Macintosh LC II Capacitor Replacement Guide
Revision as of 16:07, 30 September 2026 by Josh (talk | contribs) (Copyedit; attribute the no-FPU-socket cost reason to Recap-a-Mac; add Recap-a-Mac KEMET parts and audio-socket warning; Performa relationship stated as Apple's manual gives it; cite chapters by page)
Macintosh LC II logic board 820-0327 with the electrolytics marked (Recap-a-Mac)
The Macintosh LC II logic board, 820-0327-A, carries seventeen surface-mount electrolytic capacitors of 1991 vintage. They leak with age, and the electrolyte attacks the solder mask and the copper beneath it. The board is different from the original LC's, with a different capacitor complement. Apple's Performa 400 series manual gives the Performa 400, 405, 410 and 430 the LC II's processor, memory and expansion specifications, and Recap-a-Mac's guide covers the LC II and Performa 400 together.[1][2]
The tools, the removal and fitting procedure, the power supply lists and the battery are common to the LC family and are on Macintosh LC Capacitor Replacement Guide.
Signs of failure
The pattern is the same as the rest of the family: residue around the capacitor bases, then faults in sound, startup or video. The −5 V rail on these boards is needed only for the RS-422 serial ports, so a bad bulk capacitor on it shows up as serial port trouble.[3] See Macintosh LC Capacitor Replacement Guide and Capacitor Failure Symptoms.
Macintosh LC II logic board (820-0327-A)
Seventeen surface-mount electrolytic capacitors. The per-designator list is Console5's; its totals by value (ten 10 µF, five 47 µF, one 100 µF and one 1 µF) match Recap-a-Mac's photograph of the same board.[4][2]
Macintosh LC II logic board 820-0327-A, surface-mount electrolytics (Console5)
Designator Value Voltage
C11, C12, C14, C15, C16, C17, C18, C21, C97, C139 10 µF 16 V
C2, C3, C4, C13, C19 47 µF 16 V
C10 100 µF 6.3 V
C22 1 µF 50 V
The LC III has a reversed capacitor at C22. The LC II's C22 is a different part, a 1 µF 50 V capacitor in a different place, and nothing is wrong with it; Doug Brown found the −5 V bulk capacitor on the LC and LC II wired the correct way round.[4][3]
Macintosh LC II logic board 820-0327 with each electrolytic marked with its value, voltage and positive terminal. Source: Recap-a-Mac.
Recap-a-Mac lists KEMET tantalum replacements: T491B105K050AT (1 µF 50 V), T491D476K016AT (47 µF 16 V), T491D107K006AT (100 µF 6.3 V) and T491B106K016AT (10 µF 16 V). It also warns that the plastic audio sockets melt easily.[2]
Power supply, battery and procedure
These are the same as the rest of the family and are on Macintosh LC Capacitor Replacement Guide: power supply 661-1733 (100–240 V AC, six known makers' variants with different capacitor complements) and lithium battery 742-0011, which Apple says to replace below 3.0 V.[5][1]
Things that are not faults
  • No FPU socket. Apple lists a coprocessor socket for the LC III and not for the LC II.[5] Recap-a-Mac says the LC II board was designed so that an FPU could be fitted but Apple left the socket off to save cost.[2] Software that needs an FPU will not run.
  • A 10 MB RAM ceiling. The machine takes 12 MB but addresses 10 MB, which Apple documents.[5]
  • Mono sound. Apple's specification for the LC, LC II and LC III is a monophonic 8-bit sound generator feeding the same signal to both channels.[5]
  1. ↑ 1.0 1.1 Apple Computer, Macintosh Performa 400 Series Service Source, covering the Performa 400/405, 410, 430, 450, 460/466/467 and 475/476, File:Performa 400 series.pdf (see Macintosh Performa 400 Series Service Source), Specifications, PDF pp. 3-10.
  2. ↑ 2.0 2.1 2.2 2.3 Macintosh LC II (Performa 400), Recap-a-Mac—link(accessed 2026-09-30) Annotated photograph of logic board 820-0327 (c) 1991, legend 1 × 1 µF 50 V, 10 × 10 µF 16 V, 5 × 47 µF 16 V, 1 × 100 µF 6.3 V; KEMET replacements T491B105K050AT, T491D476K016AT, T491D107K006AT and T491B106K016AT; warning that the plastic audio sockets melt easily; note that Apple left the FPU socket off to save cost. Hosted here as File:Mac LC II Recap Guide.jpg. Secondary source.
  3. ↑ 3.0 3.1 Doug Brown, "The capacitor that Apple soldered incorrectly at the factory", 26 November 2024. C22 on the LC III board is reversed; the LC and LC II boards are wired correctly; the −5 V rail is only needed for the RS-422 serial ports.
  4. ↑ 4.0 4.1 Macintosh LC Series, Console5 TechWiki—link(accessed 2026-09-30) Section "LC II Logic Board: 820-0327-A". Secondary source.
  5. ↑ 5.0 5.1 5.2 5.3 Apple Computer, Macintosh LC Series/Quadra 605 Service Source, File:Quadra 605.lc series.pdf (see Macintosh LC Series/ Quadra 605 Service Source): Specifications, PDF pp. 6-17; symptom charts, PDF p. 36; Battery Verification, PDF p. 107; Exploded View, PDF p. 112.
