Macintosh LC 575
Revision as of 00:47, 23 September 2026 by Josh (talk | contribs) (Verified against Apple's LC 520/550/575 Service Source (hosted) and EveryMac. Corrected: dimensions 45.5x34.4x42.0cm not 41.9x33.5x41.3; weight 18.4kg not 17.4; viewable 13in not 12.4; grille pitch 0.26mm not 0.28; max power 120W (the 150W was invented); operating 10-40C not 10-35; storage -40 to 65C not -40 to 47; humidity 20-95% not 20-80; model M1640 not M1347. Removed the '66 MHz bus', the 16-bit/44.1kHz sound claim, the unsourced chip-function and Comm-card part tables, and four red link...)
Macintosh LC 575
Macintosh LC 575
TypeAll-in-one personal computer
Released2 February 1994
Discontinued3 April 1995
Intro priceUS$1,700
CPUMotorola 68LC040 @ 33 MHz
Memory4 MB on board, expandable to 36 MB
Storage160 MB or 320 MB SCSI hard drive; manual-insert 1.4 MB SuperDrive; optional 2x CD-ROM
Display14 in Trinitron CRT, 13 in viewable, 640 x 480
SoundStereo output, monaural input; 11/22 kHz record, 22 kHz playback
Dimensions45.5 cm H x 34.4 cm W x 42.0 cm D (17.9 x 13.5 x 16.5 in)
Weight18.4 kg (40.5 lb)
OS / FirmwareSystem 7.1 - Mac OS 8.1
PredecessorMacintosh LC 550
SuccessorMacintosh LC 580
CodenameOptimus
Model no.M1640
The Macintosh LC 575 is an all-in-one Macintosh introduced on 2 February 1994 and discontinued on 3 April 1995.[1] It is the 68LC040 member of Apple's LC 500 series: the same chassis and the same 14-inch Trinitron display as the LC 520 and LC 550, with a faster processor and one extra expansion slot.
Apple's identifying features for the LC 575, as against the LC 520 and LC 550, are precisely three: a 68LC040 processor, an additional communications slot, and a hook-and-loop-attached battery.[2] The LC 550 and LC 575 also share the newer manual-insert SuperDrive, a revised chassis harness with no floppy drive adapter, and the caddyless CD 300+ CD-ROM drive.[2]
On the 66 MHz figure. The LC 575 is sometimes listed as a 66 MHz machine. Apple's own specification gives 33 MHz; the 66 MHz figure is the oscillator feeding the processor, which is not clock-doubled.[2][1]
Model variants
The LC 575 was sold to education. The consumer equivalents are the Performa 575, 577 and 578. Apple's own service documentation for this chassis family covers the LC 520, LC 550 and LC 575 together; the Performa variants are the same machines with different bundles.[2]
Configurations quoted by Apple's Service Source are a 160 MB or 320 MB SCSI hard drive, with the CD-ROM drive optional — an education configuration was sold without one.[2][1]
General maintenance
The LC 575 is an all-in-one: mains-powered analogue board, CRT and logic board in one case. Before doing anything inside it, read CRT Discharge Procedure. The anode holds a charge after the machine is switched off and unplugged, and the analogue board carries mains voltage on its primary side. Both are live at the same time when the case is open.
Routine care is the same as any beige Macintosh of the period: keep the vents clear, do not run it in a sealed cabinet, check the PRAM battery every few years and take it out before storage, and clean the front-panel contrast and volume buttons rather than forcing them. For yellowed plastics see Retrobrite; for battery and electrolyte damage see Battery Explosion, Capacitor or Corrosion Damage.
Logic board and service parts
The logic board is 820-0464-B (copyright 1993, 1994).[3] Apple's service part numbers for this family are:
Apple service parts, LC 520 / 550 / 575[2]
Part Number
Logic board, LC 575 661-0867
Logic board, LC 550 661-1830
Logic board, LC 520 661-0812
Analogue board (all three models) 661-0192
CRT 661-1666; 661-1667 (Australia); 661-1668 (Europe)
Floppy drive, manual insert 661-0121
CD-ROM drive 661-0222
Fan 922-1803
Internal microphone 922-1802
There is one analogue board part number for the whole family. Apple specifies the supply as universal, 100–240 VAC at 47–63 Hz, so unlike some machines of this era there is no separate 115 V and 230 V board to confuse when ordering parts or reading capacitor lists.[2] The CRT, by contrast, does have regional part numbers.
