Macintosh Classic
Revision as of 18:18, 23 September 2026 by Josh (talk | contribs) (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, ROM SIMM module table, SWIM-II/53C80 detail, MacBench benchmark table, Seattle/LittleFish codenames and MacsBug easter egg, and the 512KB 32-bit-clean/HFS+ ROM claim; CPU 8MHz -> 7.8336MHz, ONE ADB port (not two), Apple dimensions and 100W; predecessor SE/30 -> SE; added the real Command-Option-X-O ROM disk; fixed red link to a nonexistent Troubleshooting page; release_date parameter fixed; re...)
Macintosh Classic
Macintosh Classic
TypePersonal computer
Released15 October 1990
Discontinued14 September 1992
Intro priceUS$999 (floppy only) โ€“ US$1,499 (40 MB hard disk, 2 MB RAM)
CPUMotorola 68000 @ 7.8336 MHz
Memory1 MB soldered, expandable to 4 MB with Apple's memory expansion board
StorageInternal 1.4 MB floppy drive; optional internal 40 MB SCSI hard disk
Display9-inch monochrome CRT, 512 ร— 342 pixels
SoundFour-voice, 8-bit D/A conversion, 22 kHz sampling
ROM512 KB
Ports / interface1 ร— ADB (mini-DIN-4); DB-19 external floppy; DB-25 SCSI; 2 ร— RS-422 serial (mini-DIN-8); headphone
Power100โ€“120 V AC, 47โ€“63 Hz, 100 W maximum
Dimensions13.2 in H ร— 9.7 in W ร— 11.2 in D (33.6 ร— 24.6 ร— 28.5 cm)
Weight16โ€“17.1 lb (7.3โ€“7.8 kg) without a hard disk
OS / FirmwareSystem 6.0.7 โ€“ System 7.5.5
PredecessorMacintosh SE
SuccessorMacintosh Classic II
CodenameXO, Civic
Model no.M0420
The Macintosh Classic, introduced on 15 October 1990, was the first Macintosh to sell for under US$1,000. It is a cost-reduced compact: the same 68000 at 7.8336 MHz as the Macintosh SE, a 1.4 MB floppy drive, an optional 40 MB hard disk, and โ€” unlike the SE โ€” no expansion slot and only one ADB port.[1][2]
Apple's own specification pages for this family.[1]
Item Specification
CPU Motorola 68000, 7.8336 MHz, 32-bit internal data bus, 256-byte instruction and data caches
RAM 1 MB, expandable to 4 MB (120 ns or faster SIMMs)
ROM 512 KB
PRAM 256 bytes
Expansion connector 44-pin connector for the optional memory expansion board, which itself carries two SIMM connectors
Floppy Internal 1.4 MB; optional external 800 KB or 1.4 MB
Hard disk Optional internal 40 MB; external SCSI supported
ADB One port, mini-DIN-4
Serial Two RS-422 ports, mini-DIN-8
Sound Four-voice, 8-bit D/A conversion, 22 kHz sampling. The Classic does not provide true two-channel output, although a stereo jack may be used
Video 9-inch diagonal, 512 ร— 342 bit-mapped monochrome
Line voltage 100โ€“120 V AC
Frequency 47โ€“63 Hz, single phase
Maximum power 100 W
Dimensions 13.2 ร— 9.7 ร— 11.2 in (33.6 ร— 24.6 ร— 28.5 cm)
Weight 16โ€“17.1 lb (7.3โ€“7.8 kg), excluding an internal hard disk
Memory
There are no SIMM sockets on the Classic's logic board. The 1 MB on board is soldered, and expansion happens on Apple's optional memory expansion board: 1 MB soldered plus a pair of 30-pin SIMM sockets and a configuration jumper, giving 2 MB, 2.5 MB or 4 MB.[1]
Two rules from Apple that cause most of the trouble:
  • the jumper must match what is fitted โ€” "SIMMs" or "No SIMMs";
  • on a 4 MB machine the modules must be eight-chip SIMMs. Apple states that 1 MB SIMMs with fewer than eight chips will not work in the Macintosh Classic.[1]
Full procedure: Macintosh Classic Memory Upgrade Guide.
The ROM disk
The Classic is the only Macintosh that can boot from its own ROM. Holding Command-Option-X-O at startup mounts a 357 KB read-only volume named "Boot Disk" containing System 6.0.3 and Finder 6.1.x โ€” a reference to the machine's XO codename. It is genuinely useful for diagnosis: a Classic that will not boot from a disk but does boot from ROM has a working logic board, ROM, RAM and video.[2][3]
Service manual and schematics
Apple service manual
All the Apple service manuals are on the Apple Service Source page.
Logic board and analogue board
Macintosh Classic PCB images
Logic board Analogue board
Macintosh Classic logic board
File:MacintoshClassic LogicBoard Schematic.pdf
Macintosh Classic analogue board
File:Classic Analog Board Schematic.pdf
Maintenance, capacitors and troubleshooting
Apple publishes no rail tolerance and no power-supply adjustment for this machine. Its Adjustments chapter is video and yoke work only โ€” light meter setup, cutoff, brightness and contrast, centring, size, focus.[1] Note also that The Dead Mac Scrolls, the standard component-level reference for the earlier compacts, explicitly does not cover the Classic.[4]
  1. โ†‘ 1.0 1.1 1.2 1.3 1.4 Apple Computer, Macintosh Classic/Classic II/Performa 200 Service Source โ€” Specifications, Troubleshooting, Upgrades, Adjustments and Additional Procedures chapters. Hosted on this wiki: File:Classic ii.performa 200.pdf.
  2. โ†‘ 2.0 2.1 Low End Mac, Mac Classic tech specs (secondary source, used for dates, prices, codenames and the ROM disk).
  3. โ†‘ The Macintosh Easter Egg List and Low End Mac both document the Command-Option-X-O ROM disk, its contents and its 357 KB size (secondary sources).
  4. โ†‘ Larry Pina, The Dead Mac Scrolls, Peachpit Press, 1992, introduction. Hosted on this wiki: File:The Dead Mac Scrolls 1992.pdf.
