Macintosh IIci
| The Macintosh IIci logic board, 820-0242-A | |
| Released | 20 September 1989 |
| Discontinued | 10 February 1993 |
| Intro price | US$8,798 at introduction |
| CPU | Motorola 68030 at 25 MHz |
| Memory | 1 MB or 4 MB standard, expandable to 128 MB with 80 ns or faster SIMMs |
| Storage | Optional internal 40, 80 or 160 MB SCSI hard drive |
| Display | — |
| Sound | Apple sound chip, 8-bit stereo sampling at 44.1 kHz, four-voice wavetable synthesis |
| Graphics | Built in, DB-15 port; shares main memory for the frame buffer |
| ROM | 512 KB, 32-bit clean |
| FPU / coprocessor | Motorola 68882 at 25 MHz |
| Media | Internal 1.4 MB SuperDrive |
| Ports / interface | Two ADB, two RS-232/RS-422 mini DIN-8 serial, DB-25 SCSI, DB-19 floppy, DB-15 video, stereo sound jack |
| Expansion | Three NuBus slots and a cache-card connector |
| Power | 100–240 VAC auto-configuring, 50–60 Hz, 90 W maximum |
| Dimensions | 5.5 × 11.9 × 14.4 in (14.0 × 30.2 × 36.5 cm) |
| Weight | 14 lb (6.4 kg) with an internal hard drive |
| OS / Firmware | — |
| Predecessor | Macintosh IIcx |
| Successor | Macintosh Quadra 700 |
| Model no. | M5780 (order no. M5710LL/A); Gestalt ID 11 |
The Macintosh IIci, introduced on 20 September 1989, is the Macintosh IIcx case with a faster processor and three firsts for the Macintosh II line: a 32-bit clean ROM, built-in video and a cache connector.[1]
Everything on this page that is a number comes from Apple's own Service Source for the IIcx, IIci and Quadra 700, hosted on this wiki, or from a named community source.[2]
Specification
| Item | Figure |
| Processor | Motorola 68030 at 25 MHz |
| Coprocessor | Built-in floating-point unit (Motorola 68882) |
| RAM | 1 MB, expandable to 128 MB (80 ns or faster SIMMs) |
| ROM | 512 K, 32-bit clean |
| Expansion | Three NuBus slots |
| Video | One DB-15 port for built-in video |
| Video modes | 640 × 480 at up to 256 colours or greys (8 bits per pixel); 640 × 870 at up to 16 greys |
| Sound | Apple sound chip: 8-bit stereo sampling at 44.1 kHz, four-voice wavetable synthesis |
| Line voltage | 100–240 VAC, automatically configured |
| Frequency | 50–60 Hz, single phase |
| Maximum power | 90 W, monitor excluded |
All of that is Apple's.[2]
Why the 32-bit clean ROM matters for repair
The IIci is the first Macintosh whose ROM contains no 24-bit addressing code, so no MODE32 and no 32-Bit System Enabler is needed to use more than 8 MB.[1] On a IIx or IIcx, a machine reporting 8 MB with 32 MB fitted is a software configuration problem. On a IIci it is a fault: check the SIMMs, the sockets and the bank population before anything else.
Built-in video takes memory
The IIci has no VRAM. The built-in video draws its frame buffer from main memory — between 64 K and 320 K depending on the resolution and depth in use.[1] Two consequences on the bench:
- "About This Macintosh" always shows slightly less RAM than is fitted. That is the frame buffer, not a bad SIMM.
- Built-in video performance depends on which memory bank is populated. The machine is faster with the video frame buffer in a bank that is not also being hammered by the processor, which is why IIci owners have always argued about SIMM placement. It is a performance characteristic, not a fault.
The cache connector
The IIci has a dedicated connector for a 32 K level-2 cache card, provided as a plug-in card on early machines and soldered down on later ones.[1] Apple's developer note gives its signal definitions, including that the card should pull /BGACK up to +5 V.[3]
If your machine has the card, it is a part you can reseat — which makes it worth reseating before you suspect anything more expensive. If it does not, there is nothing to reseat and nothing missing.
Power
The IIci uses the same physical supply family as the IIcx, the IIvi/IIvx and the Quadra 700, at different ratings.
| Apple P/N | Fitted to | Manufacturer and model | Rated output |
| 699-0392 | IIci | Astec AA15830 | +5 V 12 A • +12 V 1.5 A • −12 V 1.0 A • +5 V 1 mA continuous |
| 614-0004 | IIci, Quadra 700 | Astec AA15831 • GE 9T89Y5005G11 | +5 V 12 A • +12 V 1.5 A • −12 V 1.0 A • +5 V 1 mA continuous |
| 614-0009 | Centris 650, Power Macintosh 7100 | Astec AA16870 • Delta SMP-120EB | +5 V 15 A • +12 V 2.5 A • −12 V 0.6 A • +5 V 1 mA continuous |
Those are rating-plate readings taken from physical units by 68kMLA members, not Apple publications, and they are quoted here because they are checkable against the label on your own supply.[4] Note that there is no −5 V output on any of them.