The board photograph below shows an AM53C96 SCSI controller and a Zilog Z8530 serial communications controller alongside four Apple ASICs marked 343S0129-C, 343S0138-A, 343S0164-b and 343S1091-A.[3] Apple's Service Source for this machine is module-level and does not describe what those ASICs do, so this wiki does not claim to either.
Apple service manual
Download the Macintosh LC 520/550/575 Service Source here: File:Lc 520.550.575.pdf. Further documentation is listed under Category:Apple Service Source.
Schematic
Download the Macintosh LC 575 schematic here: File:LC575.pdf
Capacitor replacement
The LC 575 logic board carries twelve surface-mount electrolytic capacitors:
  • 10 × 47 µF 16 V
  • 2 × 100 µF 6.3 V
These figures come from Recap-a-Mac's annotated photograph of an 820-0464-B board, which is also the location map — there is no second published list for this board to cross-check against, and Apple never published component-level capacitor data for any Macintosh of this era.[3] Read the value printed on each capacitor body before you lift it.
Macintosh LC 575 logic board 820-0464-B, with each electrolytic marked with its value, working voltage and positive terminal. Source: Recap-a-Mac.
Leaking SMD electrolytics on this generation show up first as lost or distorted sound, then as intermittent starting, and finally as corroded copper under the solder mask. The removal and fitting procedure is identical to the rest of the LC family and is documented on Macintosh LC Capacitor Replacement Guide; see also Capacitor Failure Symptoms.
The analogue board carries its own electrolytics, on a board that is mains-connected and shares a case with a charged CRT. No published per-designator list for the 661-0192 analogue board was found while this page was verified, so none is given here.
Display adjustments
Apple's Adjustments chapter gives figures you can check with a ruler and the Display Service Utility's test patterns.[2] All of the adjustment controls are in the high-voltage area of the analogue board; Apple specifies a short plastic hex-head tool and warns explicitly against metal alignment tools.
Apple geometry targets, LC 520/550/575[2]
Adjustment Target
Raster height (VH) 7 in ± 1/8 in (176 mm ± 2 mm) on an all-white screen
Raster width (HW) 9 1/4 in ± 1/8 in (235 mm ± 2 mm) on an all-white screen
Vertical / horizontal centre (VS, HS) Raster centred in the display area
Cutoff and white balance are set on the Gray Bars pattern after the monitor has been on for at least ten minutes, with contrast at maximum and the Screen control panel brightness at midrange. Cutoff is set first, with VG2 adjusted until the first bar is completely black and the second is barely visible; white balance follows on the red, green and blue background and drive controls. Apple requires the cutoff adjustment whenever the CRT or the analogue board is replaced.[2]
Technical details
System
Sub-system Specification
Processor Motorola 68LC040, 33 MHz, built-in MMU, no FPU. Socket for an optional coprocessor[2]
Processor upgrade Socketed; Apple's Macintosh Processor Upgrade fits a PowerPC 601 with a 256 K cache card and re-seats the customer's 68LC040 on the upgrade board[2]
ROM 1 MB[2]
RAM 4 MB on board, expandable to 36 MB through a single 72-pin SIMM socket[2]
PRAM 256 bytes of clock/calendar/parameter memory[2]
VRAM 512 K on board for 8-bit colour, expandable to 1 MB for 16-bit colour, across two VRAM SIMM slots[2]
Display 14 in Trinitron with high-contrast glass, 13 in viewable, 0.26 mm aperture grille pitch, 640 x 480 at 70 dpi[2]
Sound Stereo sound output port and front headphone jack; monaural sound input; records at 11 or 22 kHz, plays back at 22 kHz; two speakers; built-in electret omnidirectional microphone[2]
Storage Manual-insert 1.4 MB SuperDrive; 3.5 in internal SCSI hard drive of 80, 160, 250 or 320 MB; internal Apple CD 300+ CD-ROM drive[2]
Expansion One processor-direct slot taking 96-pin or 114-pin cards, plus a communications slot for 50-pin modem and Ethernet cards[2]
Gestalt ID 92[1]
SIMM speed: Apple's LC 520/550/575 volume specifies "100 ns or faster" for the DRAM SIMM.[2] Third-party references commonly quote 80 ns as the requirement.[1] Faster is always safe; the two figures do not agree and the discrepancy is noted here rather than resolved.
