Macintosh Performa 460
Revision as of 16:55, 30 September 2026 by Josh (talk | contribs) (Rewrite from Performa 400 Series SS, Apple tech specs 112332 and LC III Developer Note: floppy conflict (SS manual-insert vs auto) stated, VRAM rules, FPU socket, C22 fault; case-design claim now attributed to EveryMac; Performa 460 photo in place of LC III; remove self-referential notes)
Macintosh Performa 460. Photo: All About Apple museum, Wikimedia Commons, CC BY-SA 3.0
TypeDesktop personal computer
ReleasedOctober 18, 1993
DiscontinuedNovember 1, 1993 (EveryMac)
Intro priceUS$1,300 (EveryMac)
CPUMotorola 68030 at 33 MHz; PLCC socket for a 68882 FPU
Memory4 MB on board, one 72-pin SIMM socket, 36 MB maximum
Storage80 MB SCSI hard drive; 1.4 MB SuperDrive
DisplayExternal; 512 KB VRAM on board, 768 KB with a VRAM SIMM
Sound8-bit mono
ROM1 MB
Dimensions7.7 × 31.0 × 38.2 cm (3.0 × 12.2 × 15.0 in)
Weight4.0 kg (8.8 lb)
OS / FirmwareSystem 7.1P3 – Mac OS 7.6.1
Model no.M1254
The Macintosh Performa 460 is a desktop Macintosh sold by Apple through consumer retail shops. It is the Macintosh LC III+ under a Performa name: a 33 MHz version of the Macintosh LC III.[1][2] The Performa 466 and 467 are the same machine with a 160 MB hard drive and the Performa Display Plus.[2] Low End Mac records that the 460 replaced the Performa 450 in October 1993.[3] EveryMac describes a new case for the 460, with a curved front, a more rounded foot and finger indentations above and below the floppy slot; the dimensions Apple gives are unchanged.[1][2]
Apple gives the introduction date as October 18, 1993, with System 7.1P3 and System Enabler 308 as the original system software.[4] EveryMac gives a US price of US$1,300, discontinuation on November 1, 1993, order number M2156LL/A and model number M1254.[1]
Apple's figures
Item Figure
Processor Motorola 68030 at 33 MHz; 32-bit data bus; coprocessor socket
RAM 4 MB on board; one 72-pin SIMM socket for 1, 2, 4, 8, 16 or 32 MB SIMMs of 80 ns or faster; 36 MB maximum
ROM 1 MB
VRAM 512 KB on the board; one VRAM SIMM socket takes a 256K SIMM for 768 KB
Floppy drive Apple SuperDrive, 1.4 MB: manual-insert (Service Source), auto-inject (technical specifications)
Hard drive at introduction 80 MB SCSI
Bundled monitor Performa Display
Ports One ADB, two serial (printer and modem, mini DIN-8), SCSI DB-25, DB-15 video, sound in and out
Expansion One 114-pin processor-direct slot for 020/030 cards
Electrical 100–240 VAC, 47–63 Hz, automatically configured; 50 W maximum (technical specifications)
Size and weight 3.0 × 12.2 × 15.0 in (7.7 × 31.0 × 38.2 cm); 8.8 lb (4.0 kg)
Sources: Apple's technical specifications, the Performa 400 Series Service Source, pp. 3–15, and the Macintosh LC III Developer Note, p. 2.[4][2][5] The Service Source prints no maximum-power figure for the 460, 466 and 467.
The coprocessor socket is a PLCC socket for a 68882; no FPU is fitted as standard.[4][5] With the on-board 512 KB of VRAM the machine shows 256 colours at 640 × 480 and 832 × 624; with 768 KB it shows thousands. A 512K VRAM SIMM fits the socket, but only 256K of it is used.[4] The processor-direct slot has a power budget of 4 W.[5]
The PRAM battery is a 3.6 V lithium cell, Apple part 742-0011; Apple says to replace it below 3.0 V. The power supply is part 661-1733, shared with the whole LC family.[4][2]
Known faults
  • Leaking surface-mount electrolytic capacitors on the logic board and in the power supply. The board list is on Macintosh LC III+ Capacitor Replacement Guide.
  • C22 on the LC III logic board, the 47 µF capacitor on the −5 V rail, is printed and fitted the wrong way round at the factory. Doug Brown's article treats the Performa 460, 466 and 467 as the same design. Serial-port faults after a recap point there.[6]
  • A flat PRAM battery: Apple's charts for this family put "Check batteries" first for "No video" and in the no-power entries.[2]
See Macintosh Performa 460 Troubleshooting, which applies to all three models, and Macintosh LC III+ Troubleshooting.
Service documentation
Apple covers the Performa 460 in the Macintosh Performa 400 Series Service Source. The Macintosh LC III Developer Note describes the hardware.[2][5]
  1. ↑ 1.0 1.1 1.2 EveryMac, "Macintosh Performa 460 Specs".
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Apple Computer, Service Source: Macintosh Performa 400 Series (1995), File:Performa 400 series.pdf; see Macintosh Performa 400 Series Service Source. Page numbers are PDF pages.
  3. ↑ Low End Mac, "Apple's Performa Line, 1992 to 1997".
  4. ↑ 4.0 4.1 4.2 4.3 4.4 Apple, "Macintosh Performa 460: Technical Specifications".
  5. ↑ 5.0 5.1 5.2 5.3 Apple Computer, Macintosh LC III Developer Note (1993), p. 2, File:Macintosh LC III Developer Note.pdf; see Macintosh LC III Developer Note. The note describes the 25 MHz LC III.
  6. ↑ Doug Brown, "The capacitor that Apple soldered incorrectly at the factory", 26 November 2024.
