Macintosh IIsi
Revision as of 18:42, 1 October 2026 by Josh (talk | contribs) (Remove Category:Macintosh II series (created in error, to be deleted))
Macintosh IIsi
Macintosh IIsi (All About Apple museum)
TypeDesktop personal computer
Released15 October 1990
Discontinued15 March 1993
Intro priceUS$3,770-4,570 at introduction
CPUMotorola 68030 at 20 MHz
Memory1 MB soldered plus four 30-pin SIMM sockets; 17 MB in Apple's specification, 65 MB with 16 MB SIMMs
StorageInternal 40 or 80 MB SCSI hard drive
Display—
SoundApple Sound Chip stereo output; 8-bit mono sound input
GraphicsBuilt in (DB-15), frame buffer in the soldered 1 MB of RAM
ROM512 KB
FPU / coprocessorOptional 68882 on the slot adapter card
MediaInternal 1.4 MB floppy drive; external floppy port
Ports / interfaceADB, two RS-232/RS-422 serial (mini DIN-8), SCSI (DB-25), floppy (DB-19), video (DB-15), sound in and out
ExpansionOne 120-pin slot, NuBus or 68030 direct slot through an adapter card
Power100-240 V AC auto-configured, 50-60 Hz, 100 W maximum
Dimensions4.0 × 12.4 × 14.9 in (10 × 31 × 37.2 cm)
Weight10 lb (4.5 kg)
OS / FirmwareSystem 6.0.7 to Mac OS 7.6.1
SuccessorMacintosh Centris 610
CodenameErickson, Raffica, Raffika, Ray Ban, Spin, Oceanic
Model no.M0360 (Gestalt ID 18)
The Macintosh IIsi is a desktop Macintosh introduced by Apple on 15 October 1990 and discontinued on 15 March 1993.[1] It is a lower-cost relative of the Macintosh IIci in a smaller case of its own: the same MDU and RBV chip set, a 20 MHz 68030, 1 MB of RAM soldered to the board, built-in video and sound input, and a single expansion connector that takes either a NuBus card or a 68030 direct-slot card through an adapter.[2] Apple's service manual gives it a volume of its own.[3]
Macintosh IIsi specifications (Apple)
Item Specification
Processor Motorola 68030 at 20 MHz; 256-byte instruction and data caches; burst-mode RAM access; built-in MMU[3]
Coprocessor Motorola 68882 at 20 MHz, on the optional adapter card only[3]
RAM 2 MB, expandable to 17 MB (1 MB soldered plus four 30-pin SIMMs); 100 ns fast-page-mode[3][2]
ROM 512K[3]
Parameter RAM 256 bytes[3]
Floppy drive Internal 1.4 MB; external DB-19 port for an 800K or 1.4 MB drive[3][2]
Hard drive Internal 40 MB; optional internal 80 MB[3]
Expansion One slot for either a NuBus or an 030 direct-slot card; 15 W maximum[3]
Video Built-in: 12-inch and 13-inch RGB and 12-inch monochrome monitors at up to 8 bits per pixel; 15-inch portrait monitor at up to 4 bits per pixel[2]
Sound Four-voice wavetable synthesis and stereo sampling; output impedance 8-600 Ω, short-circuit protected; internal speaker disabled when the jack is used; 8-bit mono sound input[3][2]
Power 100-240 V AC, automatically configured; 50-60 Hz single phase; 100 W maximum, not including the monitor[3]
Size and weight 4.0 × 12.4 × 14.9 in (10 × 31 × 37.2 cm); 10 lb (4.5 kg), varying with configuration[3]
Apple's online specification sheet for the IIsi gives the maximum as 160 W (1.33 A, 547.2 BTU per hour), the battery as 3.6 V lithium, and one ADB port.[4]
Macintosh IIsi order numbers (EveryMac)
Order number RAM Hard drive
M0363LL/A 2 MB 40 MB
M0491LL/B 3 MB 40 MB
M0364LL/A, M0364LL/B 5 MB 80 MB
M0954LL/A 5 MB 160 MB
Memory and video
Bank A is the 1 MB soldered to the logic board, eight 256K × 4 DRAMs that cannot be changed. Bank B is four 30-pin SIMM sockets, filled with four identical SIMMs of 256K, 512K, 1 MB, 2 MB or 4 MB. Apple's developer note also allows 16 MB SIMMs, which give 65 MB.[2][4] Apple's figure for SIMM speed is 100 ns or faster.[2]
