Macintosh Quadra 800 General Maintenance
Proper maintenance is essential to extending the lifespan and ensuring reliable operation of your Macintosh Quadra 800. The following sections provide in-depth guidance on cleaning, battery management, and component inspection.
Regular Cleaning
Internal Cleaning
- Power off the system and disconnect all cables before opening
- Use compressed air to remove dust from the interior, paying attention to the power supply vents and fan
- Clean the NuBus slots and PDS slot with compressed air to ensure good contact
- Inspect and clean the SIMM slots if memory errors occur
External Cleaning
- Wipe the case with a slightly damp, lint-free cloth
- Use isopropyl alcohol (90% or higher) for stubborn marks
- Clean the floppy drive opening with compressed air
- Wipe the CD-ROM tray (if equipped) with a soft cloth
Keyboard and Mouse Cleaning
- The Apple Desktop Bus Mouse II included with the Quadra 800 uses a ball mechanism
- Remove the ball and clean it with isopropyl alcohol
- Clean the internal rollers with a cotton swab
- For keyboards, remove keycaps and clean with compressed air
PRAM Battery Handling
The Quadra 800 uses a lithium battery in a clip-in holder on the logic board โ the familiar 3.6 V half-AA lithium-thionyl-chloride cell. Do not substitute an alkaline cell.
Apple's own check
Apple's Battery Verification procedure requires the cover and the logic board to be removed first:[1]
- Set the voltmeter to the 10 V DC scale.
- Hold the positive probe to the positive end of the battery โ the end marked "+" on the logic board โ and the negative probe to the negative end.
- If the battery voltage is below 3.2 V, replace the battery.[1]
3.2 V is the threshold Apple publishes for this machine. Thresholds are machine-specific and have been transplanted between models: the Performa 5000 series uses 3.0 V, the Macintosh IIci and SE/30 use 2.8 V. Use the figure for the machine in front of you.
Apple publishes no replacement interval. Replace on measurement, or on symptoms โ a lost clock, a forgotten startup disk, a machine that resets its settings whenever it is unplugged.
To replace it, prise open the latch at the end of the battery holder with a small flat-blade screwdriver, lift off the cover and lift the cell out.[1]
Cleaning Battery Leakage
A lithium-thionyl-chloride cell is not alkaline, and vinegar is the wrong treatment for it. Its electrolyte hydrolyses to acidic products, so neutralise with a weak bicarbonate of soda solution. Vinegar belongs to alkaline cells such as the 4.5 V pack used in the Performa 5000 and 6000 series.
- Remove the cell immediately and ventilate the area โ a vented lithium cell releases sulphur dioxide
- Neutralise with bicarbonate of soda solution, then clean with isopropyl alcohol
- Inspect nearby traces and components under magnification
- See Battery Explosion, Capacitor or Corrosion Damage for the full procedure
Connector and Socket Corrosion
Key Areas to Check
- SIMM slots โ Oxidation can cause memory errors; clean contacts with DeoxIT or isopropyl alcohol
- VRAM slots โ Same cleaning procedure as SIMM slots
- NuBus slots โ Inspect for bent pins or corrosion; clean with DeoxIT
- PDS slot โ Essential if using cache cards or accelerators
- ADB ports โ Check for bent pins if keyboard/mouse are unreliable
- Serial ports โ Clean if experiencing communication issues
- SCSI connector โ Inspect pins and clean with contact cleaner
Use DeoxIT D5 or similar contact cleaner for best results on all connectors.
Common Failure Points
Power Supply
Apple's electrical specification for the Quadra 800 is 100โ240 VAC, 50โ60 Hz single phase, 200 W continuous. Note 50โ60 Hz: a range of 47โ63 Hz belongs to other Apple machines of the period and is often quoted for this one by mistake.[1] Common issues include:
- Failing capacitors causing startup problems
- Fan failure leading to overheating
There is no "voltage drift requiring adjustment" to chase: Apple publishes no rail tolerances and no power-supply adjustment procedure for this machine. See Voltage checks below.
Capacitor Health
While the Quadra 800's logic board uses through-hole capacitors (unlike the surface-mount electrolytics in earlier compact Macs), they can still fail with age. See the Macintosh Quadra 800 Capacitor Replacement Guide for details.
PRAM Battery Damage
A leaking PRAM battery can cause extensive damage to nearby traces and components. Inspect regularly and replace proactively.
Logic Board Removal Difficulty
The Quadra 800's case design requires logic board removal for RAM or VRAM upgrades โ and Apple's own battery verification procedure also begins by removing the logic board, so this is a routine operation on this machine rather than a last resort.[1] Take care with the plastic clips securing the board; they become brittle and break. Photograph cable positions before disconnecting anything.
