Macintosh Centris 610
| Centris 610 with colour display, in Apple's 1993 product photograph | |
| Released | 10 February 1993 |
| Discontinued | 21 October 1993 |
| Intro price | US$1,860 and US$2,560 (two configurations) |
| CPU | Motorola MC68LC040 @ 20 MHz (no FPU) |
| Memory | 4 MB on the logic board; two 72-pin SIMM slots; 68 MB maximum |
| Storage | 1.4 MB SuperDrive; 80โ500 MB SCSI hard drive; optional internal CD-ROM |
| Display | External monitor via DB-15; 512 KB VRAM, 1 MB maximum |
| Sound | 8-bit stereo output, mono input |
| ROM | 1 MB |
| Expansion | One slot for a 7-inch NuBus card or a PDS card, via adapter |
| Power | 100โ240 V AC |
| Dimensions | 85 ร 415 ร 397 mm (3.4 ร 16.3 ร 15.6 in) H ร W ร D |
| Weight | 6.4 kg (14.0 lb) |
| OS / Firmware | System 7.1 โ Mac OS 8.1 |
| Successor | Macintosh Quadra 610 |
| Model no. | M1444 |
The Macintosh Centris 610 is a low-profile desktop Macintosh with a 20 MHz Motorola MC68LC040. Apple introduced it on 10 February 1993 and discontinued it on 21 October 1993.[1] Apple's developer note describes the Centris 610, Macintosh Centris 650 and Macintosh Quadra 800 as three models bringing the 68040 in at lower prices than the Quadra 700 and 950.[2] It was replaced by the 25 MHz Macintosh Quadra 610 in the same case.[3][4]
Configurations
[edit | edit source]EveryMac lists three configurations: M1345LL/A with 4 MB of RAM, an 80 MB hard drive and no CD-ROM; M1397LL/A with 8 MB and a 230 MB drive; and M1398LL/A with 8 MB, a 230 MB drive and a double-speed CD-ROM. It gives the US prices as $1,860 and $2,560.[5] Ethernet was optional on the Centris 610.[4] The Workgroup Server 60 uses the same case with a 25 MHz 68040, 8 MB of RAM, a 230 or 500 MB drive and Ethernet as standard.[4]
[edit | edit source]Processor and memory
[edit | edit source]The MC68LC040 has an integrated MMU but no floating-point unit. The Service Source states that Apple does not provide an FPU upgrade for the Centris 610.[4] The developer note adds that the MC68LC040 sits in a socket and can be replaced with a full MC68040.[6] Apple's CPU replacement procedure uses a PGA chip removal tool and warns that pressing down on the tool's handle can damage components on the board.[7]
The logic board carries 4 MB of RAM. The two 72-pin SIMM slots take 80 ns or faster SIMMs of 4, 8, 16 or 32 MB, for a maximum of 68 MB.[1][8] The ROM is 1 MB and the PRAM holds 256 bytes, backed by a lithium battery.[4]
Video
[edit | edit source]Built-in video drives an external monitor from a DB-15 port. The logic board has 512 KB of VRAM; two 256 KB VRAM SIMMs raise it to 1 MB.[1] VGA monitors are supported at 640 ร 480 only and SVGA at 800 ร 600 only, with an adapter cable.[4]
| Resolution | 512 KB VRAM | 1 MB VRAM |
| 512 ร 384 | 16-bit | 16-bit |
| 640 ร 480 | 8-bit | 16-bit |
| 800 ร 600 | 8-bit | 16-bit |
| 832 ร 624 | 8-bit | 16-bit |
| 1024 ร 768 | 4-bit | 8-bit |
| 1152 ร 870 | 4-bit | 8-bit |
[edit | edit source]The Centris 610 has an internal 1.4 MB Apple SuperDrive and room for two internal SCSI devices: one 3.5-inch hard drive and one 5.25-inch device such as a CD-ROM drive.[9] The external DB-25 SCSI port supports up to six external devices.[4] The drive at the end of the internal SCSI cable must carry terminators and other internal devices must not; the logic board terminates the external end of the bus automatically when nothing is plugged in.[10]
Ports and expansion
[edit | edit source]Two ADB ports (500 mA maximum for all ADB devices), two mini DIN-8 serial ports, DB-25 SCSI, DB-15 video, stereo sound out and mono sound in, and on Ethernet-equipped models an AAUI-15 port.[4][1] The power button is on the front panel; the programmer's NMI and reset buttons and an unswitched AC outlet are on the back.[9]
The single expansion slot takes one card through an adapter: either a processor-direct slot (PDS) card or a NuBus card no more than 7 inches long.[9] The NuBus adapter was Apple part M1402LL/A.[5] A card may draw 10 W in total, split as follows:[11]
| Supply | Budget 1 | Budget 2 |
| +12 V | 2.1 W | 0.0 W |
| โ12 V | 1.8 W | 0.0 W |
| +5 V | 6.1 W | 10.0 W |
Power
[edit | edit source]Line voltage is 100โ240 V AC.[4] Apple's documents give two different power figures. The Service Source lists 112 W, not including the monitor.[4] The developer note says the Centris 610 power supply "provides 86 W total", and Apple's technical specifications page gives 86 W maximum, 1.7 A, at 47โ63 Hz.[12][1] After the logic board and the expansion card, 1.5 A at +5 V and 1.5 A at +12 V remain for internal drives.[12]
