Power Macintosh 7500 Capacitor Replacement Guide
The Power Macintosh 7500, 7600 and 8500 logic board 820-0752-A carries surface-mount aluminium electrolytic capacitors of three values: 47 µF 16 V, 10 µF 16 V and 4.7 µF 25 V. Console5 lists 34 positions on the front and rear of the board, and MacDat's annotated photograph of the front marks 22.[1][2] The photograph shows aluminium cans. Apple's Service Source treats the logic board as one part and gives no component values.[3]
820-0752 is the board that Apple's charts name as supporting cards on the DAV connector in Mode 2; boards marked 820-0564 need Apple's jumper-wire fix to do so.[4] No capacitor list has been published for the 820-0564 board or for the 7300 board, which owners identify as 820-0858-B.[5] Read the number printed on the board before using the table below.
Logic board capacitors
[edit | edit source]| Side | Position | Value | Voltage |
| Front | C49 | 10 µF | 16 V |
| C56 | 10 µF | 16 V | |
| C61 | 47 µF | 16 V | |
| C85 | 47 µF | 16 V | |
| C86 | 10 µF | 16 V | |
| C103 | 10 µF | 16 V | |
| C108 | 10 µF | 16 V | |
| C109 | 10 µF | 16 V | |
| C116 | 47 µF | 16 V | |
| C125 | 47 µF | 16 V | |
| C130 | 10 µF | 16 V | |
| C151 | 47 µF | 16 V | |
| C170 | 47 µF | 16 V | |
| C177 | 47 µF | 16 V | |
| C189 | 47 µF | 16 V | |
| C190 | 47 µF | 16 V | |
| C193 | 4.7 µF | 25 V | |
| C194 | 4.7 µF | 25 V | |
| C195 | 4.7 µF | 25 V | |
| C196 | 4.7 µF | 25 V | |
| C197 | 4.7 µF | 25 V | |
| C230 | 47 µF | 16 V | |
| C231 | 47 µF | 16 V | |
| Rear | C362 | 10 µF | 16 V |
| C369 | 47 µF | 16 V | |
| C372 | 47 µF | 16 V | |
| C373 | 47 µF | 16 V | |
| C383 | 47 µF | 16 V | |
| C392 | 47 µF | 16 V | |
| C396 | 47 µF | 16 V | |
| C432 | 47 µF | 16 V | |
| C435 | 47 µF | 16 V | |
| C440 | 47 µF | 16 V | |
| C452 | 47 µF | 16 V |
Console5 notes that C56 is a 47 µF 6.3 V part on some boards and considers that likely to be wrong, recommending 10 µF in its place.[1] Console5 lists eleven 47 µF parts on the front of the board; MacDat's photograph of the front marks ten, with the same seven 10 µF and five 4.7 µF parts, and shows nothing of the rear.[1][2] The 4.7 µF 25 V parts sit in a row of five, and the 10 µF parts are mostly near the I/O connectors.[2]
Owners report that the 8500 version of the board has all of the video chips fitted, the 7500 and 7600 versions about half and the 7300 none, so a position fitted on one model can be empty on another.[5] Count the parts on your board and replace only what is fitted.
Inspection
[edit | edit source]Swing up the internal chassis or remove the board as described on Power Macintosh 7500 General Maintenance. Look for:
- electrolyte residue, dark rings or corrosion round the capacitor pads
- bulging or leaking cans
- corrosion near the battery holder; a leaking lithium cell leaves acidic residue (see Battery Explosion, Capacitor or Corrosion Damage)
Capacitor Failure Symptoms describes what failing parts look like.
Replacement
[edit | edit source]- Photograph both sides of the board and record the value, voltage and polarity of every part before removing anything.
- Remove each capacitor with hot air or two irons without lifting the pads, and clean away electrolyte with isopropyl alcohol.
- Fit parts of the same capacitance and at least the same voltage rating, observing polarity. On an aluminium electrolytic the marked side is negative; on a tantalum the stripe marks the positive end.
- Do not fit capacitors to empty pads. An owner who added two capacitors to empty positions while recapping a 7300 board, and later removed them, found the computer would power its fan and LED but gave no chime and no picture.[6]
- Check each new part for a short to ground before the first power-up.
[edit | edit source]The 7500 and 7600 use Apple's 614-0039 supply, made by Delta (DPS-150GB) and ASTEC, the same unit as the Power Macintosh 7200. No capacitor list for it has been published; owners' notes on its glued capacitors and on resistor R41 are on Power Macintosh 7200 Capacitor Replacement Guide.[7] The 7300's supply has a different logic board connector. The primary capacitors hold mains-derived voltage; discharge them and confirm with a meter before touching the board, and check the 115/230 V switch before the supply goes back in.
[edit | edit source]- Power Macintosh 7500
- Power Macintosh 7600
- Power Macintosh 7300
- Power Macintosh 8500
- Power Macintosh 7500 General Maintenance
- Power Macintosh 7500 Troubleshooting
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ 1.0 1.1 1.2 Console5 Tech Wiki, "Power Macintosh", section "7500 / 7600 / 8500: 820-0752-A" (secondary source; read 2 October 2026). Console5 sells the set as a tantalum kit.
- ↑ 2.0 2.1 2.2 MacDat, "Power Macintosh 7500 Capacitor Reference" (same data on the 7600 and 8500 pages): logic board, 47 µF 16 V × 10, 10 µF 16 V × 7, 4.7 µF 25 V × 5, all surface-mount electrolytic; photo from MrFahrenheit (secondary source).
- ↑ Apple Computer, Service Source: Power Macintosh 7300/7500/7600 & WS 7350 (1997), exploded view, PDF p. 170: logic boards 661-1154, 661-1219, 661-1266, 661-1783; power supply 661-0920. File:Pm7300.7500.7600.ws7350.pdf; see Power Macintosh 7300/ 7500/7600 & WS 7350 Service Source.
- ↑ Apple Computer, Service Source: Power Macintosh 7300/7500/7600 & WS 7350 (1997), PDF pp. 71–72: boards with 820-0752 silkscreened support DAV cards; 820-0564 boards need a jumper-wire fix near U18.
- ↑ 5.0 5.1 68k Macintosh Liberation Army forum, "7500 Power Supply Woes" (2021): 7300 logic board part number 820-0858-B, with a 24-pin power connector; trag: the 8500 board has all of the video chips fitted, the 7500 and 7600 boards about half and the 7300 none.
- ↑ 68k Macintosh Liberation Army forum, "Power Mac 7300 issues post tantalum" (2020): two extra capacitors fitted to unpopulated pads on the multi-model board during a recap; after their removal the machine still gave no chime or video. A 2025 reply reports the same symptom after a recap, with no fix posted.
- ↑ 68k Macintosh Liberation Army forum, "Need Resistor Value from PowerMac 7600 Power Supply Delta DPS-150GB" (2025–2026): 614-0039 supplies from a 7500 (ASTEC) and a 7600 (Delta); Console5 recap kit; glued capacitors; R41 845 kΩ.