The built-in video has no video RAM of its own. The RBV chip uses the soldered bank A as its frame buffer, taking only as much as the screen needs at the chosen depth.[2] EveryMac gives 64K to 320K.[1] Video fetches tie up bank A only; the processor can use bank B at the same time.[2] Low End Mac notes that sharing RAM with the video slows the machine slightly, and suggests a 768K disk cache, which occupies bank A so that programs run from the SIMMs.[5] With an unknown monitor, or none, the built-in video stops.[2]
ROM
Apple's developer note says the first production IIsi boards carry the 512K ROM on a ROM SIMM, and later boards have it soldered, with the SIMM socket kept for upgrades.[2] Low End Mac says a board built with a ROM SIMM will not work without it.[5] On the board Recap-a-Mac photographed, the soldered ROMs are the two square chips above the floppy connector.[6]
Expansion slot and FPU
The logic board has one 120-pin Euro-DIN connector. Apple sold two adapter cards for it: one takes a 68030 direct-slot card, the other a NuBus card, and both carry a 20 MHz 68882. A IIsi without an adapter has no FPU; a buyer who wanted the FPU and nothing else still had to fit an adapter.[2][3] Macintosh SE/30 direct-slot cards work if they can run at the IIsi's 20 MHz and their ribbon cables are at least 220 mm long.[2] The NuBus card sits horizontally over the logic board at slot address $9, and Apple says any NuBus card size it specifies fits.[2]
Apple budgets 15 W for the slot. The Service Source prints the currents as "+5 V 2.0 A, +12 V 175 A, -12 V 150 A"; the last two can only be milliamps within 15 W.[3]
Power control
A Motorola 68HC05-based microcontroller runs ADB, the clock, parameter RAM, soft power and power-on reset. The supply keeps a +5 V trickle output whenever the machine is plugged in, which lets the controller watch the keyboard power key and the rear power switch.[2] There is no programmer's switch: Command-Control-Power gives a hard reset, and Command-Power an NMI once a control panel has enabled it; hold either for at least a second.[2]
The rear power switch can be locked on with a screwdriver or coin, so that the IIsi restarts itself after a power cut. Apple's cure for "system restarts itself" is to turn that switch back to the unlocked, horizontal position.[2][3]
Sound
Sound output uses the Apple Sound Chip and two Sony sound chips, as on the II, IIx, IIcx and IIci. Sound input is 8-bit mono through a filter, preamplifier and FIFO buffer; a microphone came with the machine.[2] The speaker sits under the logic board and connects through metal fingers pressing against the underside of the board.[3] When those contacts corrode, the internal speaker cuts out, sometimes only after hours of running; see Macintosh IIsi Troubleshooting.[7]
Apple part 661-1616.[3] Console5 and Recap-a-Mac identify it as a Sony APS-06M, and Recap-a-Mac says it is "extremely prone to leakage".[8][9] Its capacitor list is on the Macintosh IIsi Capacitor Replacement Guide. Apple publishes no rail tolerances and no adjustment for it; every power fault in the symptom charts ends at "replace power supply".[3]
Battery
The clock and parameter RAM are kept by a 3.6 V lithium cell in a holder on the logic board.[4] Apple's test: with the cover off, measure on the 10 V DC range and replace the battery if it reads below 3.0 V. To change it, remove the cover and expansion card, prise open the latch at the end of the holder with a small flat-blade screwdriver, and match the "+" end to the "+" on the holder.[3] Remove the cell before storing the machine; see Battery Explosion, Capacitor or Corrosion Damage.
