Macintosh 512Ke
Revision as of 12:51, 23 April 2025 by Josh (talk | contribs)
Macintosh 512Ke
TypePersonal Computer
ReleasedApril 14, 1986
DiscontinuedSeptember 1, 1987
Intro priceUS$1,999
CPUMotorola 68000 @ 7.83 MHz
Memory512 KB RAM (built‑in)
Storage800 KB 3.5″ floppy drive
Display9″ monochrome CRT (512×342)
SoundMonaural, 8‑bit
Dimensions13.6″ H × 9.6″ W × 10.9″ D
Weight16.5 lbs (7.5 kg)
OS / FirmwareSystem 1.0 – System 6.0.8
PredecessorMacintosh 512K
SuccessorMacintosh SE
CodenameM0001E
Model no.M0001E
The Macintosh 512Ke (often called the 512K “enhanced”) was introduced by Apple on April 14, 1986, as a cost‑effective alternative to the Macintosh Plus. It combined the 512 KB RAM and compact case of the Macintosh 512K with the 800 KB floppy drive and 128 KB ROM of the Macintosh Plus, unlocking support for newer System software and utilities.
Features
  • 800 KB Floppy Drive – Double‑sided drive offering twice the native disk capacity of earlier models.
  • 128 KB ROM from Mac Plus – Built‑in SCSI Manager support (no physical SCSI port), enabling compatibility with SCSI‑based hard drives via third‑party adapters.
  • Educational Edition – Late‑life rebadged as the “Macintosh ED” for schools, with identical hardware but educational packaging.
  • Limited Expansion – No internal slots; RAM upgrades and SCSI adapters were supplied by third parties, often boosting memory to 2 MB+.
System Software
Shipped with System 3.2; later officially supported up to System 6.0.8. In practice, many users ran System 5.x for a balance of features and available memory.
Upgrade Paths
Official Apple upgrade kit (US $299) for the 512Ke included:
  1. 800 KB floppy drive
  2. 128 KB ROM chips
  3. Macintosh Plus System Tools disk and installation guide
Third‑party kits offered SCSI port cards and RAM expansions (up to 2 MB or more), addressing the machine’s expansion limitations.
Maintenance
The 512Ke shares its PCB layout and servicing procedures with the Macintosh 128K and Macintosh 512K. For cleaning, capacitor replacement guides, and general servicing, see Macintosh 128K/512K General Maintenance.
Sub-system Specification (Macintosh 512Ke, 1986)
CPU Motorola 68000 @ 7.8336 MHz (15.667 MHz ÷ 2)
Bus width 16-bit data • 24-bit address (16 MB logical)
ROM **128 KB “Plus-class”** ROM
  • (Twice the 64 KB of the 512 K / 128 K; adds HFS, SCSI Manager, 800 K disk routines)*
RAM 512 KB DRAM (16 × 256-Kbit 150 ns) – *soldered*
Video 512 × 342 monochrome frame-buffer (22.1 KB) DMA-shared with RAM
Sound 8-bit PWM DAC via VIA timers • 22 kHz RC filter → LM380 amp
Disk I/O **Sony OA-D34V-22 800 KB** auto-inject 3.5″ drive • IWM controller
Ports DE-9 mouse/KB • DB-19 ext. floppy • RS-422 serial × 2 (230 kbps) • 3.5 mm audio-out
Memory Map (Physical)
Macintosh 512Ke Address Space
Range Size Purpose
$000000 – $07FFFF 512 KB **DRAM** (program, heap, frame-buffer)
$400000 – $41FFFF 128 KB **ROM** (v3.4 “Plus” Toolbox)
$480000 – $4BFFFF 256 KB **I/O** (VIA 1/2, SCC, IWM, VBL PAL)
$500000 – $5FFFFF 1 MB **Reserved / not decoded**
$600000 – $FFFFFF Mirrors / ghost ranges
  • Frame-buffer note:* 22 016-byte display buffer lives at **$07B000 – $07FFFF**.
ROM Layout (v3.4 128 KB set)
Offset Size Module
$400000 8 KB 68000 vectors + Mini-Shell
$402000 20 KB QuickDraw 1.1 (mono, patched)
$407000 52 KB Toolbox, SANE, Mouse & Keyboard drivers
$414000 24 KB Sony 800 KB IWM driver, HFS routines
$41A000 24 KB SCSI Manager, Disk Cache, I/O traps
800 KB Floppy Format
  • 80 tracks • **double-sided** • variable-speed GCR
  • 12 → 8 sectors/track (outer→inner) • 512-byte sectors
  • 800 KB formatted • still driven by IWM (no SWIM yet) with ROM-based speed tables
Key I/O ICs
  • **6522 VIA × 2** — timers, sound PWM, keyboard/mouse handshake
  • **8530 SCC** — dual RS-422 serial
  • **IWM** — Integrated Woz Machine floppy controller
  • **MC6883 PAL** — VBL interrupt & DRAM arbitration
Sound Path
68000 → VIA Port A (8-bit sample) • VIA Timer 1 toggles Port B @ 22.254 kHz → PWM → RC filter → LM380 amp → speaker/headphones.
ROM Enhancements vs. 512 K
  • **HFS file system** support (400 KB disks can be HFS-formatted).
  • **SCSI Manager** present (unused until external SCSI upgrade boards).
  • **“Backwards-compatible”**: still boots MFS and runs 128 K/512 K apps.
Hardware Easter Egg
Hold **⌘ + Option + ⇧ + Clear** at power-on for the hidden bass “startup” chime—retained from earlier ROMs.
