coloured exterior plastics rather than the usual beige. Replacement plastic parts for this model are ordered in graphite
- Market: Japan initially
Every other hardware feature is that of the Power Macintosh 5400/120.
A separate model: the Performa 5420/180
Apple's manual also lists a Performa 5420/180, which is a different machine: a graphite-coloured unit sold in Japan and Australia, with a PowerPC 603ev at 180 MHz, 16 MB of RAM on the logic board, and a 1.6 GB or 2.4 GB hard drive. It is otherwise the Power Macintosh 5400/180.[1] The two should not be conflated โ the plain 5420 is a 120 MHz machine and the 5420/180 is not.
The Performa 5420CD uses a PowerPC 603e processor running at 120 MHz. Apple describes the addressing as a 64-bit PowerPC bus; it publishes no bus clock figure for this machine, so none is given here.[1]
Cache Configuration
- L1 Cache: 32 KB (16 KB instruction, 16 KB data)
- L2 Cache: optional 256 KB, on a 160-pin DIMM card[1]
Memory and Storage
RAM Configuration
| Specification | Details |
| RAM Type | 168-pin DIMM |
| DIMM specification | JEDEC standard, 168-pin, 70 ns or faster, 2K refresh rate[1] |
| Motherboard RAM | 8 MB soldered (the 5400/120 configuration this machine is based on)[1] |
| Maximum RAM | 136 MB[1] |
| RAM Slots | 2[1] |
| ROM | 4 MB[1] |
| Frame buffer | 1 MB of DRAM on the logic board, dedicated to video[1] |
Storage Systems
- Hard Drive: 1.2 GB or 1.6 GB IDE, as for the Power Macintosh 5400/120[1]
- Floppy Drive: 1.4 MB Apple SuperDrive, manual insert[1]
- CD-ROM: AppleCD 600i (4ร) as standard on the 5400/120[1]
- SCSI: one external DB-25 port supporting up to seven devices[1]
Display and Graphics
The built-in display is a 15-inch shadow-mask CRT with a 12.8-inch viewable image, 0.28 mm dot pitch, 66.7 Hz vertical frequency, 240 ร 185 mm nominal active raster, 9,300 K white point and an aluminised P22-derivative phosphor.[1]
Apple's published video modes for the 5400 series:[1]
- 640ร480 at 16-bit colour, 60 Hz or 67 Hz
- 800ร600 at 16-bit colour, 60 Hz or 72 Hz
- 832ร624 at 8-bit colour, 75 Hz โ this mode does not support video input
Power
- Line voltage: 100โ240 VAC; frequency: 47โ63 Hz; power: 125 W[1]
- Supply rated 2.5 A maximum and 220 W maximum for all line and load conditions; surge 300 V RMS for 100 ms; peak inrush 40 A[1]
Apple publishes no per-rail voltage or tolerance for this machine. It does publish a high-voltage adjustment โ 29.5 V DC ยฑ 0.1 V at the cathode of D713 (Rev. A) or D703 (Rev. B), set with VR501 or VR702 โ which is covered on Macintosh Performa 5400 General Maintenance.[1]
For detailed maintenance practices, refer to the dedicated Macintosh Performa 5400CD General Maintenance page.
Detailed capacitor replacement guidelines can be found on the Macintosh Performa 5400CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide is available on the Macintosh Performa 5400CD Troubleshooting page.
- Macintosh Performa 5400CD โ Base model
- Macintosh Performa 5410CD โ Europe variant
- Macintosh Performa 5430
- Power Macintosh 5400 โ the model the 5420 is based on
- โ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 Apple Computer, Inc., Power Macintosh/Performa 5400 and 5500 Series Service Source, Basics → Configurations ("The Performa 5420 is a graphite-colored Power Macintosh 5400/120 initially sold in Japan only\u2026 all other hardware features are the same as the Power Macintosh 5400/120") and Specifications. Hosted on this wiki as File:Powermac.perf 5400.5500.pdf.
