Macintosh Classic II
Revision as of 18:18, 23 September 2026 by Josh (talk | contribs) (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, V8 Lite/MEMCjr chipset claims, 53C96 and Egret attributions, ROM module table, MacBench comparison table, Paris codename/Eiffel silkscreen, JP3 debug jumper and the cold-start easter egg; SIMM speed 80ns -> 120ns or faster, single SIMM claim corrected to a pair, dimensions/weight/model number corrected; region-specific analogue board warning added; release_date parameter fixed; refs and reflist)
TypePersonal computer
Released21 October 1991
Discontinued13 September 1993
Intro priceUS$1,899
CPUMotorola 68030 @ 16 MHz, 16-bit external data bus
Memory2 MB soldered, expandable to 10 MB (two 30-pin SIMMs, 120 ns or faster)
StorageInternal 1.4 MB floppy drive; internal 40 or 80 MB SCSI hard disk
Display9-inch monochrome CRT, 512 × 342 pixels
SoundMonophonic, 8-bit D/A conversion, 22 kHz sampling; built-in microphone
ROM512 KB
Ports / interface1 × ADB; DB-19 external floppy; DB-25 SCSI; 2 × RS-422 serial; sound in and out
ExpansionNone
Power100–120 V AC, 47–63 Hz, 100 W maximum
Dimensions13.2 in H × 9.7 in W × 11.2 in D (33.6 × 24.6 × 28.5 cm)
Weight16–17.1 lb (7.3–7.8 kg) without a hard disk
OS / FirmwareSystem 6.0.8L – System 7.6.1
PredecessorMacintosh Classic
SuccessorMacintosh Color Classic
CodenameApollo, Montana
Model no.M4150
The Macintosh Classic II was introduced on 21 October 1991 and is the last 9-inch monochrome compact Macintosh. Apple also sold it as the Performa 200 from September 1992, and services all three names from one manual.[1][2]
It replaced the Macintosh SE/30 and is slower than it, despite using the same 68030 at the same clock: the Classic II's logic board is derived from the LC and carries a 16-bit external data bus, and it has no expansion slot.[1][2]
Apple's own specification pages.[1]
Item Specification
CPU Motorola 68030, 16 MHz, 32-bit internal data bus, 256-byte instruction and data caches
RAM 2 MB, expandable to 10 MB (120 ns or faster SIMMs)
ROM 512 KB
PRAM 256 bytes
SIMM sockets Two, 30-pin, on the logic board
Floppy Internal 1.4 MB; optional external 800 KB or 1.4 MB
Hard disk Internal 40 MB or 80 MB; external SCSI supported
Microphone Electret, omnidirectional; output 4 mV peak to peak at normal volume
ADB One port, mini-DIN-4
Serial Two RS-422 ports, mini-DIN-8
Sound Monophonic, 8-bit D/A conversion, 22 kHz sampling; can drive stereo headphones through the sound jack
Video 9-inch diagonal, 512 × 342 bit-mapped monochrome
Line voltage 100–120 V AC
Frequency 47–63 Hz, single phase
Maximum power 100 W
Dimensions 13.2 × 9.7 × 11.2 in (33.6 × 24.6 × 28.5 cm)
Weight 16–17.1 lb (7.3–7.8 kg), excluding an internal hard disk
Memory
2 MB soldered plus two 30-pin SIMM sockets on the logic board, filled as an identical pair: 4 MB with a pair of 1 MB modules, 10 MB with a pair of 4 MB modules. 120 ns or faster, eight-chip, non-parity.[1] Full procedure: Macintosh Classic II Memory Upgrade Guide.
Apple's Sad Mac chart for this machine says to replace the pair of SIMMs before replacing the logic board.[1]
Upgrade from a Classic
Apple sold a Classic II upgrade kit for the Macintosh Classic: a Classic II logic board, a Classic II rear cover, a microphone and an accessory kit. The instruction that went with it was to record the original serial number onto the new rear housing.[1]
Service manual and schematics
Apple service manual
All the Apple service manuals are on the Apple Service Source page.
Logic board and analogue board
Macintosh Classic II PCB images
Logic board Analogue board
Macintosh Classic II logic board
File:Macintosh Classic II Schematic.pdf
Classic-family analogue board
File:Classic Analog Board Schematic.pdf
Maintenance, capacitors and troubleshooting
The Classic II logic board carries surface-mount electrolytic capacitors and suffers the usual leakage and trace corrosion; recapping is the first job on any machine that has sat unused. Values and positions are on the Macintosh Classic II Capacitor Replacement Guide.
The Classic II analogue board exists in 110 V and 220–240 V versions, and their reservoir capacitors are not the same part. Work from the table for the board in front of you — a capacitor rated for the 110 V board on a 240 V board sits on a bus that rectifies to roughly 340 V.
Apple publishes no rail tolerance and no power-supply adjustment for this machine; its Adjustments chapter is video and yoke work only.[1] The Dead Mac Scrolls does not cover the Classic II either, so board references quoted for it from that book have been transplanted from another model.[3]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Apple Computer, Macintosh Classic/Classic II/Performa 200 Service Source — Specifications, Troubleshooting, Upgrades, Adjustments and Additional Procedures chapters. Hosted on this wiki: File:Classic ii.performa 200.pdf.
  2. ↑ 2.0 2.1 Low End Mac, Mac Classic II tech specs (secondary source, used for dates, prices, codenames and the motherboard lineage).
  3. ↑ Larry Pina, The Dead Mac Scrolls, Peachpit Press, 1992, introduction: the Classic and Classic II "aren't covered at all in this edition". Hosted on this wiki: File:The Dead Mac Scrolls 1992.pdf.
