Power Macintosh 6100 Specifications
Revision as of 23:00, 23 September 2026 by Josh (talk | contribs) (Verification drive: correct power spec (Apple gives 132 W max continuous / 201 W peak input / 86 W DC out, not 210 W); SCSI is DB-25 not HDI-30; video out is HDI-45 not DB-15; serial is mini DIN-9; VRAM is None (DRAM-based video), not 640 KB; full audio spec; RAM max 72 MB per Apple; cited to the 6100/WS 6150 Service Source)
This page contains detailed technical specifications for the Power Macintosh 6100 series.
Model Configurations
Power Macintosh 6100 Model Configurations
Model Order Number Processor Bus Speed L2 Cache RAM Hard Drive CD-ROM Price
6100/60 M2197LL/A 60 MHz 30 MHz Optional 256k 8 MB 160 MB None $1,820
6100/60 M1878LL/A 60 MHz 30 MHz Optional 256k 8 MB 160 MB 2X $2,000
6100/60 M3078LL/A 60 MHz 30 MHz Optional 256k 16 MB 250 MB 2X $2,350
6100/66 M3631LL/A 66 MHz 33 MHz 256k 8 MB 350 MB None $1,750
6100/66 M3632LL/A 66 MHz 33 MHz 256k 8 MB 350 MB 2X $1,950
6100/66 (PC) M3972LL/A 66 MHz 33 MHz 256k 8 MB 500 MB 2X $2,150
Model Number: M1596 | Gestalt ID: 75 (6100/60), 100 (6100/66)
Processor Specifications
CPU Specifications
Specification 6100/60 6100/66
Processor PowerPC 601 PowerPC 601
Clock Speed 60 MHz 66 MHz
Architecture 32-bit RISC 32-bit RISC
Data Path 64-bit 64-bit
FPU Integrated Integrated
System Bus 30 MHz 33 MHz
L1 Cache 32 KB 32 KB
L2 Cache Optional 256 KB 256 KB (standard)
Memory Specifications
RAM Specifications
Specification Value
RAM Type 72-pin SIMM
Minimum Speed 80 ns
RAM Slots 2
Onboard RAM 8 MB
Standard RAM 8โ€“16 MB (varies by model)
Maximum RAM 72 MB [1]
SIMM rule Must be fitted as a pair of the same size and speed; non-composite SIMMs only[1]
Apple's figure of 72 MB assumes the SIMM sizes on sale at the time. Larger non-composite 72-pin SIMMs are often reported to work, but Apple publishes no figure above 72 MB and no source has been found for a higher one, so none is given here.
ROM
ROM Specifications
Specification Value
ROM Type Macintosh ROM
ROM Size 4 MB
Video Specifications
Specification Value
Video Type Built-in DRAM-based video on the logic board[1]
Video RAM None fitted. Apple lists VRAM as "None" for every non-AV 6100 and 6150; the frame buffer is taken from main DRAM[1]
VRAM Upgradeable No (the optional Power Macintosh AV Card carries its own 2 MB of VRAM)[1]
Maximum Resolution (16-bit) 640ร—480
Maximum Resolution (8-bit) 832ร—624
Second Display Supported with NuBus video card (requires adapter)
Supported Display Modes
Resolution Color Depth
512ร—384 16-bit (thousands)
640ร—480 16-bit (thousands)
832ร—624 8-bit (256 colors)
Storage Specifications
Component Specification
Hard Drive Interface SCSI
Hard Drive Capacity 160, 250, 350, or 500 MB (varies by model)
Floppy Drive 1.44 MB 3.5" (manual eject)
CD-ROM 2X (optional or standard depending on model)
Audio Specifications
Specification Value
Audio Output 16-bit stereo out[1]
Audio Input 16-bit stereo in[1]
Sample Rates 48, 44.1, 24 and 22.05 kHz[1]
Line Level 1 V peak-to-peak in and out[1]
Signal-to-Noise Ratio 82 dB, with no audible discrete tones[1]
Bandwidth 20 Hz โ€“ 20 kHz (ยฑ2 dB) at a 44.1 kHz sample rate[1]
THD+N Less than 0.05%, measured 20 Hz โ€“ 20 kHz with a 1 V RMS sine input[1]
Expansion and Ports
Expansion Slots
Slot Type Quantity Notes
601 PDS 1 Processor Direct Slot
NuBus 1 (via adapter) Requires M1402LL/A PDS-to-NuBus adapter
Drive Bay 1 Front-facing 5.25" (if no CD-ROM installed)
Ports
Port Quantity Notes
Serial 2 RS-232/RS-422 LocalTalk/GeoPort ports on mini DIN-9 connectors, backward compatible with mini DIN-8[1]
ADB 1 Apple Desktop Bus. Maximum draw 500 mA; maximum of three devices in total[1]
SCSI 1 External DB-25 connector. Supports six external devices, or five when a CD-ROM drive is fitted[1]
Video Out 1 HDI-45 DRAM-based video port. An HDI-45 to DB-15 adapter was supplied in the box[1]
Audio In 1 Stereo 3.5mm jack
Audio Out 1 Stereo 3.5mm jack
Ethernet 1 AAUI-15
Physical Specifications
Physical Dimensions
Specification Imperial Metric
Height 3.4 inches 8.6 cm
Width 16.3 inches 41.4 cm
Depth 15.6 inches 39.6 cm
Weight 14.0 lbs 6.4 kg
Power Specifications
Power Requirements
Specification Value
A/C line input voltage 100โ€“240 VAC, RMS single phase, automatically configured[1]
Input line frequency 50โ€“60 Hz[1]
Input power 132 W maximum continuous, 201 W peak (not including monitor power)[1]
Power supply DC output 86 W continuous[1]
Apple publishes no per-rail voltages, no rail tolerances and no power-supply adjustment procedure for this machine; the Service Source electrical specification stops at the four figures above.[1] See Power Macintosh 6100 General Maintenance for what can usefully be measured instead.
Operating System Support
Software Compatibility
Specification Value
Original OS System 7.1.2
Maximum OS Mac OS 9.1
Supported Range System 7.1.2โ€“7.5.1, 7.5.3โ€“9.1
Note Mac OS 7.5.2 not supported
Timeline
Product Timeline
Event Date
6100/60 Introduction March 14, 1994
6100/60 Discontinued January 3, 1995
6100/66 Introduction January 3, 1995
6100/66 Discontinued October 14, 1995
DOS Compatible Card Specifications
PC Compatibility Card (Optional)
Specification Value
Processor Intel 486DX2
Clock Speed 66 MHz
Maximum RAM 32 MB (dedicated)
Interface NuBus
Operating System MS-DOS, Windows 3.1
  1. โ†‘ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 1.20 Apple Computer, Inc., Power Macintosh 6100/WS 6150 Service Source, Specifications chapter (Processor, Memory, I/O Interfaces, Electrical, Physical) and Additional Procedures → Battery Verification. Hosted on this wiki as File:Powermac 6100 series.pdf.
