Macintosh Performa 575
| Macintosh Performa 575 | |
| Type | All-in-one Personal Computer |
| Released | February 2, 1994 |
| Discontinued | April 3, 1995 |
| Intro price | US$1,599 |
| CPU | Motorola 68LC040 @ 33 MHz |
| Memory | 5 MB (Apple's figure for the board is 4 MB on board, expandable to 36 MB through one 72-pin SIMM socket) |
| Storage | 250 MB SCSI hard drive; internal Apple CD 300+ CD-ROM drive; manual-inject 1.4 MB SuperDrive |
| Display | 14-inch diagonal Trinitron with a 13-inch viewable screen, 0.26 mm aperture grille pitch, 640 ร 480 at 70 dpi |
| Sound | Stereo 16-bit, 44.1 kHz |
| Power | 100โ240 V AC universal supply, 47โ63 Hz, 120 W maximum โ there is no voltage selector and no region-specific board |
| Dimensions | 17.9 in (45.5 cm) high ร 13.5 in (34.4 cm) wide ร 16.5 in (42.0 cm) deep, per Apple |
| Weight | 40.5 lb (18.4 kg), per Apple |
| OS / Firmware | System 7.1.1 โ Mac OS 8.1 |
| Predecessor | Performa 550 |
| Successor | Performa 580 |
| Codename | Optimus |
| Model no. | M1347 |
The Macintosh Performa 575 is an all-in-one personal computer released on February 2, 1994, as part of Apple's consumer-oriented Performa line. The Performa 575 is a rebrand of the LC 575 configured for retail sale, featuring a 33 MHz Motorola 68LC040 processor, built-in 14-inch Trinitron display, and bundled consumer software.[1]
The Performa 575 uses the same logic board and chassis as the Macintosh LC 575, differing only in configuration and bundled software:
- Processor: Motorola 68LC040 at 33 MHz with a built-in MMU. There is no FPU in the 68LC040, but the board has a socket for an optional math coprocessor.[2]
- RAM: Apple specifies 4 MB on board, expandable to 36 MB with 100 ns or faster SIMMs through one 72-pin DRAM SIMM connector. The 5 MB retail figure is that 4 MB plus the SIMM Apple shipped in it.[2]
- Storage: 250 MB SCSI hard drive. Apple built this family with 80, 160, 250 or 320 MB drives, and a manual-inject 1.4 MB SuperDrive.[2]
- Optical: internal Apple CD 300+ CD-ROM drive.[2]
- Communications Slot: 50-pin internal expansion for a modem or an Ethernet card — a feature of the LC 575 board that the LC 520 and LC 550 do not have.[2]
- Display: 14-inch diagonal Trinitron, 13-inch viewable, 0.26 mm aperture grille pitch, 640 ร 480 at 70 dpi. 512K of VRAM on board gives 256 colours; two VRAM SIMM slots expand it to 1 MB for 32,000 colours.[2]
Electrical
The supply is universal: 100–240 V AC, 47–63 Hz, 120 W maximum.[2] There is no voltage selector switch and no region-specific power board, so an imported machine needs only the right lead. That is worth knowing, because several Apple all-in-ones of this era do have region-specific boards where it matters a great deal.
Bundled Software
The Performa 575 shipped with System 7.1.1 (with System Enabler 065) and included:
- ClarisWorks 2.0
- Quicken 4.0
- Grolier's Encyclopedia
- Educational titles
Related Models
The Performa 575 shares identical hardware with:
- Macintosh LC 575 โ Education market version
- Performa 577 โ 320 MB hard drive
- Performa 578 โ 8 MB RAM, 320 MB hard drive
Maintenance, Troubleshooting and Recapping
The Performa 575 is the same machine as the Macintosh LC 575 — same logic board, same chassis, same power supply, same display. All of the service material lives on the LC 575 and LC family pages:
- Macintosh LC 575 — the machine page, including the board's capacitor guidance and the service documentation.
- Macintosh LC Capacitor Replacement Guide — surface-mount electrolytic replacement for this generation of LC logic board.
- Macintosh LC 520/550/575 Service Source — Apple's own service manual, hosted here.[2]
- CRT Discharge Procedure — read this before opening an all-in-one.
- Battery Explosion, Capacitor or Corrosion Damage — the PRAM battery in this family leaks and the damage is the reason many of these boards are dead.
The links this page used to carry — to "Macintosh LC 575 General Maintenance", "Macintosh LC 575 Capacitor Replacement Guide" and "Macintosh LC 575 Troubleshooting" — pointed at pages that do not exist on this wiki, and so did the three Performa 575 redirects that fed them. They have been replaced with the pages that do.
Retrobrite
The Performa 575's beige plastics yellow from UV exposure. Restoration techniques are detailed on the Retrobrite page.
For the rest of the technical detail, see Macintosh LC 575. Apple's own specifications are in the Service Source hosted here.[2]
Service Documentation
Apple's own service manual for this machine, hosted on this wiki as Macintosh LC 520/550/575 Service Source:
- โ Apple Macintosh Performa 575 Specs, EveryMac.comโlink(accessed 2026-02-10)
- โ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 Apple Computer, Macintosh LC 520, 550, 575 Service Source — hosted on this wiki as File:Lc 520.550.575.pdf. Specifications chapters: Processor (Motorola 68LC040 at 33 MHz with built-in MMU and a socket for an optional math coprocessor on the LC 575); Memory (4 MB of dynamic RAM on board, expandable to 36 MB with 100 ns or faster SIMMs through one 72-pin DRAM SIMM connector; 1 MB of ROM; 512K of VRAM on board expandable to 1 MB, with two VRAM SIMM slots on the LC 575); Disk Storage (manual-inject 1.4 MB SuperDrive, 80, 160, 250 or 320 MB SCSI hard drive, and the internal Apple CD 300+ CD-ROM drive on the LC 550 and LC 575); I/O Interfaces (two serial ports, one SCSI port, two ADB ports with a 500 mA maximum draw, the processor-direct slot, and the Communications Slot on the LC 575); Sound and Video (14-inch diagonal with a 13-inch viewable Trinitron screen, 0.26 mm aperture grille pitch, 640 by 480 at 70 dpi); Electrical (100–240 V AC universal supply, 47–63 Hz, 120 W maximum); and Physical (height 17.9 in / 45.5 cm, width 13.5 in / 34.4 cm, depth 16.5 in / 42.0 cm, weight 40.5 lb / 18.4 kg).
- Macintosh LC 575 โ Base model (education market)
- Macintosh Performa 577 โ 320 MB hard drive variant
- Macintosh Performa 578 โ 8 MB RAM variant
- Macintosh LC 580 โ Successor model