The clock and PRAM are backed by a 3.6 V lithium battery.[1] Apple's battery check: measure across the cell with the meter on the 10 V DC range, and replace the battery if it reads below 3.2 V. The holder cover is released by prising the latch at one end with a small flat-blade screwdriver.[13] Apple warns that the lithium battery can explode if mishandled.[13]
Upgrades
[edit | edit source]The Service Source documents a Centris 660AV logic board upgrade kit for the Centris 610 (logic board, product labels and I/O panel), and upgrades to the Power Macintosh 6100/60 or 6100/60AV. A Power Macintosh card for the PDS converts the machine to PowerPC.[14]
Service parts
[edit | edit source]Selected part numbers from Apple's exploded view, which covers the Centris 610, Quadra 610 and Workgroup Server 60. The drawing does not say which logic board number belongs to which model.[15]
| Part | Apple part number |
| Logic board | 661-0042 (no FPU), 661-0043 (FPU), 661-1681, 661-1682 (with Ethernet) |
| Power supply | 661-1688 |
| PDS adapter or NuBus adapter | 661-1718 |
| Floppy drive | 661-0121, 661-0474 |
| SCSI cable | 922-0804 |
| Speaker | 922-0353 |
| On/off actuator | 922-0357 |
Maintenance and repair
[edit | edit source]- Macintosh Centris 610 General Maintenance
- Macintosh Centris 610 Capacitor Replacement Guide
- Macintosh Centris 610 Troubleshooting
The Service Source's symptom charts cover video, floppy drive, hard drive, CD-ROM drive and peripherals. It has no error-chord table.[16]
[edit | edit source]- Macintosh Quadra 610/ Centris 610/WS 60 Service Source: Apple's module-level service manual (specifications, symptom charts, take-apart, upgrades, battery and CPU procedures, exploded view). It prints the depth as 4.2 in (107 mm), a misprint for the 397 mm given in the developer note.[4][17]
- Macintosh Centris 610 Centris 650 and Quadra 800 Developer Note: Apple's design description, with the power budgets, SCSI termination and expansion-slot details used above.
[edit | edit source]- โ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Macintosh Centris 610: Technical Specifications, Appleโlink(accessed 2026-09-30)
- โ Apple Computer, Developer Note: Macintosh Centris 610, Macintosh Centris 650, and Macintosh Quadra 800 Computers (1993), Preface, p. ix (PDF p. 9). Hosted as File:Macintosh Centris 610 Centris 650 and Quadra 800 Developer Note.pdf; see Macintosh Centris 610 Centris 650 and Quadra 800 Developer Note.
- โ Centris 610, Low End Macโlink(accessed 2026-09-30) Replaced by the Quadra 610 on 21 October 1993; highest Mac OS without a PowerPC upgrade is 8.1.
- โ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 4.10 Apple Computer, Macintosh Quadra 610/Centris 610/WS 60 Service Source, Specifications, pp. 1-13 (PDF pp. 5-17). Hosted as File:Quadra.centris_610.ws_60.pdf; see Macintosh Quadra 610/ Centris 610/WS 60 Service Source.
- โ 5.0 5.1 Apple Macintosh Centris 610 Specs, EveryMac.comโlink(accessed 2026-09-30) Order numbers, model number M1444, Gestalt ID 52, prices, VRAM SIMMs, NuBus adapter M1402LL/A.
- โ Developer Note: Centris 610, Centris 650, Quadra 800, Table 1-1, p. 3 (PDF p. 15).
- โ Quadra 610/Centris 610/WS 60 Service Source, Additional Procedures, CPU Replacement, pp. 6-9 (PDF pp. 98-101).
- โ Developer Note: Centris 610, Centris 650, Quadra 800, "RAM", p. 21 (PDF p. 33).
- โ 9.0 9.1 9.2 Developer Note: Centris 610, Centris 650, Quadra 800, "The Macintosh Centris 610 Design", p. 4 (PDF p. 16).
- โ Developer Note: Centris 610, Centris 650, Quadra 800, "SCSI Bus and Termination", pp. 18-19 (PDF pp. 30-31).
- โ 11.0 11.1 Developer Note: Centris 610, Centris 650, Quadra 800, Table 3-2, p. 32 (PDF p. 44).
- โ 12.0 12.1 Developer Note: Centris 610, Centris 650, Quadra 800, "Power Supplies", p. 9 (PDF p. 21).
- โ 13.0 13.1 Quadra 610/Centris 610/WS 60 Service Source, Additional Procedures, Battery Verification and Battery Replacement, pp. 1-5 (PDF pp. 93-97).
- โ Quadra 610/Centris 610/WS 60 Service Source, Upgrades, pp. 13-27 (PDF pp. 77-91).
- โ 15.0 15.1 Quadra 610/Centris 610/WS 60 Service Source, Exploded View (PDF p. 103).
- โ Quadra 610/Centris 610/WS 60 Service Source, Troubleshooting, pp. 1-11 (PDF pp. 19-29).
- โ Developer Note: Centris 610, Centris 650, Quadra 800, Table 1-2, p. 4 (PDF p. 16).