Internal SCSI Cables
The internal SCSI ribbon cables can come loose during service. Ensure all connections are secure before reassembly.
Voltage checks
Apple publishes no per-rail voltages, no rail tolerances and no power-supply adjustment procedure for the Quadra 800. The Service Source electrical specification gives the input side only: 100โ240 VAC, 50โ60 Hz, 200 W continuous.[1]
The "+5 V 4.85โ5.15 V / +12 V 11.9โ12.7 V" table that circulates for this machine is Apple's Macintosh Plus adjustment procedure โ genuine there, performed with voltage test cable 077-0135 on the external floppy port, and with an upper bound of 12.75 V rather than 12.7 V. The Quadra 800 has no such procedure and no such test point.
What you can usefully check instead:
- The +5 V rail against the specification of the 5 V logic it feeds, which is 5 V ยฑ5 per cent โ 4.75 V to 5.25 V.
- That each rail holds steady when a drive spins up, rather than sagging.
- Ripple on an oscilloscope. A dried output capacitor shows up as ripple long before the DC average moves.
Expansion slots
The Quadra 800 has three NuBus slots, occupying expansion slot addresses $C, $D and $E, plus a processor-direct slot connected straight to the MC68040 by way of the system bus.[2]
The PDS lines up with NuBus slot $E, so fitting a PDS card reduces the usable NuBus slots from three to two.[2] This catches people who count slots rather than reading the developer note.
The NuBus here includes several NuBus '90 features, among them a 20 MHz clock โ twice the standard 10 MHz rate. Double-rate block transfers are supported between NuBus cards but not to or from the main logic board.[2]
RAM is on four 72-pin SIMM slots with 8 MB soldered on the logic board, for a maximum of 136 MB. These are not the 30-pin SIMMs of older Macintoshes, nor the 64-pin SIMMs used in the Macintosh IIfx and in LaserWriter printers.[2]
SCSI Maintenance
The Quadra 800's SCSI bus supports a maximum of eight devices in total, including the computer itself, which is always device 7 โ internal and external devices share that count.{SS} The earlier claim that the machine "supports up to 7 internal SCSI devices" was wrong on both numbers and on the internal/external split.
Automatic external termination
Do not fit an external terminator on an empty Quadra 800 SCSI port. The Centris 610, Centris 650 and Quadra 800 introduced automatic termination: when no external device is connected, circuitry on the logic board near the external connector terminates the bus. When one or more external devices are connected, that circuitry detects the external termination during system reset and disconnects the on-board termination.{DN}
Internal SCSI
- Apple's rule for this machine is that the device at the end of the internal cable carries terminators and every other internal device does not. When fitting a drive, check that the end device is terminated and remove terminators from the others{DN}
- Ensure SCSI IDs do not clash (the hard drive is usually ID 0, an internal CD-ROM usually ID 3)
- The internal SCSI ribbon cables can work loose during service; check them before closing the case
If storing the Quadra 800 long-term:
- Remove the PRAM battery
- Store in a cool, dry location
- Cover to prevent dust accumulation
- Store hard drives horizontally
- Consider removing and separately storing any NuBus cards
Physical specification
| Dimension | Value |
| Height | 14.25 in. (360 mm)[1] |
| Width | 7.75 in. (196 mm)[1] |
| Depth | 16 in. (396 mm)[1] |
| Weight | 24 lb (11.3 kg)[1] |
| Operating temperature | 10โ40 ยฐC (50โ104 ยฐF)[1] |
- โ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Apple Computer, Inc., Macintosh Quadra 800/WS 80 Service Source, Specifications (I/O Interfaces, Electrical, Physical) and Additional Procedures → Battery Verification and Battery Replacement. Hosted on this wiki as File:Quadra 800.ws 80.pdf.
- โ 2.0 2.1 2.2 2.3 Apple Computer, Inc., Macintosh Centris 610, Macintosh Centris 650, and Macintosh Quadra 800 Developer Note: RAM and RAM SIMMs; SCSI Bus and Termination (Automatic SCSI Termination, Installing Internal SCSI Devices); Expansion Slots (NuBus Slots, The Processor-Direct Slot, NuBus โ90 Features). Hosted on this wiki as File:Macintosh Centris 610 Centris 650 and Quadra 800 Developer Note.pdf.
Related Maintenance Pages
- Macintosh Quadra 800
- Macintosh Quadra 800 Troubleshooting
- Macintosh Quadra 800 Capacitor Replacement Guide
