Macintosh Portable Troubleshooting
Macintosh Portable (Hannes Grobe, Wikimedia Commons, CC BY 3.0)
Fault-finding on both Macintosh Portable models, the original M5120 and the backlit M5126, starts from Apple's symptom charts in the Service Source, which work at module level. Restorers have since added component-level findings, given below with each symptom.[1] Apple's rule for the charts: try the cures in order, test after each, and put the original module back before moving to the next cure.[1]
Before you start
  • Fit a charged main battery or a proper substitute. The Portable does not work properly without one, and the hard disk will not spin up without it.[2][3] See Macintosh Portable Battery Replacement.
  • Use an adapter to Apple's specification, 7.5 V nominal. David Cook warns that a higher-current PowerBook adapter fits the socket and can kill the Portable.[3] Apple's adapter test: 7.53-7.54 V between the inside (positive) and outside of the plug on the 10 V DC range.[1]
  • On a bench supply, feed both +V pins of J17 together (6.3 V, 1 A limit is David Cook's setting). Powering only pin 3 leaves the hybrid module unregulated and can kill a line of chips.[3]
  • Recap the board and clean off all leakage before powering it for long; see Macintosh Portable Capacitor Replacement Guide.
  • The power manager holds the machine's state. Apple's first step for many faults is to reset it by pressing the reset and interrupt switches at the same time.[1]
Power
Symptom Probable cause Action
Blank screen, no response Flat battery; power manager hung; keyboard or its cable; logic board Apple's order: remove the shipping sheet between battery and contacts on a new machine; reset the power manager; connect the adapter and restart after three or four minutes; replace the main battery; check the keyboard connections, keyboard and keyboard cable; then the logic board[1]
No response to a key press, constant current draw on a bench supply Dead power manager (PMGR) David Cook measured 33 mA that did not change on a key press on a board with a dead PMGR, against about 10 mA asleep and 300 mA or more awake on a good one. Check that the reset and interrupt switches read under 5 Ω pressed and over 10 kΩ released. He later revived a board by transplanting the PMGR from a PowerBook 100, which uses the same part[3]
Control Panel settings change after the main battery is removed Cover not refitted, or backup battery flat Restore the settings; replace the 9 V backup battery[1]
Adapter connected, battery desk accessory does not show the charger Connection, battery, adapter, logic board Check the charger connection; then the battery, the adapter and the logic board[1]
Low-power warning soon after starting Discharged battery or heavy drain Connect the adapter; reduce use of the floppy and hard drives, modem and speaker[1]
Battery does not hold its charge even when not in use Old system software; battery; keyboard; harness; logic board Use System 6.0.5 or later; then replace the battery, keyboard, wire harness and logic board in that order[1]
"No reserve battery power" at startup, battery shown at 0 % Corroded via or track in the power circuit One M5126 had a via eaten away under a resistor array and over 6 V with heavy ripple on the 5 V rail; repairing the via fixed it[4]
Restarts by itself after every shut-down Leakage residue on the board One owner cured it by scrubbing two dirty areas with a toothbrush and 99 % isopropyl alcohol[3]
Sleeps after 15 minutes on AC with sleep disabled The ROM ignores "don't sleep" unless it detects the charger; a battery eliminator hides the charger Expected with a battery eliminator; see Macintosh Portable Battery Replacement[5]
Startup
Apple's startup flowcharts:[1]
  1. Reset the power manager and switch on with no startup disk, by pressing any key except Caps Lock.
  2. No startup tone and no video: keyboard, keyboard cable, then logic board. Video but no tone: speaker, then logic board. An abnormal tone: logic board.
  3. No grey pattern: check the display cable, then the display, the display cable and the logic board.
  4. No disk icon with a question mark: logic board. Then insert a System Tools disk; if the desktop does not appear and the drive makes no sound, keyboard, keyboard cable, logic board; if it does, a known-good disk, the drive and its cable.
  5. Finally check the trackball and button.
Apple's chart for error chords at startup is a single line: replace the logic board.[1] Restorers go further:
  • A failed SWIM floppy controller can stop the machine at a grey screen with a cursor but no happy Mac or flashing disk.[6] A SWIM can also fail actively: on one board it held data line D4 low, so the CPU read a wrong reset vector, took a bus error and restarted in a loop. Lifting D4 on the SWIM gave a chime, and a SWIM from a dead PowerBook 170 completed the repair. The Portable will not boot with the SWIM removed.[3]
  • Androda suggests that when the hybrid (M5120) or regulation circuit (M5126) fails, the 5 V rail can see the adapter's 7.5 V, which may be what kills SWIM chips.[6]
  • Sad Mac codes after the chime on an M5120 can come from sound power-up putting noise on the 5 V rail. David Cook and techknight both bypass the sound circuit's high-side load-switch MOSFET with a bodge wire so that sound power stays on, as Apple did on the backlit board.[3][7]
  • On a backlit board that will not chime, check that nobody has bridged the factory cut trace by the 74AC00 next to the A23 bodge wire; see Macintosh Portable (backlit).