The "+5 V 1 mA continuous" line is the trickle rail, and it is the first useful go/no-go check on a dead machine. It is alive whenever the mains lead is plugged in, switched on or not, because it keeps the soft-power circuit and the clock running. Present means the primary side is working and the fault is downstream; absent means the fault is in the mains input, the primary switcher or the standby circuit.
Console5 records the IIci supply as a GE 9T89Y5005G11 or a Delta SMP-120EB, which matches the Apple 614-0004 and 614-0009 entries above.[5]
Apple publishes no rail tolerance and no power-supply adjustment procedure for the IIcx, IIci or Quadra 700. The Service Source contains no acceptable-range table for any rail and no trimmer adjustment; every power fault in the symptom charts ends in "Replace power supply".[2] The "+5 V 4.85–5.15 V / +12 V 11.9–12.7 V" table that circulates on pages of this era is Apple's Macintosh Plus procedure — genuine there, where it uses voltage test cable 077-0135 on the external floppy port — copied onto machines it was never written for. Neither it nor any invented substitute appears on this page.
What you can do instead is measure against a known load. Each rail at the logic-board power connector should sit close to nominal with the machine running and should not move when a drive spins up. A rail that sags under load points at the supply; a rail that measures as a short to ground with the supply disconnected points at the logic board.
Recapping the supply
You may open it. Understand what is live in it first: it is mains-rectified, so with the cover off and the lead plugged in the fuse, input filter, bridge rectifier and reservoir capacitors sit at mains potential and hold a charge after the plug comes out. Unplug, discharge each large reservoir through a 1 kΩ / 5 W resistor, and confirm with a meter before a tool goes near the primary side. If two reservoir capacitors sit in series across the rectified mains, replace both together with matched parts — a single capacitor in place of the pair will fail on European mains, violently.
Battery
A 3.6 V lithium half-AA cell in a holder on the logic board keeps the real-time clock and parameter RAM alive with the machine unplugged.
- Set a meter to the 10 V DC range.
- Positive probe on the positive end of the cell, negative probe on the other.
- Replace the cell if it reads below 2.8 V.[2]
2.8 V is this machine's figure. It is not the 3.2 V of the II/IIx/IIfx, the Centris machines and the larger Quadras, and not the 3.0 V of the IIsi and the LC series. Apple's thresholds are machine-specific and are routinely transplanted between pages; use the one printed in your own machine's manual.[2]
Apple publishes no replacement interval, and none is invented here: a cell above 2.8 V is doing its job, and one below it should come out today whatever its age.
If it has leaked
This is a lithium cell, so neutralise with bicarbonate of soda, not vinegar. Vinegar is the right treatment for alkaline leakage, which is basic; it is the wrong treatment here and it adds water and chloride to an already corroded board. Use a paste of sodium bicarbonate and distilled water, rinse with distilled water, follow with isopropyl alcohol and dry thoroughly. Then buzz out every track running away from the holder, and check the underside of the board — electrolyte wicks down through vias.
Take the cell out before the machine goes into storage.
Apple's symptom chart puts "replace battery" as the first cure for a clock that does not run on this machine, ahead of the logic board.[2] Apple's developer note describes the parameter RAM as having seven-year battery protection — which is the design intent, not a service interval, and tells you nothing about a cell that has been in the machine since 1992.[3]
Capacitors
Logic board 820-0242-A (1989). Fourteen electrolytics:[6][7]
| Value | Working voltage | Quantity | Package |
| 47 µF | 16 V | 8 | Surface-mount |
| 470 µF | 25 V | 3 | Axial |
| 220 µF | 25 V | 1 | Axial |
| 10 µF | 16 V | 2 | Surface-mount |
Note the axial voltage ratings. MacDat records the IIci's four axial capacitors as 25 V parts, against 16 V on the otherwise very similar IIcx board, and flags the difference explicitly on both pages.[6] Fit 25 V here. A higher rating is never a hazard; a lower one is exactly the class of mistake this wiki exists to stop.
Console5 carries no IIci capacitor list, so unlike the IIx and IIcx this complement rests on two sources rather than three: MacDat's reference list and Recap-a-Mac's annotated photograph, hosted here as File:Mac IIci Recap Guide.jpg.[6][7] Both are readings of physical boards; Apple published no component-level capacitor data for any Macintosh of this era. Read the value and voltage off each can before you lift it.
The failure pattern is the family one — audio first, then intermittent starting, then visible residue. See Capacitor Failure Symptoms.
Connectors and sockets
- SIMM sockets. Clean with isopropyl alcohol on a swab and reseat. Do not take an abrasive to a module's gold fingers — once you are through the plating, the base metal oxidises and then transfers to every socket the module touches.