Memory configurations
The machine has 4 MB soldered and one SIMM socket, so the total is 4 MB plus whatever is in the socket, to a maximum of 36 MB.[2] Apple's standard configurations were 5 MB (a 1 MB SIMM) and 8 MB (a 4 MB SIMM).[1]
I/O ports
From Apple's I/O Interfaces specification[2]
Port Connector Notes
Serial x 2 Mini-DIN-8 RS-232 / RS-422
SCSI DB-25 Up to six external devices
Apple Desktop Bus Mini-DIN-4 Apple's specification for this family lists two ADB ports, a maximum of three ADB devices, and 500 mA maximum current draw (mouse 10 mA, keyboard 25 mA)
Sound output 3.5 mm Stereo; plus a stereo headphone jack on the front bezel
Sound input 3.5 mm Monaural
Communications slot
Apple describes the communications slot simply as internal expansion for 50-pin modem and Ethernet cards, and lists it as one of the three features that distinguish the LC 575 from the LC 520 and LC 550.[2] EveryMac records the LC 575 as the first LC-series model to carry one.[1] No verified list of compatible cards and their Apple part numbers was found while this page was checked, so none is given.
Electrical, physical and environmental
Apple specification[2]
Item Specification
Line voltage 100–240 VAC, universal power supply
Frequency 47–63 Hz, single phase
Maximum power 120 W
Dimensions 17.9 in (45.5 cm) H x 13.5 in (34.4 cm) W x 16.5 in (42.0 cm) D
Weight 40.5 lb (18.4 kg)
Operating temperature 50–104 °F (10–40 °C)
Storage temperature −40 to 149 °F (−40 to 65 °C)
Relative humidity 20–95 %, non-condensing
Altitude 0–10,000 ft operating
PRAM battery
Apple's specification for the LC 520/550/575 lists a long-life lithium battery, and Apple's service check is to measure it on the 10 V DC range and replace it if it reads below 3.0 V. On the LC 575 the battery is attached with hook-and-loop fastener rather than clipped into a holder, and Apple's take-apart sequence removes the I/O door, the logic board and then the battery.[2]
There is a source conflict here. EveryMac lists the LC 575's battery as a 4.5 V alkaline pack.[1] Apple's own manual for this machine says lithium and gives a 3.0 V replacement threshold, which does not fit a 4.5 V pack. Open the machine and look at what is actually fitted before ordering a replacement — and measure it while it is in there.
Whatever is fitted, a cell left in a stored machine is one of the two great destroyers of boards of this age; the other is the capacitors. See Battery Explosion, Capacitor or Corrosion Damage and Battery Refurbishment.
Software
Apple shipped the LC 575 with System 7.1. EveryMac records the supported range as System 7.1 to 7.5.1 and 7.5.3 to Mac OS 8.1.[1]
Known issues and quirks
  • SMD capacitor leakage. Assume an un-recapped board needs it. See above.
  • PRAM battery corrosion. As above.
  • Trinitron damper wires. Two faint horizontal lines are visible across the screen on any
 aperture-grille tube. They are part of the tube's construction, not a fault.
  • Heat. The logic board, the analogue board and a CRT share one sealed-ish case. Blocked vents are
 a real cause of intermittent faults on this chassis.
  • The "Mystic" upgrade. The LC 575 logic board is widely transplanted into a
 Macintosh Color Classic case by enthusiasts. Apple did something similar itself: its own PowerPC
 upgrade for the LC 520 and LC 550 consists of an LC 575 logic board, the PowerPC Upgrade Card, a new
 rear panel and a 575 product ID label.[2] This is the main reason bare LC 575 boards are scarce
 and complete machines are often found gutted.
  1. 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 EveryMac.com — Apple Macintosh LC 575 Specs. Third-party reference, used here for introduction and discontinuation dates, price, model and Gestalt identifiers, supported system software, and for the explanation of the 66 MHz figure sometimes quoted for this machine.
  2. 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 2.15 2.16 2.17 2.18 2.19 2.20 2.21 2.22 2.23 2.24 2.25 2.26 Apple Computer, Service Source: Macintosh LC 520, 550, 575 — Basics, Specifications, Troubleshooting, Take Apart, Adjustments, Additional Procedures and Exploded View chapters. Hosted on this wiki as File:Lc 520.550.575.pdf; see Macintosh LC 520/550/575 Service Source.
  3. 3.0 3.1 3.2 Recap-a-Mac — Macintosh LC575. Annotated photograph of the 820-0464-B logic board. Hosted on this wiki as File:Mac LC 575 Recap Guide.jpg. Secondary source.