Capacitors
Logic board 820-0301-A has eleven 47 µF 16 V surface-mount electrolytics and two 220 µF 16 V axial parts, and Recap-a-Mac found leaking capacitors on both the logic board and the power supply.[6] Designators and the power supply list are on the Macintosh IIsi Capacitor Replacement Guide.
Maintenance and repair
  1. ↑ 1.0 1.1 Apple Macintosh IIsi Specs, EveryMac—link(accessed 2026-09-30) Introduced 15 October 1990, discontinued 15 March 1993; US$3,770 and US$4,570; model M0360, Gestalt ID 18; order numbers M0363LL/A (2 MB, 40 MB), M0364LL/A and M0364LL/B (5 MB, 80 MB), M0491LL/B (3 MB, 40 MB), M0954LL/A (5 MB, 160 MB); 64-320K of RAM used by video; 3.6 V lithium battery.
  2. ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 2.15 2.16 2.17 2.18 Apple Computer, Macintosh IIsi Computer Developer Note (1990), File:Macintosh IIsi Developer Note.pdf; see Macintosh IIsi Developer Note. Page numbers are the PDF's: features pp. 14-16; compatibility pp. 18-20; RAM interface and video use of RAM pp. 32-36; ROM interface p. 38; on-board video p. 41; sound p. 61; ADB microcontroller, RTC, soft power, reset and NMI pp. 62-66; 68030 Direct Slot pp. 70-72; NuBus adapter p. 95.
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 3.11 3.12 3.13 3.14 3.15 3.16 3.17 3.18 3.19 Apple Computer, Macintosh IIsi Service Source (1995), File:Macintosh iisi.pdf; see Macintosh IIsi Service Source. Page numbers are the PDF's: Specifications pp. 5-12; Symptom Charts pp. 15-28; Take Apart pp. 30-48; Upgrades (adapter cards) pp. 50-56; Battery Verification p. 59; Battery Replacement pp. 60-62; Exploded View p. 64.
  4. ↑ 4.0 4.1 4.2 Macintosh IIsi: Technical Specifications, Apple—link(accessed 2026-09-30) Max watts 160, amps 1.33, BTU per hour 547.2, 100-240 V, 50-60 Hz; battery 3.6 V lithium; soft power and pass-through outlet; 1 MB on the logic board, four 30-pin SIMM slots, 1-17 MB, 100 ns, installed in groups of four; one ADB port; Gestalt ID 18; ROM ID $067C; original system software 6.0.7; supported to 7.6.1.
  5. ↑ 5.0 5.1 Mac IIsi, Low End Mac—link(accessed 2026-09-30) Intended as a 25 MHz machine and scaled back to 20 MHz; 768K disk cache or IIsi-RAM-Muncher to keep programs out of the video bank; speaker fault from poor contact; ROM SIMM rare, and a IIsi that has one will not work without it; US$3,800; code names; SE/30 PDS at 20 MHz.
  6. ↑ 6.0 6.1 Macintosh IIsi, Recap-a-Mac—link(accessed 2026-09-30) Annotated photograph of logic board 820-0301-A, hosted here as File:Mac IIsi Recap Guide.jpg: 11 × 47 µF 16 V surface-mount and 2 × 220 µF 16 V axial; leaky capacitors on the logic board and in the power supply; some versions use a ROM SIMM instead of soldered ROMs.
  7. ↑ Elliotte Rusty Harold and contributors, Macintosh hardware FAQ, "How can I fix the sound on my IIsi?", 32 How can I fix the sound on my IISI?, TULARC—link(accessed 2026-09-30)
  8. ↑ Sony APS-06M, Console5 TechWiki—link(accessed 2026-09-30)
  9. ↑ Macintosh IIsi Power Supply, Recap-a-Mac—link(accessed 2026-09-30)