Two more specific to this board: the cache connector, where one is populated, and the ROM DIPs at UM10–UM13 alongside the ROM SIM socket. A poorly seated ROM gives a machine that chimes and does nothing else.
Cleaning
Opening the case
The IIcx and IIci chassis is the easiest of the Macintosh II family to work on: release the catches and the cover lifts away, and the logic board slides out of the bottom case on rails once the drives and the supply are clear. There are no hidden screws.
Inside
Outside
- A damp microfibre cloth and mild detergent. No abrasives, no solvents — the texture on these shells does not survive either.
Floppy drive
The 1.4 MB Apple SuperDrive is direct drive. It has no belt. Advice to fit a new belt to a sluggish or non-ejecting SuperDrive — including to the auto-inject version — is wrong: there is nothing there to replace. What these drives actually suffer is hardened grease on the head carriage and eject rails, dust in the mechanism, and dirty or worn heads. On manual-inject drives a worn eject gear is a genuine and common failure.
- If the rails are stiff, re-lubricate with a silicone grease — not white lithium grease, which gums up as it ages.
Hard disk
Apple's own SCSI notes for this chassis: the external device's ID switch must not be set to 0 (the internal drive) or 7 (the computer), and Apple resolves both "drive icon does not appear" and "data is lost or corrupted" to a termination check.[2]
Easter egg
Set the system date to 20 September 1989 — the machine's introduction date — set the display to 8-bit colour, and restart holding Command-Option-C-I. A colour photograph of the IIci design team appears; click the mouse to continue.[8]
The IIfx has the same egg on its own date with its own key combination, and displays the same picture.[8]
Things that are not faults
- Slightly less RAM reported than fitted. The built-in video frame buffer lives in main memory.[1]
- A cache connector with nothing in it. The card was an option and was soldered down on later boards.[1]
- 640 × 480 at 8 bits being the limit of the built-in video. That is Apple's published figure; more needs a NuBus card.[2]
- Take the battery out.
- Store dry and at room temperature — not a loft, not a garage.
Service documentation
- Macintosh IIcx — the same case, one generation earlier
- Macintosh Quadra 700 — the same case, 68040
- Macintosh IIx
- Macintosh IIcx/IIci/ Quadra 700 Service Source
- Macintosh IIci Developer Note
- Capacitor Failure Symptoms
- Recommended Tools
- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 EveryMac.com, Macintosh II series specification pages — https://everymac.com/systems/apple/mac_ii/ . Secondary source: a long-running reference compiled from Apple product literature. Used here for model and order numbers, Gestalt IDs, introduction and discontinuation dates, original US prices, and the maximum RAM actually achievable with 16 MB SIMMs.
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 Apple Computer, Service Source: Macintosh IIcx/IIci/Quadra 700. Hosted on this wiki as File:Quadra 700.mac iicx.iici.pdf; see Macintosh IIcx/IIci/ Quadra 700 Service Source. Chapters used: Specifications, Troubleshooting (Symptom Charts), Take Apart and Additional Procedures (Battery Verification).
- ↑ 3.0 3.1 Apple Computer, Macintosh IIci Developer Note. Hosted on this wiki as File:Macintosh IIci Developer Note.pdf; see Macintosh IIci Developer Note.
- ↑ 68kMLA forum thread "Compact Desktop Power Supply Capacitor Lists (by make and model)", posts by jessenator, Fizzbinn and Franklinstein. Secondary source: rating-plate readings taken from members’ own supplies. Used here for Apple part numbers 699-0392, 614-0004 and 614-0009, their manufacturers and model numbers, and their rated rail currents.
- ↑ Console5 TechWiki, Apple computer pages — https://wiki.console5.com/wiki/Category:Computer . Secondary source: community-maintained per-designator capacitor lists compiled from physical boards. Used here for logic-board assembly numbers and per-designator capacitor lists where Console5 carries the board.
- ↑ 6.0 6.1 6.2 MacDat Capacitor Reference Library, Apple section — https://macdat.net/repair/cap_reference/apple/ . Secondary source: a community-maintained capacitor reference compiled from physical boards, giving value-and-count lists and, for most boards, an annotated reference photograph. Used here for the per-board electrolytic complements quoted, which agree with Recap-a-Mac’s independently produced board photographs wherever both cover the same board.
- ↑ 7.0 7.1 Recap-a-Mac, Macintosh IIci — https://recapamac.com.au/macintosh-iici/ . Annotated photograph of the 820-0242-A logic board with each electrolytic marked with its value, working voltage and positive terminal. Hosted on this wiki as File:Mac IIci Recap Guide.jpg. Secondary source: one repairer’s reading of boards handled personally.
- ↑ 8.0 8.1 "The Macintosh/Newton Easter Egg List", Higher Intellect Vintage Wiki, a mirror of the long-running Usenet Macintosh Easter egg list. Secondary source. Used here for the exact key combinations and date settings for the Macintosh IIci and Macintosh IIfx design-team pictures, and for the observation that both machines display the same image.