Test points
The RAM, ROM and PDS slots bring out signals that can be watched with an oscilloscope or logic analyser. David Cook's guide: SYS_PWR* low means the machine is awake; SYS_RST* held low means it is halted or restarting; ROM_CS* low means the ROM is being read; BERR* low means a bus error. A healthy start reads the first eight bytes of ROM (stack pointer and reset vector) and then jumps to $0090002A. The ROM and RAM slots are numbered bottom to top on the board but top to bottom on the schematic.[3]
Video
Some pixels never come on Display Up to five such voids is acceptable; replace the display at six or more[1]
A pixel is always black Display Replace the display[1]
A row of pixels always black, or never black Display, display cable, logic board Replace in that order[1]
Display blurred, too dark or too light Viewing angle, light, contrast setting Adjust the angle and the contrast in the Control Panel; on the non-backlit model move it nearer the light; then the display and logic board[1]
Backlight will not adjust or does not light (M5126) Control panel version, inverter, display Use Portable CDEV 1.3; check the inverter connections; replace the inverter board, the display, the logic board[1]
Blank display, machine otherwise working Display cable, display Check the cable connection; replace the display, the cable, the logic board[1]
Screen suddenly goes blank Screen saving Press any key except Caps Lock[1]
The rear video port is not VGA. Do not plug a VGA cable straight into it; use a Portable video adapter.[3]
Floppy and hard disk
Internal floppy drive does not work Disk, drive, cable, logic board Replace in that order[1]
Disk ejects at boot, blinking X System disk, drive, cable, logic board Known-good system disk first[1]
Disk will not eject Stuck mechanism Shut down, hold the trackball or mouse button and switch on; or push a straightened paper clip into the hole beside the drive[1]
Internal hard disk does not work External SCSI device off; cable; driver Switch on external SCSI devices; check the cable; run HD SC Setup and reinitialise if the drive is seen; then the drive and logic board[1]
Machine crashes waking from sleep Disk driver too new Do not use HD SC Setup newer than 7.3.1 on a Portable[2]
Will not boot after an external SCSI device is connected Device off, termination, duplicate ID Switch the device on first; check termination and IDs. The Portable does not supply termination power[1][2]
The Conner CP-3045 drive has a proprietary connector, and owners report its seals and head bumpers turning to goo.[8][6] See Hard Drive Maintenance and Repair.
Keyboard, trackball, sound and modem
No response to any key Power manager, keyboard connection Reset the power manager (reset and interrupt switches together); check the keyboard connection; then the keyboard and logic board[1]
Cursor does not move with the trackball Power manager, cable, trackball Reset the power manager; check the cables; replace the trackball cable, the trackball, the logic board[1]
Cursor sticks or jumps Dirty rollers Clean the ball and rollers (see Macintosh Portable General Maintenance)[1]
Speaker silent Volume setting, speaker, connection Set the volume to 1 or above; check the speaker connection; replace the speaker, the logic board[1] One restored board had a corroded via above the positive pad of C9 that broke the left channel to the speaker[3]
Pop or tick every 10 seconds Apple's sound-power code writing to the power manager Install David Cook's Quiet Portable extension[3]
Crash when a sound plays (M5120) Noise on the 5 V rail from the sound power switch, or dirt on the board Bodge wire to keep sound power on, as above. One board was cured instead by ultrasonic cleaning and cleaning out the hybrid module's solder holes[3]
Garbage on the serial ports Old software Use Portable INIT 1.0 and System 6.0.5 or later[1]
Internal modem missing from the Portable control panel Card seating Reseat the modem card; replace it; replace the logic board[1]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 1.20 1.21 1.22 1.23 1.24 1.25 1.26 1.27 1.28 Apple Computer, Macintosh Portable Service Source, hosted here as File:Macintosh_portable.pdf (see Macintosh Portable Service Source). Troubleshooting: Symptom Charts, Power pp. 2-4, Video pp. 5-7, Floppy Drive pp. 8-9, Hard Drive p. 10, Peripherals pp. 11-15, Internal Modem pp. 16-17, Miscellaneous pp. 18-19, Startup Problems flowcharts 1 and 2 (PDF pp. 18-37); Adapter Verification (PDF pp. 136-137); Trackball Maintenance (PDF pp. 145-149).
  2. ↑ 2.0 2.1 2.2 Low End Mac, "Backlit Mac Portable" (retrieved 2026-10-02). Cautions: battery unusable below 5.4 V; hard drive will not spin up without a charged battery; never use HD SC Setup newer than 7.3.1; the Portable does not supply SCSI termination power. Secondary source.
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 3.11 TinkerDifferent forum thread "Fixing a Macintosh Portable - What worked for me", David Cook, techknight and others, January to August 2026. Community repair report covering battery dependence, adapters, J17 wiring, current draw, slot test points, SWIM failures and sound crashes. Secondary source.
  4. ↑ TinkerDifferent forum thread "Macintosh Portable M5126 - Battery problem - Good night :0)", Scouter3D and techknight, August 2026. Secondary source.
  5. ↑ TinkerDifferent forum thread "Portable SLEEPS even when it shouldn't? [SOLVED"], April 2024. SuperSVGA on charger detection. Secondary source.
  6. ↑ 6.0 6.1 6.2 TinkerDifferent forum thread "GOTCHAS when buying a Macintosh Portable?", July 2023. moldy and Androda on SWIM, hybrid and 9 V battery failures. Secondary source.
  7. ↑ TinkerDifferent forum thread "Mac Portable 5V Line and Troubleshooting", May 2026. David Cook: on the 5120, powering up sound for the chime introduces noise into the 5 V line and scrambles the CPU. Secondary source.
  8. ↑ Low End Mac, "Mac Portable" (retrieved 2026-10-02). Conner hard drive with special connector. Secondary source.
